What are these springs called and where can I get them?
I used to make these all the time. You need some 26g (approx) stainless steel rigging wire from a model yacht supplier - try Graham Bantock, Housemartin Sails, KBITS
Simply wind using a 3mm drill bit or a length of brass tube as a mandrel. If you have a variable speed pillar drill and can slow it right down then you can wind them under power but it's not necessary
They are very easy to make. Piano wire doesn't work as its too hard
Martyn
Edit. Make sure you are wearing gloves and have eye protection..
Edited By Martyn K on 03/08/2015 17:40:50
