Dwain Dibley. Posted April 26, 2017 Author Share Posted April 26, 2017 Some more covering......................Zzzzzzzzzzzzzzzzzzzzz..... B.T.W. there are three Yellows in the Solartex range, Cub, antique, and just yellow. Antique yellow is darker than yellow but lighter than cub yellow, so I went with yellow. D.D. Bottom. Servo covers. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 27, 2017 Author Share Posted April 27, 2017 Servo covers turned out to be a pretty good fit. Just one wing to go and two fuz sides.................Phewww !! D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 29, 2017 Author Share Posted April 29, 2017 No wings to go and just half fuz sides to go, I remembered just in time to put a nice fillet on the bottom wing seat, and to neaten up the edges of the rudder exit holes.....Phew again.....!! The fillet is sanded back to the profile of the wing, actually, to nothing at the T/E. Wrapped the U/C in foam to stop it crushing the new fillet, as per a suggestion by someone earlier in the thread. I will cover the fillet and then the sides to make a nice neat job. Had to work today, had three powercuts, Thanks local authorities, I only had 13 blocks to reset both intruder and fire each time, plus boilers and DHW. Tomorrow it's mothers facia board in plastic, and finish the aviary.................is there no respite............ D.D. Edited By Dwain Dibley. on 29/04/2017 22:39:41 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 30, 2017 Author Share Posted April 30, 2017 It's coming along nicely, with some help from the nipper.... Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 1, 2017 Author Share Posted May 1, 2017 A bit more progress. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 1, 2017 Author Share Posted May 1, 2017 I have made the dummy tank skin. I made it from corrugated cardboard, which I wet with water and let hang over the top wing center. Once it had contoured itself I gave it a blast with the heat gun, which set it. I then soaked it with CA and it ended up as hard as a "Bibble". Next I stuck it down with Aliphatic glue and pinned it. I will get some pics later. I was unable to get them at the time, as there was a crisis with the Candy Floss machine...............!! YES.....You heard me correctly. Next up is a bit of Black paint, or could be rib tapes, or I might even glue the Tail Plane on. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 1, 2017 Author Share Posted May 1, 2017 A bit more................... I think I will paint the tank silver to simulate metal ?? This is the underside ready to go, as you can see the CA makes it look like an old roof sheet. Top side on the wing, pinned and glued. tore a strip off and made rib tapes, I didn't simulate the stitching. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 4, 2017 Author Share Posted May 4, 2017 Today I have installed the servos in the wing and made the rods, installed the snake inner in the fuselage and the servo tray and the rudder mechanism. also the tail is glued on, I used Epoxy for that job, but I used CA to glue the vertical stab into the horizontal stab. All the surfaces are attached now too. D.D. Edited By Dwain Dibley. on 04/05/2017 19:31:38 Quote Link to comment Share on other sites More sharing options...
Geoff S Posted May 4, 2017 Share Posted May 4, 2017 Dwain, wouldn't the fuel tank be painted to match the wings or fuselage? I know it is on G-ACDC Tiggie which is what mine is (vaguely) based on. I was lucky enough to find some corrugated card on eBay that was exactly the right shade of red and very inexpensive. I think it's intended for handicrafts etc. It's all looking very good. After falling on my Tiggie last week while carrying a heavy building board I've had to make a completely new tail assembly Not best pleased with my clumsy self. Just glad it's so windy I wouldn't be flying it anyway. Geoff Edited By Geoff Sleath on 04/05/2017 20:17:33 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 4, 2017 Author Share Posted May 4, 2017 That's unfortunate Geoff, but to a man of your calibre, the repair is simplicity itself. Don't be too hard on yourself Matey, we all do silly things now and again. The Tank is going to be black as per the scheme I have chosen, but my idea is to simulate metal by first applying the silver, then a black layer or two, which I will wipe, to give the appearance of a bit of age. Here is the scheme. Edited By Dwain Dibley. on 04/05/2017 21:53:14 Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 4, 2017 Share Posted May 4, 2017 Looking good Quote Link to comment Share on other sites More sharing options...
