cymaz Posted March 20, 2017 Share Posted March 20, 2017 I blew up the picture. If I'm not mistaken the ailerons can just be seen right to the tips. We are agreed! Go for it DD ,,, G-EBLV. She's a beaut. Edited By cymaz on 20/03/2017 18:31:23 Quote Link to comment Share on other sites More sharing options...
Chris Whalley Posted March 20, 2017 Share Posted March 20, 2017 Ref your aileron conundrum, full size go all the way to the tips, that's the way I did my DB cyrus moth, they were fairly easy to do. Yours is looking good keep up the good work Regards Chris Whalley Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 20, 2017 Author Share Posted March 20, 2017 Cheers Chaps, it's decided then !! They will go right to the end, just a bit of ferkeling to do with a bit of scrap and a razor saw. Good pics there Cymaz, especially of the engine McG, the plan shows where they begin, as you say, 4 or 5 ribs from the root, but the discrepancy was where they end, I think the model on the D.B. box was done the easy way, with the tips intact. Thanks every one for your help and guidance. I have now built 2 port wings. I thought it was easier to do this than 2 lower and then 2 upper, as I don't have to swap the plan about too much. Pics in a bit. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 20, 2017 Author Share Posted March 20, 2017 The bottom port wing, you can see a line where the wing will be trimmed on the trailing edge. I still have to add the strut fixing blocks and the servo boxes. you can also see the Shear webbing in alternate bays. In this pic you can see where the tip will be cut so it will be part of the aileron, in between the tip brace and the T/E sheeting, just about where my index finger is.... I hope I move it in time.... These pieces were supplied to fit against the root rib to give a "ledge" to aid covering but they were too short.....good old scrap bin came to the rescue. The tip braces, and the " under camber" of the wing tip. The root reinforcement on the upper port wing, needed as the root rib is to be cut off at the line I have drawn. Edited By Dwain Dibley. on 20/03/2017 22:43:07 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 21, 2017 Author Share Posted March 21, 2017 I managed a bit more before I went to work, but ran out of posting time. So here is the progress for today. I now have two wings built bar the members for the struts and the servo boxes. I have cut the wings to shape at the root, as per the plan, this I did by drawing a line freehand with the upper wing over the plan, then cutting outside the line and sanding back, the lower wing was a straight line cut, so a steel ruler and a knife sorted that. The tips are easier as they are both the same top and bottom. I cut two riblets to make the aileron end nearest the root, I used a ply spacer, so that I have a space to cut into. I will build the two starboard wings before I remove the ailerons, that way nothing will get lost or broken. To be fair, the wings went together really quickly, and everything was a good fit. I noticed that the leading edge has to be left quite sharp, and not the usual rounded profile. I have a major distraction now, in the form of a BF110 from you know who ? Must resist....MUST RESIST !! D.D. the riblet and spacer The upper wing cut to shape the other scrap piece if from the tip. The lower wing cut. Riblets. The top one is the correct length, plus a sanding margin of course. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 23, 2017 Author Share Posted March 23, 2017 After a visit to the blood Nurse, who insisted on emptying my right arm, to see if I am in good nick for my age, I managed to do a bit on the Moth. I had already done a dry fit of the lower middle section, so I knew what was what. Before I could glue it up, I had to cut the fat slot for the under cart wire bearer. I have done a loverly pictoral "how to" for you. I made sure everything was square. I left the undercart bearer very slightly proud so it can be sanded to the profile of the ribs. There are some strengthening Trailing edge pieces in the... er....trailing edge..where the wing bolts will go through. I made sure these were flooded with Aliphatic so that when I pushed them in the glue flowed out, hopefully this has filled all the gaps and will be as solid as rock. The pieces pre cut by me. Installed. One complete lower mid section. Also, behind the shear web you can see, is a spar filler piece, this was not on the plan but was in the book of words. Piece No' 245. If you are wondering. Last job will be to cut in the dihedral braces once the starboard wings are built. Oh and the dowells to locate the wing in the former. D.D. Edited By Dwain Dibley. on 23/03/2017 11:27:39 Quote Link to comment Share on other sites More sharing options...
cymaz Posted March 23, 2017 Share Posted March 23, 2017 Coming on leaps and bounds now ! Quote Link to comment Share on other sites More sharing options...
Geoff S Posted March 23, 2017 Share Posted March 23, 2017 Posted by cymaz on 23/03/2017 12:41:53: Coming on leaps and bounds now ! ... but hopefully not when landing It's certainly coming together quickly and I'll be re-reading it all together with drawings when I get to building mine in the next month or two. My building progress (on the Mew Gull) has been slightly delayed by work on SWMBO's bike - new transmission components and electrification (she didn't fancy a glow engine ). Geoff Quote Link to comment Share on other sites More sharing options...
