Peter Miller Posted September 13, 2017 Author Share Posted September 13, 2017 Your local office supply shop or EBay which is cheaper Quote Link to comment Share on other sites More sharing options...
Focae Posted September 14, 2017 Share Posted September 14, 2017 Posted by Peter Miller on 13/09/2017 19:48:55: Your local office supply shop or EBay which is cheaper Thanks Peter, the shortest I can see on eBay or Amazon is 11mm which I guess will do just fine. In wildest Cornwall on holiday so I will look at a stationers when I get home. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted September 14, 2017 Share Posted September 14, 2017 I will be building one. A couple of modifications I will make, one, a fit a bigger engine, a OS 70FS or a SC 61 four stroke, as this has a smaller case and using two mini servos for the ailerons and not a dated single servo and push-rod/bell crank assembly - gives better resolution, mixing and redundancy - also helps to use one of my many spare mini servos up. Might get the woodpack this time, as although like cutting the ribs out, it takes ages. Does SLEC do one now? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted September 15, 2017 Author Share Posted September 15, 2017 Posted by Focae on 14/09/2017 19:23:26: Posted by Peter Miller on 13/09/2017 19:48:55: Your local office supply shop or EBay which is cheaper Thanks Peter, the shortest I can see on eBay or Amazon is 11mm which I guess will do just fine. In wildest Cornwall on holiday so I will look at a stationers when I get home. Sorry, I looked at mine an realised that they were longer than 6 mm. 11 mm will be about right. I use diagonal cutters to get them out but sometimes the head comes of. The diagonal cutters can grip the bit of pin left to pull it out. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted September 15, 2017 Author Share Posted September 15, 2017 Posted by Paul Marsh on 14/09/2017 21:30:13: I will be building one. A couple of modifications I will make, one, a fit a bigger engine, a OS 70FS or a SC 61 four stroke, as this has a smaller case and using two mini servos for the ailerons and not a dated single servo and push-rod/bell crank assembly - gives better resolution, mixing and redundancy - also helps to use one of my many spare mini servos up. Might get the woodpack this time, as although like cutting the ribs out, it takes ages. Does SLEC do one now? Ye Gods, the man is power mad Well it does look like a racer.. I find that my reactions have slowed down so the slower models are easier for me to fly. SLEC cut a set for me so I know that they can do them for you. I am not sure if the have updated the set for the RCM&E plan but the only difference is the R-2 should be made from liteply. The rferason for that is that on my model I had the undercarriage plug in against R-1 which is under the planking as I realised too late. By moving it out as per the magazine plane it is clear of the planking. I did mention it to a chap at SLEC but not sure if they will have had time to change that. Yes,I am dated but I don't care. I like the servo that way. Edited By Peter Miller on 15/09/2017 08:26:23 Quote Link to comment Share on other sites More sharing options...
robert morley Posted December 21, 2017 Share Posted December 21, 2017 Hello I have built the harmony ,very good Indeed,I love the look of the destiny but thinking it was also a fast lander,.thi king of flap mix on alerons or cut out for flaps inwards.also I have a saito .81 gold knight will that be ridiculous to use,thoughts please?and merry xmas Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted August 17, 2018 Share Posted August 17, 2018 Just building the wing from the free plan. I cut the ribs from the templates on the plan, and, unless I've misread something, R10 is seriously undersize. Anyone else had this issue? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 17, 2018 Author Share Posted August 17, 2018 It is possible. I did check the plans by laying my tracing pf the top of the plans but it is possible that I maissed that rib. I will doube check it. If you PM me you email address I will send you the original PDF of my own drawing. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 17, 2018 Author Share Posted August 17, 2018 Hi Trevor. MIssed that mistake. I have PMed you and can send you a scan of my original Compufoil print out on an A4 page of that rib. Anyonex alse who wants a copy. please PM your email address Edited By Peter Miller on 17/08/2018 11:01:02 Quote Link to comment Share on other sites More sharing options...
SR 71 Posted August 17, 2018 Share Posted August 17, 2018 Lovely model,bean the plans be bought from somewhere, Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 17, 2018 Author Share Posted August 17, 2018 I am not sure if Sarik Hobbies have taken them on. If no one has I can supply my orginal PDF files. I know that Slec can cut out the parts because they cut mine for me. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 17, 2018 Author Share Posted August 17, 2018 I have done a sexarch and no one does them at the moment. I can supply PFFs of my own plan In future SLEC will beselling my own version of the plan and in five or six weeks they will be cutting kits to MY plan Quote Link to comment Share on other sites More sharing options...
SR 71 Posted August 17, 2018 Share Posted August 17, 2018 Thanks Peter there is no rush I have 1/4 scale F104 Star Fighter to finish first, I'll contact Slec later Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 17, 2018 Author Share Posted August 17, 2018 Actually. I have to wait until I find out if Sarik have bought the plan or not, so don't hold your breath. Graham Asby is checking up first Edited By Peter Miller on 17/08/2018 17:16:34 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted June 3, 2021 Author Share Posted June 3, 2021 I have now converted Destiny to electric power. I used the motor and ESC etc as specified by 4-Max. The first take off was terrifying. Straight into a vertical climb that just went on UP. I must admit that I was shaken. I added 6 ounces of lead in the nose plus a small belly intake for the ESC Today it was much more civilised and performed aerobatics beautifully. Not as wild as some of my designs but much more like precision Manouvres. The power was much better than on the original OS FS40 Surpass. Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted June 3, 2021 Share Posted June 3, 2021 She is beautiful Peter. Not too sure how I missed her. My son built your Harmony which he enjoyed, and I am still flying your lazer cut prototype Nieuport which went in the magazine. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted June 3, 2021 Author Share Posted June 3, 2021 Hi Andy. Glad that your son liked Harmony, one of the series. I have never done a Nieuport of any type, Sorry!!! Quote Link to comment Share on other sites More sharing options...
Graham Davies 3 Posted June 3, 2021 Share Posted June 3, 2021 Hi Peter, good to hear the second (re) maiden went well. I have to say, Destiny is one of the nicest sports models I've ever seen. I'm feeling the urge to plank... Graham Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted June 4, 2021 Author Share Posted June 4, 2021 Thanks Graham I have to say that it is one of, no, is THE nicest that I have ever designed. It takes a lot of time and patience but is worth the effort. It flies in a very steady way but responds instantly and smoothly to the controls Yesterday I was going multiple vertical rolls. I have the PDF files of the drawings and SLEC cut out my parts so that makes life easier for anyone who wants to build it. Quote Link to comment Share on other sites More sharing options...
Graham Davies 3 Posted June 4, 2021 Share Posted June 4, 2021 Sorely tempted Peter. I'm enjoying building the Harmony wing, so I'm already softened up... One question; does your pilot have an older sister? Graham Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted June 4, 2021 Author Share Posted June 4, 2021 Not that I know of! I can tell you that the pilot is modified from a couple of normal pilots and I was wandering round the toy departments in Sudbury with a vernier caliper to find the right hair!! Quote Link to comment Share on other sites More sharing options...
Graham Davies 3 Posted June 4, 2021 Share Posted June 4, 2021 A similar activity got me a restraining order! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted June 4, 2021 Author Share Posted June 4, 2021 I had not thought of that risk!! Ah well, I was cleared to work with children when I worked at an Upper School. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 29, 2021 Author Share Posted July 29, 2021 For those who want it electric. 4Max have the suggested power set up. It is more powerful that=n the OS and I can now do consecutive vertical rolls, Quote Link to comment Share on other sites More sharing options...
