Jerry Zito Posted August 23, 2014 Share Posted August 23, 2014 I'm working on my quadcopter, and I would like to add LED lights. I am looking for some kind of wiring harness to connect all four light sections to my receiver. I saw one on YouTube, but he didn't mention where he got it. Anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 23, 2014 Share Posted August 23, 2014 Thinking of it, why not try lighting from a model railway specialist? They might have packs of lights. Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted August 23, 2014 Share Posted August 23, 2014 Mr Google is your friend "Quadcopter lights"... **LINK** Quote Link to comment Share on other sites More sharing options...
Phil Green Posted August 23, 2014 Share Posted August 23, 2014 Standard LED sticky-strips run directly off a 3S lipo, as long as you cut them in multiples of three. I think that's what most quad people use. Edited By Phil Green on 23/08/2014 19:21:56 Quote Link to comment Share on other sites More sharing options...
Jerry Zito Posted August 23, 2014 Author Share Posted August 23, 2014 Thanks Dave, Cymaz, and Phil. I appreciate the response. I have ordered a roll of white and red LED strips from HK. That's a good idea tapping into the flight battery. I have seen several wiring harnesses but they all come with LED's built in. I was thinking that I could tap into an unused port on my receiver and get the power from there and also be able to turn on and off the lights. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted August 23, 2014 Share Posted August 23, 2014 If you want to control the LED lighting from a receiver output, you will need something similar to this: **LINK** Quote Link to comment Share on other sites More sharing options...
Phil Green Posted August 23, 2014 Share Posted August 23, 2014 Jerry you cant power the LEDs from the rx, they need at least 10 volts, preferably 12v. You can switch them from a rx channel but they still need the higher voltage supply. I think most people just take the LED power from the lipo balance plug. Quote Link to comment Share on other sites More sharing options...
Jerry Zito Posted August 23, 2014 Author Share Posted August 23, 2014 Thanks Gary. I think that will work nicely. Quote Link to comment Share on other sites More sharing options...
Jerry Zito Posted August 23, 2014 Author Share Posted August 23, 2014 Now that you mention it Phil. I believe you are correct. I never thought Led lighting was so complcated. 😩 Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted October 13, 2014 Share Posted October 13, 2014 You maybe can't power HK LED sets direct from the receiver, but you can home-make sets that will run off 5v, or even buy strips from Dimension Engineering that'll run direct off the receiver. The Dimension Engineering ones are much shorter than the HK ones. I've just installed some on my 250-size quad. Whichever way you go, you need an LED controller if you want to switch them on and off remotely. Quote Link to comment Share on other sites More sharing options...
Eamonn Fahey Posted October 13, 2014 Share Posted October 13, 2014 Jerry, HobbyKing UK warehouse have an ADAPTER to connect 4 of their LED strips to your flight battery. Eamonn. Quote Link to comment Share on other sites More sharing options...