cymaz Posted March 23, 2017 Share Posted March 23, 2017 Posted by Geoff Sleath on 23/03/2017 16:52:03: Posted by cymaz on 23/03/2017 12:41:53: Coming on leaps and bounds now ! ... but hopefully not when landing It's certainly coming together quickly and I'll be re-reading it all together with drawings when I get to building mine in the next month or two. My building progress (on the Mew Gull) has been slightly delayed by work on SWMBO's bike - new transmission components and electrification (she didn't fancy a glow engine ). Geoff You could take off the chain and pedals off, explain to her that it now a free flight model........now waiting for the telling off! Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted March 23, 2017 Share Posted March 23, 2017 Good heavens D.D you've got a rib tickler I've not seen one of those in years. Coming along beautifully. I bet you have opened the box of your 110 just to have a peek inside, that's when they start calling you and before you know it the plans are out and the distraction starts. You must resist be strong. Regards Robert Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 23, 2017 Author Share Posted March 23, 2017 But the force is strong in this one Robert !!! I can hear her calling me, even now..... D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 24, 2017 Author Share Posted March 24, 2017 A pile of wings...... Just an upper center section to go. Work again tomorrow, Flippin' Open Day...it interferes with my hobby, it's not on you know !!! D.D. I forgot to make the servo lead holes on the first wing, but remembered on this one... Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 25, 2017 Share Posted March 25, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 25, 2017 Author Share Posted March 25, 2017 Hi Percy, I'm gonna make card tubes, so should add strength back Matey, but I forgot, in my eagerness, to do the lower port wing.... thinking cap on now to try and figure it out as access is a bit tight. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 25, 2017 Author Share Posted March 25, 2017 Like so ....will be better than this, just did this quickly to give you an idea. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 25, 2017 Author Share Posted March 25, 2017 Well, aint it funny how things go...?? Old Percy Verance there, made a comment, and it set me to thinking about getting the holes in the other wing... So I went into the workshop to have a look, hoping for inspiration. I spotted my hole saw kit and low and behold in there was a cutter the exact same size as the holes I had cut in the starboard wing,......I couldn't get my cap on Boys... This is the result, using a 10mm socket, and three extensions on the end of the hole cutter. Oh and a bit of insulation tape.. I did it by hand turning the cutter anti clockwise....... Let it be known throughout the land, that Sir Percy Verance is a Hero. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 26, 2017 Author Share Posted March 26, 2017 Today I have managed to get the center section of the top wing done. The hardest part was lining up the bolt liners and getting them fixed in. In the end I laminated some balsa to the size of the space where the liner was to go, drilled through it and then sanded to size, making sure the liner was over the captive nut, then glued the brass liner in. Luckily it all lined up. I will have to make some offset washers to neaten it all up, or bury the bolt heads. I cut all the wings to shape and did a bit of sanding, there is plenty more sanding to do tho. I have to glue in the ply bearer that holds the top wing on, and locate the holes for the bottom wing fixing and add the dowels for the same. The dry fit showed that all the panels line up pretty good and the dihedral is more or less there. I still have to cut the dihedral braces into the wings, starting with the center sections. The box is now empty and I can get the "other" box on the bench. D.D. Oh yeah, I added a ply doubler at the back for a bit of strength. Top section in place. Top Center all covered up. 2 Wings. 4 Wings. Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 27, 2017 Share Posted March 27, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 27, 2017 Author Share Posted March 27, 2017 Just thought I'd give you Kudos for getting my brain in gear Percy.. This is all I did this morning, apart from sanding and shaping...............and more sanding........ D.D. Edited By Dwain Dibley. on 27/03/2017 23:27:22 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 29, 2017 Author Share Posted March 29, 2017 This morning I made the servo covers and the gubbins to screw them to. I start by cutting a piece of lite ply to the size of the bay. To get the size, simply trace round the inside of the bay straight onto the ply. Lite ply cuts with a blade nice and easy, no need for a saw. Then I put a piece of clear plastic over the ply and place the wing on top, so the ply is where it will be eventually fixed. Next I make a frame around the bay with off cuts of balsa from the scrap bin, and glue them in. The plastic stops them sticking to the lite ply cover but the cover keeps the frame at the right "height", so the cover remains flush with the wing surface. Next I cut some triangular lite ply fillets to take the cover fixing screws. since the pic was taken I have increased their thickness X 3. While the whole lot was still on the bench, I drilled pilot holes for the screws. The last job was to plane and sand the cover so that it is totally flush with the bottom of the wing. A hole for the servo arm will be cut and the servo fitted with blocks and/or tape and glue. D.D. Cover marked up so we get it in the right way round, and the arm hole drawn on for future reference. As you can see there is not much room for standard servos. The cover in place and the servo where it will be sitting. The cover all flush and holes drilled. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted March 29, 2017 Author Share Posted March 29, 2017 Just a pic of the plastic trick, to show you guys....I am sure someone else posted this tip before, so kudos to them, can't remember where I saw it tho. It does allow for a very neat installation though. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 3, 2017 Author Share Posted April 3, 2017 Whilst I have been over on the 110 thread I have had the four dihedral braces soaked and under some weight, trying to flatten them out....You will be pleased to know that it worked and they can now be cut into the center sections. the only thing that lets DB kits down is sometimes the ply is bendy. Once that is done, I can join the wings. Happy Days. D.D. Edited By Dwain Dibley. on 03/04/2017 00:54:03 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 13, 2017 Author Share Posted April 13, 2017 By way of a diversion from chores and the planing and sanding on the 110, i thought I would get the Dihedral braces chopped into the wings on the Moth. the braces have stayed nice and straight so here we go. D.D. The Bottom middle section. The Top wing all together, but just held with clamps.to check the fit. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 13, 2017 Author Share Posted April 13, 2017 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 13, 2017 Author Share Posted April 13, 2017 Gluing up and making sure the braces are straight and true. D.D. Quote Link to comment Share on other sites More sharing options...
