Dwain Dibley. Posted April 17, 2017 Author Share Posted April 17, 2017 He used to fly my Extra 330, and never once spilled a drop of tea. Today I have been sticking sticks, and this is the result of my labours, and it was a laborious task I can tell you. !! D.D. First you need a really bendy ruler to draw some lines round some corners. I added the main ribs first then marked up the spacing, in this case it was 20mm, dunno if this is to scale, but it's only for effect. I then decided to have a go at fitting the struts, they still have to be shaped, and the pins glued in, and all set up but they look OK, and the wings sit well. Happy Campers at Dibley Towers. Edited By Dwain Dibley. on 17/04/2017 14:53:22 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 17, 2017 Author Share Posted April 17, 2017 Tail feathers all sanded to shape and hinged up..Ready for covering. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 17, 2017 Share Posted April 17, 2017 Err...the other end ? Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 17, 2017 Author Share Posted April 17, 2017 I couldn't reach matey, too much in the work shop....... D.D. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted April 17, 2017 Share Posted April 17, 2017 I hadn't realised the Cirrus Moth kit had a full D section wing l/e. The Tiggie is all open structure but this will make for a much stiffer wing. Your idea of glueing strip on the l/e sheeting to simulate an open structure I may steal. You have, of course done the same on the underside just as I'm sure you're going to apply simulated rib stitching to both upper and lower surfaces Geoff Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 17, 2017 Share Posted April 17, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 17, 2017 Author Share Posted April 17, 2017 Percy is correct Geoff, the underside is not sheeted, I have tried to simulate the riblets, as seen from above. I have sanded the strips down quite a lot to avoid that very scenario Percy, should look quite scale like....hopefully.. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 17, 2017 Author Share Posted April 17, 2017 That would be 96 riblets to make Percy.....And after all the model is only stand off scale, how far we will have to stand away remains to be seen.. D.D. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 18, 2017 Share Posted April 18, 2017 Interesting that the Cirrus Moth didn't have anti stall strips on the top wing but the Gipsy Moth did. I wonder why that was? Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 20, 2017 Author Share Posted April 20, 2017 I have no clue Cymaz, but I may endeavor to find out at some point. I have seen images with the appendages. Meanwhile, I have been playing with servos and building the boxes for them to sit in. I also bought some things, that arrived today, this may give the Colour scheme away tho. Standard servos are a bit tight in the wing but they do go in. I couldn't help it so I had to do a bit of covering. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 21, 2017 Author Share Posted April 21, 2017 It's just more covering, but it has to be done, next up will be the ailerons, and then the wings, and then the Fuselage, and then some paint, and then some detailing. D.D. The cutting up of bits. The laying down of the bits. What the bits is gonna end up like. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 22, 2017 Author Share Posted April 22, 2017 The numbers are burnt in quite deep in the balsa parts, and will show through certain coverings, to blind this I ironed patches of the same film over them before the main covering went on. This worked a treat and is invisible on the finished job. D.D. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 22, 2017 Share Posted April 22, 2017 That is going to look very smart. How will you do the black edging detail.? Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 22, 2017 Share Posted April 22, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Geoff S Posted April 22, 2017 Share Posted April 22, 2017 Posted by cymaz on 18/04/2017 06:18:35: Interesting that the Cirrus Moth didn't have anti stall strips on the top wing but the Gipsy Moth did. I wonder why that was? I think those anti-stall strips were invented by Handley Page. The HP42 airliner flown by Ian Redshaw has them and they work totally automatically. Ian initially fitted servos but IIRC found them unnecessary in practice as the strips lift as airflow over the wing reduces. Not exactly sure why but Ian says they actually do work. Like the anti-spin strakes, they're only fitted to some Tiger Moths but they are very simple in operation but perhaps not so simple to add. The scheme looks great DD and should show up well. For contrasting lines I use the Solartrim strips available in several colours and widths ready cut. It goes round gentle curves quite well and stays on mostly. Geoff Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted April 22, 2017 Share Posted April 22, 2017 Those are Handley Page Slats. Developed by HP in response to a competition set up by Guggenheim to make aeroplanes safer. They produced the HP39 Gugnunc that featured these high lift devices. Powered by an Armstrong Siddeley Mongoose, it had a stalling speed of only 33 mph and could take off in a very short run, with a steep climb-out and not stall. I have never seen it modelled, but it looks like a good candidate. The original still exists in the Science Museum. Not wishing to divert the thread, but in view of the interest, here it is. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 22, 2017 Share Posted April 22, 2017 A diversion , yes, but excellent and informative nevertheless ! Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 22, 2017 Author Share Posted April 22, 2017 Yes..A nice diversion away from the endless covering..... I intend to hand paint the black parts, but I have also considered the Solartrim idea, if the paint route gets aborted. More covering has been achieved this evening, as I will be aviary building again tomorrow. D.D. This pic shows up the dummy riblet effect quite well. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 23, 2017 Share Posted April 23, 2017 If you intend to paint the black edging on then beware of bleeding. Doing a bit of reading up, paint the edge to be painted first with the same colour as the covering. Then mask off with blue lining tape and paint in the black. The base coat will stop bleed through under the tape. A bit of testing on scrap woul be a wise move to avoid a disaster Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 23, 2017 Share Posted April 23, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Geoff S Posted April 23, 2017 Share Posted April 23, 2017 Actually a little bleeding isn't too much of a disaster if you're covering a model red. In this case however ... I admire your energy, Dwain, but as far as I'm concerned aviary building is strictly for the birds. Geoff PS Very impressed with your dummy riblets. They'll really help to bring the model alive. That's an idea I will almost certainly steal. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 23, 2017 Author Share Posted April 23, 2017 I normally hand paint my models, with warbirds paints, I still have some black, also some German Yellow, which will come in for the 110. You are welcome to copy/steal Geoff, We spent a Happy 5 hours building in my sons Garden. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 23, 2017 Author Share Posted April 23, 2017 The Bird House, was straight forward, no one got in a flap, I think the end result is something to Crow about, a feather in ones cap so to speak ?? My wood butchering skills haven't gone to seed just yet. D.D. Some holes for the tweety birds to fly through. Quote Link to comment Share on other sites More sharing options...
