Devcon1 Posted February 11, 2016 Author Share Posted February 11, 2016 Great picture Peter. What model is it ?As an aside do you know what difference there is in effect between flaps externally hinge that create a big gap and sealed hinges with no gap at all.Regards John Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 11, 2016 Share Posted February 11, 2016 By the way. I thought that you might like to see a rare sight. My bench in a tidey state. Well, I am about to start building the wings. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 11, 2016 Share Posted February 11, 2016 Posted by John Milne on 11/02/2016 11:38:12: Great picture Peter. What model is it ? As an aside do you know what difference there is in effect between flaps externally hinge that create a big gap and sealed hinges with no gap at all. Regards John The model is the Aerolab USA LOcamp. An Italian desinged kit plane that is being manufactured in the USA Slotted flaps produce more lift and less drag, The slot guides the air flow over the flap and helps prevent it graking away from the top surface. Slotted ailerons work in the same way which means that they work well at lower speeds. I expect some aerodynmic expert will pull this to pieces but that is what I was taught. Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 11, 2016 Author Share Posted February 11, 2016 That's what I do when I embark on a different part , or between builds, I guess that's where the phrase " clear the decks" comes from.What's the current project ? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 11, 2016 Share Posted February 11, 2016 It is a development that started life as a control line model, then as a .25 powered model and now will be a bigger and slower model powered by a .52 four stroke. This is Super Marauder FS Actually the photo is the .25 sized model that was originally in AMI Edited By Peter Miller on 11/02/2016 12:12:25 Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 12, 2016 Author Share Posted February 12, 2016 Having trouble posting pictures. After I've selected my files and started the upload it just hangs there forever, both from a tablet and also my phone. Nothings changed, the photos are JPG and the same as all my others Is it me. I did wonder if there was a storage limit maybe but I get no warning or error messages.John Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted February 12, 2016 Share Posted February 12, 2016 I have the same problem with my home broadband but if I upload them through my phones 4G connection they fly through! Must be something to do with upload speed/ capacity. Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 13, 2016 Author Share Posted February 13, 2016 Thanks Chris. It was odd because some sites worked but very slowly, others not at all and some OK. I don't know why but by switching off the router and back on again its fixed. So, engine mount done and motor selected, I'll use an Overlander Thumper 2836/08 on 3 cells. Version 1 motor mount. Version 2 Thrust lines are exactly as per plan. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 13, 2016 Share Posted February 13, 2016 Very good John Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted February 13, 2016 Share Posted February 13, 2016 Yep, version 2 looks a lot happier. Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 13, 2016 Author Share Posted February 13, 2016 The observant ones out there will notice which face is looking forward 😁 Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 13, 2016 Author Share Posted February 13, 2016 Getting to the fine tuning aspects. I didn't have s spinner in stock so have resorted to a blunt front end so I utilised some mesh left over from my Dawn Flyer build. I made a lamination of balsa, mesh and ply. The mesh is car body aluminium repair mesh from Halfords. To aid motor/speed controller cooling I've added an Me 109 air inlet. I think I'll thin down the intake a bit to make it more scale. This is the notch in the fuselage to accept the flaps. Guess where the poor little thing will break its back when I mistreat it. Edited By John Milne on 13/02/2016 21:33:48 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 13, 2016 Share Posted February 13, 2016 Nice looking prop, they any good ? John Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted February 13, 2016 Share Posted February 13, 2016 And why is the angry face looking forward? Has he seen your other landings? Quote Link to comment Share on other sites More sharing options...
AndyD Posted February 13, 2016 Share Posted February 13, 2016 love the mesh(and the faces) why cant i think of these things,prob because i rush about to much,looking good. Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 13, 2016 Author Share Posted February 13, 2016 Don't know how efficient they are John but they were cheap, look nice, in stock and flew the Dawn Flyer OK.Well spotted Chris, landings are usually OK it what happens in the air would be the worry. Much of this build has been fairly fluid AndyD, as Peter has done the hard work coming up with a lovely structure/shape to play with.John Quote Link to comment Share on other sites More sharing options...
Chris Barlow Posted February 13, 2016 Share Posted February 13, 2016 That prop is rather nice! I have just tried a Just Engines wood 12x6 on mine but the hole is a little too big for the .52 FS. Might have to look on HK for a display prop now! Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted February 13, 2016 Share Posted February 13, 2016 Posted by john stones 1 on 13/02/2016 21:38:06: Nice looking prop, they any good ? John I tested, for another plane, the 13x8 in that series. It drew as much current as an APC 14x10E, but ran at 500 rpm less at full throttle. Much less thrust also. So my verdict is not good for flying, but nice looking on the ground. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 14, 2016 Share Posted February 14, 2016 That front view looks a little like a Jenny (Curtiss) Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 14, 2016 Author Share Posted February 14, 2016 I see what you mean. Had to go for a quick fly this morning on Dartmoor. A bit cold, blustery but good fun. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 14, 2016 Share Posted February 14, 2016 No there is a young man...or at least a lot younger than I am!!! Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 14, 2016 Author Share Posted February 14, 2016 I did cheat and drove up there. I have a kit, sort of Whilst I have no target weight in mind the airframe as seen is 329 gramms. Rear fairings put on a diet. Woodwork pretty much done now, I'll have a go at its legs tomorrow. For a light filler I mix balsa dust, wood glue and a little water. Resuse recycle etc Quote Link to comment Share on other sites More sharing options...
AndyD Posted February 14, 2016 Share Posted February 14, 2016 thats just gorgeous John enough said. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 15, 2016 Share Posted February 15, 2016 I very nearly bought a G-Mark 12 twin on Ebay just to build a small Ballerina. Luckily I just missed it although it went for a very sensible £62. Can't really afford such things on a whim. Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted February 15, 2016 Author Share Posted February 15, 2016 That sounds like a good price. Do they run well or are they more a collectors piece ? Quote Link to comment Share on other sites More sharing options...
