Denis Watkins Posted May 17, 2017 Share Posted May 17, 2017 Woops, I thought we were jamming 2.4 gig, which is pretty specific? Quote Link to comment Share on other sites More sharing options...
Keith Lomax Posted May 17, 2017 Share Posted May 17, 2017 The BBC short video on Guernsey's "drone fence" says "stops it and sends it back to where it came from". This would suggest that all it is doing is blocking the signal and relying on the failsafe being set to "return to home". If you set the failsafe on the other side of the prison, then the return home path will overfly the prison. Some sort of trigger to release the contraband mid flight (could just be a DT timer) would overcome this problem. Quote Link to comment Share on other sites More sharing options...
onetenor Posted May 17, 2017 Share Posted May 17, 2017 What I would like to know is what will happen when one of these contraptions goes out of control and injures or god forbid cause death one way or another. It is bound to happen I believe Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted May 17, 2017 Share Posted May 17, 2017 Can we stay on topic please. The topic is the NPA and its content. BEB Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 17, 2017 Author Share Posted May 17, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
GONZO Posted May 17, 2017 Share Posted May 17, 2017 Posted by Steve J on 17/05/2017 16:45:46: Posted by ChrisB on 13/05/2017 20:59:12: The key themes I'll be commenting on are: Registration Heights Geo-fencing CE Markings Registration of operators is a lost cause as EASA seem to see registration as a silver bullet. UAS.SPEC.20 allows the authorisation issued by the CAA to the model associations to include deviations from the registration requirements, so maybe association members won't have to register every UAS over 900g (c. 15 models in my case). There was mention of an exemption for models in the DfT consultation, so there is hope. I will be surprised if we don't end up with a general 400ft (120m) limit with higher altitudes only allowed at club sites. A 400ft limit was in the DfT consultation. EASA seem to have backed off on geofencing. It appears to be only required for class C2 and in designated zones. CE marking is not applicable to privately built. Electronic identification is top of my list. Mainly because they mention it a lot, but I am not aware of any specifications for what it is going to be and what it would cost to add it to a UAS. Steve The only electronic identification that would be small and light enough for our use and that gives the other information required ie height, speed, heading location etc is **LINK** **LINK** Along with other necessary extras like the aerial etc you could get a system down to under say 100gm. BUT, and it is a big But, look at the price of the two units at nearly £1600 then add the cost of other parts. A complete no go for general modellers. Edited By GONZO on 17/05/2017 17:50:56 Quote Link to comment Share on other sites More sharing options...
GONZO Posted May 17, 2017 Share Posted May 17, 2017 Constructive criticism would be more useful. I f not this then what? I would guess that any system would need to be 'type approved' by the aviation authorities(that's a cost multiplier) and have the major, if not all, the same attributes of the system I listed. The 10gm $10 unit that is sometimes referred too is not an existing real life entity. More an uneducated guess by some faceless Euro official of what maybe/could be(some chance!). Lets see your suggestion and don't forget it has to be able to be integrated with aviation protocols that the commercial drone traffic will be using. Quote Link to comment Share on other sites More sharing options...
GONZO Posted May 17, 2017 Share Posted May 17, 2017 Whatever the outcome on unit to be used you can bet 'your/mine/ anybody you care to name' life that it will not be cheep! My experience of GA flying and aviation in general tells me this is a reasonable assumption. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted May 17, 2017 Share Posted May 17, 2017 Apparently, only 10% of ultralights carry SSR Transponders and 35% of hot air balloons (and 0% of birds). I fail to see the urgency of UAVs carrying electronic identifiers. Quote Link to comment Share on other sites More sharing options...
XK50 Posted May 18, 2017 Share Posted May 18, 2017 Having read Parts A and B of the proposals, I read, finally, the covering note. With its "150kg" and "cross border operations", it does seem to support BEB's earlier assertions that this ain't really about model aircraft, nor even those naughty multi-rotors. It's seems to be about the commerce of fairly big things flying through the air, autonomously - Fedex and Uber for the skies! I reckon we model flyers are, currently, in the position of small dog-cart makers and users, circa 1896, who had little concept of the horseless carriages, the lorries and the charabancs, plus their required network of roads, autobahns, and garagistes that were about to hit them. This is going to be big .... very big. This will be the way the "millenniums" get their pensions paid. But, just like the Great Crested Newt, I suggest we model flyers will be alright, left in our designated areas. John Quote Link to comment Share on other sites More sharing options...
will -0 Posted May 18, 2017 Share Posted May 18, 2017 Exacactly. We don't need a lot of airspace, we just need to try to protect the bits we do use even if it's just once a year. Easy enough for club sites, but the bit of hill side that gets used once in a blue moon when the wind is in the right direction is not so obvious. Quote Link to comment Share on other sites More sharing options...
