Andy Green Posted February 27, 2014 Author Share Posted February 27, 2014 No I didn't, but with 1/16 sheet before the ply plate is it necessary? I expect it will compress over time anyway. Andy Quote Link to comment Share on other sites More sharing options...
kc Posted February 27, 2014 Share Posted February 27, 2014 Well I wondered if that's why you were looking into the incidence.I would expect the bolts to compress the balsa and maybe not the same front and rear therefore changing the incidence or maybe changing it from flight to flight.Danny's photo shows how he neatly cut around the alloy and removed the balsa. Quote Link to comment Share on other sites More sharing options...
Andy Green Posted February 27, 2014 Author Share Posted February 27, 2014 The front cabane assembly is still still loose, not fixed at either end. Wanted to get the incidence right (?) and fixed to the fuse, then the lateral positioning, with the holes into the wing. All very empirical. Andy Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted February 27, 2014 Share Posted February 27, 2014 Andy can you take a pic of the forward cabane to fus section of the plan. I think I can see a reason....CheersDanny Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted February 27, 2014 Share Posted February 27, 2014 Ignore that last post Andy, I checked my drawing and yourcabane mounting looks the same as mine. Which considering the other similarites between the Barnstorme/Bistormer makes sense..... Cheers Danny Edited By Danny Fenton on 27/02/2014 21:20:22 Quote Link to comment Share on other sites More sharing options...
Andy Green Posted February 27, 2014 Author Share Posted February 27, 2014 Thanks Danny The front mount is as per plan. Thing is its probably me, measured its 2.3 degrees, and from crude measurement from plan its 3, which is close enough. I think my initial guess was at fault. Andy Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted February 27, 2014 Share Posted February 27, 2014 I try to keep things simple on these models Andy, I try and build them as accurately to the plan as I can, ie as the designer intended, leave the designer to worry about incidences etc and, I send it aloft Your way is far more scientific But they usually fly okay I am looking forward to flying in the circuit with the Barnstormers at Greenacres should be very memorable, and a great tribute to Boddo Cheers Danny Quote Link to comment Share on other sites More sharing options...
Andy Green Posted February 28, 2014 Author Share Posted February 28, 2014 I agree Danny, I think I may be trying to be too clever. Andy Quote Link to comment Share on other sites More sharing options...
Barnstormer 52 Posted February 28, 2014 Share Posted February 28, 2014 Posted by kc on 27/02/2014 17:37:05: Well I wondered if that's why you were looking into the incidence. I would expect the bolts to compress the balsa and maybe not the same front and rear therefore changing the incidence or maybe changing it from flight to flight. Danny's photo shows how he neatly cut around the alloy and removed the balsa. Hi I have done this both ways in the past. I think it's better to cut the balsa sheet away. You can cut an X in the covering and iron it down. The edges of the 1/16" sheet help when locating the wing and putting the bolts in. If you leave the 1/16" sheet, it does compress and you get saggy covering. Regards Geoff Quote Link to comment Share on other sites More sharing options...
Andy Green Posted April 14, 2014 Author Share Posted April 14, 2014 Not been idle, nearly finished, but first a catch up. As I've mentioned before there will be no wires running to the wing, I'll be using the cabanes. and the wing will carry all the wiring. Typical connection detail - wires soldered onto the captive nuts with a strain relief to support the wire. Its all then sheeted and capping strips added. The capping strips were cut from a 3"sheet with a balsa stripper. Servo built into the wing, worked well on my Super 60. More details on my website Andy Quote Link to comment Share on other sites More sharing options...
Andy Green Posted April 14, 2014 Author Share Posted April 14, 2014 Nearly forgot the cabane strut pins. 1/8 dowel epoxied in place. Front top decking, built up and razor planed to shape. Andy Quote Link to comment Share on other sites More sharing options...
Andy Green Posted April 14, 2014 Author Share Posted April 14, 2014 Split cabane strut split as these will carry the servo supply and signals. that 2 for the power and 2 for the servo signals Typical connection to get the servo signal to the cabanes. The ends will be terminated in a servo plug. Andy Quote Link to comment Share on other sites More sharing options...
Andy Green Posted April 14, 2014 Author Share Posted April 14, 2014 Complete wing ready for covering. I have a unique scheme up my sleeeve. Details to follow. Things to do. Make the elevators Drill all hinges Cover Andy Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted April 14, 2014 Share Posted April 14, 2014 Andy are you insulating those cabanes? If not then I have a concern about anything metal being dropped near that gap, maybe a screwdriver or allen key maybe? Quote Link to comment Share on other sites More sharing options...
Andy Green Posted April 14, 2014 Author Share Posted April 14, 2014 I hear what you are saying Chris, one side will not be covered (part of the scheme) not sure about the other side. To be honest I'm not too concerned. I don't have any long reach allen keys, and it could only be an issue when turned on. Also the amount of bare metal wont be as bad is it looks in the pictures as the top section / cockpit will be there. That said a coat of finishing epoxy won't go a-mis Andy Quote Link to comment Share on other sites More sharing options...
Andy Green Posted May 8, 2014 Author Share Posted May 8, 2014 Wings and tail surfaces are now covered, but ho photos until the fuselage is done. For fun I have added a flashing LED strip light. Andy Quote Link to comment Share on other sites More sharing options...
Andy Green Posted May 11, 2014 Author Share Posted May 11, 2014 Colour scheme revealed: Split down the middle half colooured and the other clear Profilm. Andy Quote Link to comment Share on other sites More sharing options...
GrahamWh Posted May 11, 2014 Share Posted May 11, 2014 Very interesting colour scheme Andy. I am thinking of building an Aircamper from the Traplet plans which is a similar looking craft and might have a go with some transparent colour film (again!). Very neat work. What colour will the leds be? Quote Link to comment Share on other sites More sharing options...
Andy Green Posted May 11, 2014 Author Share Posted May 11, 2014 The LED's are multi coloured from Hobby King. Not tired them yet. Probably should have tested them before covering. Andy Quote Link to comment Share on other sites More sharing options...
Martian Posted May 12, 2014 Share Posted May 12, 2014 Very nice Andy looks lovely and neat and is that an inspiration in the background for a new plane (THE PUSSY CAT ) Quote Link to comment Share on other sites More sharing options...
Andy Green Posted May 12, 2014 Author Share Posted May 12, 2014 Funny you should say that. I have a design for a small .25 powered model I designed to learn CAD, while playing one day Merlin (the cat a right miserable so and so) came in with a mouse, and started chomping his way through it. The model is called 'Merlins Mouse' Andy Quote Link to comment Share on other sites More sharing options...
Martian Posted May 12, 2014 Share Posted May 12, 2014 LOL that's brilliant Quote Link to comment Share on other sites More sharing options...
Andy Green Posted June 5, 2014 Author Share Posted June 5, 2014 Light ply with supports for the servo mounts and switch. Andy Quote Link to comment Share on other sites More sharing options...
Andy Green Posted June 5, 2014 Author Share Posted June 5, 2014 Fully assembled and programmed. Hope to maiden this weekend. Andy Quote Link to comment Share on other sites More sharing options...
Martyn K Posted June 5, 2014 Share Posted June 5, 2014 Looks great Andy. Another Classic Aerobat Martyn Quote Link to comment Share on other sites More sharing options...
