How to make a pilot bust
Fraazen
Hallo!
As many, I do not like to have an empty cockpit, especially if a clear canopy is to used. Drones apart, every plane is flown by a pilot and everybody of us is a pilot. So a decent "avatar" should be considered.
A year ago I started the construction of the beautiful CleanSweep from Tim Hooper and then I started looking here and there to find an appropriate figure for the role. I was not wanting to spend a fortune for a very good figure, after all it's not a scale model. Nor, the simple Chinese molded and painted figure seemed absolutely poor for a model with a certain character.
I was also wondering about a very unique pilot, maybe not the best one, but a least only mine. And "snap!" the idea came!
Why not sculpting one?
Stay tuned to see the progress and have some hints!
Francesco
Hello guys and thank you for your support!
For sure I'm not a master sculptor, so I looked for a way to combine technology (i.e. a PC) and manual work in order to streamline the process and obtain a decent pilot in a reasonable time.
Unfortunately, I'll be abroad for few days, so you have to wait a little bit for the complete explanation... Just a picture for now, the subject I started from... Quite complex for now, but he will become easier later!
Regards!
Francesco
Ok, I'm back from my trip in the cold russian winter, so I can continue on this project.
The first step is to find a suitable bust figure in 3D. OBJ data format works well, but other are suitable, too. The one I'm going to use was downloaded for free from the site **LINK**. You need to login and become member, but that all, nothing to pay.
Another useful tool for our purpose is the 123D Make software, also available for free both for Mac and PC. I like Mac, but this is just my preference. This is a powerful yet easy to use software that let you convert this complex 3D model into something more simple and, most important, real.
After you have downloaded the 3D model and 123D Make software, let import the model by clicking on the "Import" command. Then browse to your file and click "Open". After few seconds (or minutes, depending on your machine!) your model will appear. Notice that the user interface is now a little bit more complete, with additional commands.
Rotate the model and fit it to screen size up to the point you're satisfied with it, using the commands I've hi lighted on the right.
Now, looking at the left panel, change units to suit your preference and needs, choosing from in, cm, mm or ft.
Now, adjust the size: it's enough to modify to height to have all the others scaled accordingly. Of course, you can also deactivate the control "Uniform scale" to achieve a somehow different (maybe hugely?) effect.
I'm going to use a height of 7cm.
The next step is the magic one! With few clicks we are going to transform the model in something more realistic.
Click on "construction technique" and choose "Stacked slices": the model will change dramatically, becoming something like this:
At this stage you should have guessed what my idea is: to transform a complex, detailed 3D model into a series of balsa slices that will be glued in stack and refined to our needs.
Now you have to change parameters a little bit to make a balance between the number of slices to be cut and the level of detail, nothing that thinner slices will provide a much, much better level of detail. The picture above uses 4,5mm balsa slices, while the following ones are created with 2,5mm and 1,0mm respectively. Impressive difference, true?
For my needs, a thickness of 1,5mm seems to be ok. This is the result.
After that, playing whit the "Dowels" panel let you add a dowel which is very helpful for aligning the stack when gluing them together. I would suggest a vertical dowel that has the further benefit of being able to keep the stake aligned in both X and Y directions, while a round one will leave some play to turn them left or right, that could be good if you want to create a bust that faces on either side of the plane. If you choose (as I did) a vertical dowel, this is automatically added to the project as well and will pop-up on the screen.
Ok, last couple of picture and we can finish with this boring (although very quick) software!
Click on the little arrow on the top right corner: a new panel will appear showing you the number of sheets and parts that are going to compose your pilot.
Next, a click on the "Get plans" button (bottom left) let you export the plans in different formats or print them on your desktop printer. The first option let you create a DXF file that can be used also with CNC machines for easiness of construction. In my case, I had my stake printed out on a couple of A4 pages.
Ok, for today we have finished! Recap: we downloaded a model fro Internet, then we used the 123D Make software to slice the model into something we can build and finally we have printed (or exported) the slices so that we can now move to the construction phase.
Stay tuned for further development!
regards,
Francesco
Posted by Bob Cotsford on 24/01/2015 13:30:02:
What an ingenious process,though I do see it becoming labour intensive if you don't have cnc or laser cutters to hand!
Not that much!
in fact, it's going to take a n hour or two to cut out the parts, and gluing is only 10-20 minutes, depending on the glue you are using.
it's a little bit more complicated sorting out the thickness as the paper size keeps defaulting back to inches, so i converted my mm's to inches and sorted the problem.
got two pages of sections printed out now, next job is to cut it all out and see what it looks like all glued together.
be easier if i had a 3d printer.
Posted by Tony Bennett on 24/01/2015 16:26:02:
Hi Tony!
You're right, selecting the proper paper is a little bit complicated, I also had some problems on it. Anyhow, I finally managed to create a proper set of stacks to be printed, as well as a DXF copy to use with my StepCraft cutting machine.
For the first experiment, I've anyhow resorted to manual cut each part for this is more similar to what most of us have to do!
Regards!
Francesco
Posted by Tony Bennett on 25/01/2015 10:15:03:
hand cutting the parts are a nightmare.
i spent 3 hours cutting parts last night and the end result was not worth the effort put in.
if you can get the parts laser or cnc cut, then this is a good method.
still i look forward to seeing your pilot figure and i hope yours turns out better than mine did.
For me it was not so complicated, only time consuming!
