Adrian Smith 1 Posted August 3, 2015 Share Posted August 3, 2015 I have occassion to use these springs supplied with kits on the tail wheel assembly. However, doing an 'tinernet' search I can only find ones without the "tails" at each end and they are mostly too big. Any ideas where I can get them? Thanks. Edited By Adrian Smith 1 on 03/08/2015 09:10:59 Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 3, 2015 Share Posted August 3, 2015 Good question Adrian, I could do with finding a source for them too Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted August 3, 2015 Share Posted August 3, 2015 Don't know where to buy them, but this stuff works just as well, it's elastic used in pole fishing, comes in different thickness and strengths, secure knots with cyano, and it comes in pretty colours John Quote Link to comment Share on other sites More sharing options...
bert baker Posted August 3, 2015 Share Posted August 3, 2015 Tension springs,are the type they are for pulling stuff together, ,,,,,,,,,,,compression spring are for pushing stuff apart. Available on internet and workshop consumables traders, and most model Engineering shops. Quote Link to comment Share on other sites More sharing options...
Wingman Posted August 3, 2015 Share Posted August 3, 2015 Try Lee Springs - great for all things springy. Just for a check I put in a search for wire dia 0.25mm by 3mm spring dia and got 76 hits - cost £10.95 for 5 for the biggest one. Quote Link to comment Share on other sites More sharing options...
Colin Bernard Posted August 3, 2015 Share Posted August 3, 2015 I found these in my local Maplins - very useful! Quote Link to comment Share on other sites More sharing options...
Tomtom39 Posted August 3, 2015 Share Posted August 3, 2015 Excellent Colin. Just what I was looking for. Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted August 3, 2015 Author Share Posted August 3, 2015 Food for thought there thanks. I should be able to find something there hopefully. Quote Link to comment Share on other sites More sharing options...
Martyn K Posted August 3, 2015 Share Posted August 3, 2015 I used to make these all the time. You need some 26g (approx) stainless steel rigging wire from a model yacht supplier - try Graham Bantock, Housemartin Sails, KBITS Simply wind using a 3mm drill bit or a length of brass tube as a mandrel. If you have a variable speed pillar drill and can slow it right down then you can wind them under power but it's not necessary They are very easy to make. Piano wire doesn't work as its too hard Martyn Edit. Make sure you are wearing gloves and have eye protection.. Edited By Martyn K on 03/08/2015 17:40:50 Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted August 3, 2015 Author Share Posted August 3, 2015 Bert I appreciate your comment, but I have tried to search using the criteria you mention, but to no avail so any suggestions as to which website to go to? Thanks. Quote Link to comment Share on other sites More sharing options...
Matt Jones Posted August 3, 2015 Share Posted August 3, 2015 Adrian, what size do you need, I may have something....... Quote Link to comment Share on other sites More sharing options...
bert baker Posted August 3, 2015 Share Posted August 3, 2015 maidstone-engineering.com Look under the fittings section near the bottom Edited By bert baker on 03/08/2015 19:38:18 Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted August 4, 2015 Author Share Posted August 4, 2015 Thanks for your offer Matt, but I think I have something in an assortment box on Amazon. We'll see. Quote Link to comment Share on other sites More sharing options...
