torbjornp Posted February 13, 2015 Share Posted February 13, 2015 Hi! Any good suggestions for fitting the cowl on my nearly finished (after 2 years in the box....) AcroWot? Saito GK .65 should be a good choice for this plane. Feels like putting a ship in a bottle to me Torbjørn, Norway Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 13, 2015 Share Posted February 13, 2015 I have used the strip cardboard method several times. Stick some cardboard on the fuselage. Mark and cut holes in the cardboard where the carb, exhaust and head stick out. Remove the engine from the mount( it only needed to be put in with a bolt to stop it dropping out ). Don't remove the card off the fuselage. Transfer the holes etc from the card to cowl. Cut the holes starting small from the middle of the marks. See how you get on with it Edited By cymaz on 13/02/2015 21:22:49 Quote Link to comment Share on other sites More sharing options...
Jon Laughton Posted February 13, 2015 Share Posted February 13, 2015 I'll second Cymaz's suggestion I use a dremel with a small sanding drum to make the necessary holes in a cowl - take it slow and keep checking how it fits & don't guess! Jon Quote Link to comment Share on other sites More sharing options...
alan p Posted February 13, 2015 Share Posted February 13, 2015 Don't forget to put masking tape on the cowl, covering more than the area to be removed. Prevents the edges splintering. also you can mark out the area to be removed with a pencil or marking pen. Quote Link to comment Share on other sites More sharing options...
bert baker Posted February 13, 2015 Share Posted February 13, 2015 Two thumbs fresh for Cymaz. Quote Link to comment Share on other sites More sharing options...
Braddock, VC Posted February 13, 2015 Share Posted February 13, 2015 Saito 65 bit underpowered for the acrowot (kit anyway imho). My saito 82 was mounted inverted, makes a much neater install. Then follow cymaz recommendation. My current a/w kit , in the building for the last 4 years is getting an OS 91 fx with the opportunity to swap to a saito 125 as they have the same footprint. All I have to do first is sort out the split veneer on the wings. I keep asking myself why do chris foss veneered foam wings split whereas my galaxy foxjet and precedent hi boy foam wings stored alongside for longer don't split. Guess I'll have to ask CF. Quote Link to comment Share on other sites More sharing options...
Masher Posted February 14, 2015 Share Posted February 14, 2015 I agree with Cymaz's advise on how to mark cowl. However I disagree with Braddock IF yours is the ARTF version. I have a Saito 65 in my ARTF mounted sideways and I think it is ideal. There are 2 others in my club who have Saito 82's in theirs - well apart from being louder they don't seem much different to mine. Quote Link to comment Share on other sites More sharing options...
David Davis Posted February 14, 2015 Share Posted February 14, 2015 Posted by Braddock, VC on 13/02/2015 23:15:18: My current a/w kit , in the building for the last 4 years is getting an OS 91 fx with the opportunity to swap to a saito 125 as they have the same footprint. Are you sure you have enough power in that thing Braddock? Quote Link to comment Share on other sites More sharing options...
Masher Posted February 14, 2015 Share Posted February 14, 2015 I had a photo With the 65, I have got away with no lead added to get C of G so I wonder how it works out for the larger engines? Edited By Masher on 14/02/2015 08:10:50 Quote Link to comment Share on other sites More sharing options...
torbjornp Posted February 14, 2015 Author Share Posted February 14, 2015 Hi Masher! Did you cut some of the rear of the cowl, to get the lump of cast iron to fit through the opening? It is a bit narrow to fit the Saito .65 without picking it to peaces...😱 I have a Saito .85, that is actually smaller. But that one is fitted in a Cessna...I might take the bother to switch them. By the way, The AW is a kit build! torbjørn Edited By torbjornp on 14/02/2015 12:08:29 Quote Link to comment Share on other sites More sharing options...
Masher Posted February 14, 2015 Share Posted February 14, 2015 Hi tobjorn No I didn't cut the rear of the cowl but there is a slot which the manifold pipe fits through. The manifold pipe and silencer have to be removed before fitting the cowl and then there is just enough room to fit them and tighten back up when cowl is in situ. I also had an Acrowot kit previously and still have a homebuilt "Acrowot copy" - both of these fly perfectly well on OS 46 LA two strokes - perhaps I am just not a promoter of over powered models? To me the Acrowot's seem best flying nice big aeros at sensible speed, I have other models when I need speed. Quote Link to comment Share on other sites More sharing options...
torbjornp Posted February 14, 2015 Author Share Posted February 14, 2015 Finally😬, I can live with this... thank you all for useful tips! Torbjørn Quote Link to comment Share on other sites More sharing options...
Stevo Posted February 14, 2015 Share Posted February 14, 2015 Nice one Torbjørn! Cymaz has it here. I really wish I've used that method in the past... I can be so lazy at times... Quote Link to comment Share on other sites More sharing options...
Masher Posted February 14, 2015 Share Posted February 14, 2015 Yes that looks very good and you have better access to the glow plug than I have. Quote Link to comment Share on other sites More sharing options...