fly-navy Posted May 4, 2017 Share Posted May 4, 2017 Coming along nicely Mr D, about time you got those cables outside the fuselage Ouch Geoff, that's bad news. Wind, what wind !!!!!!!! Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 4, 2017 Author Share Posted May 4, 2017 Thanks Cymaz. That is the next job John, in fact I threaded the Swivels not half an hour ago. Gonna get them made ready for when the paint is done. How you been anyway, are you well ? D.D. Quote Link to comment Share on other sites More sharing options...
fly-navy Posted May 4, 2017 Share Posted May 4, 2017 I'm fine thanks Steve, hands are killing me right now though, had some more pills so wait for them to kick in. Girls well? Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 4, 2017 Author Share Posted May 4, 2017 yes thanks Growing up fast, taller than their mom and with twice as much Lip...... Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 11, 2017 Author Share Posted May 11, 2017 Some minor tinkering, cockpit detail added etc. D.D. The wood is for bracing and gluing purposes only. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 13, 2017 Author Share Posted May 13, 2017 I was in a painting mood today so I started on the fuselage and the cowl. I am using Warbird Colours black and doing it by hand. In between coats I use a hot air gun to dry the paint , this lets me apply multiple coats in double quick time. The pics show Four coats applied. D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 13, 2017 Author Share Posted May 13, 2017 I have also made a start on the Hub caps supplied by Richard at DB Sport and Scale. I have made a disk of balsa which sits inside the vac formed hubcap, the disk was sanded to a dome shape to get the maximum gluing area, and the glued with CA. I put it against the wheel and pushed the wheel onto the axle, thereby making a mark in the balsa, which I then reamed out with a 4 mm bit by hand, but not through the plastic. There should be enough room when the Collet is holding the wheel on, for the hubcap to be fixed to the wheel. I will paint these to match the colour scheme. D.D. Edited By Dwain Dibley. on 13/05/2017 13:58:44 Quote Link to comment Share on other sites More sharing options...
Geoff S Posted May 13, 2017 Share Posted May 13, 2017 Good idea to fit a balsa disc inside the hub to glue on the DB hub cap. I have the same wheels. I make balsa discs by using the 'scrap' from a hole saw cutting and that means there's a central hole ready cut. By hand painting, do you mean brush? I use Warbirds colours and it does brush quite well. I use a fairly expensive brush I bought in an art shop and clean it thoroughly under the tap after each use - the advantage of water based paint. Geoff Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 13, 2017 Author Share Posted May 13, 2017 Hi Geoff, Yes I have used brushes, like you, the best I can get, as they last a long time, and "wear in" nicely for cutting a nice straight line. I have added the Rudder lines. The guides being simulated with ball links from my heli spares box. I do the pull pull set up with the servos connected and the Tx on, to center the them. Obvious, but mentioned just in case some one has never done it before......... Also, I have painted the embossed lettering on the wheels, i will do the background black of course, to match the rest D.D. Front. Back. Middle. Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 13, 2017 Share Posted May 13, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 13, 2017 Author Share Posted May 13, 2017 Stop it Tom !!, how am I gonna replicate that ??? I have put some more paint on and fixed the fairings to the U/C legs. I added a backing piece the the fairings, so that the piano wire was fully enclosed. Painted Black to match. D.D. Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 13, 2017 Share Posted May 13, 2017 DD...look what I've found. Who's the owner? I looked it up. Page 108, construction number 1809 Edited By cymaz on 13/05/2017 22:26:36 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 13, 2017 Author Share Posted May 13, 2017 Excellent Cymaz, but long, I found this entry tho after a long trawl......of the reg I am duplicating. Cheers dood. Operated in UK under US regn until regd G-AAMY 2.5.80 to Cliff C & Mrs JM Lovell, Walkeridge Farm [later Coombe Bissett] D.D. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 13, 2017 Author Share Posted May 13, 2017 DH.60X [Cirrus III] regd G-AAMT [CofR 2169] 16.9.30 to National Flying Services Ltd, Hanworth. CofA 2789 issued 17.10.30. Operated by Nottingham Aero Club, Tollerton. Crashed Cotgrave, nr Nottingham 9.11.30; pilot Ronald L Wing killed. Regn cld 11.30 See the info at the bottom of the picture. My Daughters name is AMY, so you can see why I chose the reg. Edited By Dwain Dibley. on 13/05/2017 22:59:59 Edited By Dwain Dibley. on 13/05/2017 23:06:51 Quote Link to comment Share on other sites More sharing options...