MattyB Posted May 19, 2017 Share Posted May 19, 2017 Still nothing from the BMFA on this one - I guess with all this rain they must be out mowing the grass at Buckminster... Edited By MattyB on 19/05/2017 16:02:49 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted May 19, 2017 Share Posted May 19, 2017 Posted by MattyB on 19/05/2017 16:02:13: Still nothing from the BMFA on this one - I guess with all this rain they must be out mowing the grass at Buckminster... Edited By MattyB on 19/05/2017 16:02:49 You didn't read this months BMFA news then? Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 19, 2017 Share Posted May 19, 2017 This may be of interest....if only to our American cousins. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted May 19, 2017 Share Posted May 19, 2017 This is not a place to make political statements regarding the benefits or otherwise of the EU. Once again, the topic is the NPA - not the EU, Mr Junkers, the French nation etc. etc. Off topic posts will be deleted. BEB Quote Link to comment Share on other sites More sharing options...
MattyB Posted May 20, 2017 Share Posted May 20, 2017 Posted by Frank Skilbeck on 19/05/2017 16:15:09: Posted by MattyB on 19/05/2017 16:02:13: Still nothing from the BMFA on this one - I guess with all this rain they must be out mowing the grass at Buckminster... Edited By MattyB on 19/05/2017 16:02:49 You didn't read this months BMFA news then? My copy has not arrived yet. What does it say? Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 20, 2017 Author Share Posted May 20, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
ChrisB Posted May 20, 2017 Share Posted May 20, 2017 The CAA will be able to regulate airspace as they do now and make their own decisions about heights and areas that flying can take place, hence the ability to delegate to a competent authority within member states. The CAA aren't stupid, they know that for decades all has been well with the world. Its only in the last few years that tings have changed...whats the variable? Multi-rota/drone aircraft and who are the people causing the problems...the toy brigade. All will be well Erfolg...the world won't end! Quote Link to comment Share on other sites More sharing options...
ChrisB Posted May 20, 2017 Share Posted May 20, 2017 Posted by Steve J on 20/05/2017 14:48:01: Posted by Erfolg on 20/05/2017 10:35:23: I will repeat, I do see this as the beginning of the end for aeromodelling as we know it as a hobby. A £5 registration scheme and either join a club or do some online training and a test is not "the beginning of the end for aeromodelling". Steve We do e-learning modules for work. rather than us all go over to the training centre we each spend an hour reading some basic facts and then answering some multiple choice questions. Simple! Quote Link to comment Share on other sites More sharing options...
MattyB Posted May 22, 2017 Share Posted May 22, 2017 Posted by ChrisB on 20/05/2017 10:52:46: The CAA will be able to regulate airspace as they do now and make their own decisions about heights and areas that flying can take place, hence the ability to delegate to a competent authority within member states. The CAA aren't stupid, they know that for decades all has been well with the world. Its only in the last few years that tings have changed...whats the variable? Multi-rota/drone aircraft and who are the people causing the problems...the toy brigade. All will be well Erfolg...the world won't end! Posted by Steve J on 20/05/2017 14:48:01: A £5 registration scheme and either join a club or do some online training and a test is not "the beginning of the end for aeromodelling". Steve My copy arrived on Saturday. Having had a read (it didn't take long; half a page tucked away near the back that sadly most will miss) it seems the BMFA have adopted a more conciliatory tone compared to their response to the prototype rules; based on their interpretation there does seem reason for cautious optimism. I think we are a long way from being in the clear though. On paper delegating that authority to the CAA (who have always seemed pragmatic and not overly worried when it comes to organised model flying) seems a good outcome for us. However I just cannot see the commercial interests involved who want access to that airspace below 400ft (Amazon, the logistics companies etc) supporting this approach. Allowing each country CA to negotiate and define it's own exception criteria for the rules with their local modelling associations will make the "U-Space" concept more costly and time consuming to legislate and implement; it would certainly make cross border operation far trickier. As a result I fully expect these organisations to put out lots of publicity and deploy employ expensive lobbying groups to set out why a top down, centralised approach across the EU with far less local variance is critical to the success of the commercial drone industry. It then becomes a political decision as to which way the EU/EASA want to go - problem is all the £££s are on one side of the argument, and it isn't ours... Edited By MattyB on 22/05/2017 11:13:12 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted May 22, 2017 Share Posted May 22, 2017 Posted by MattyB on 22/05/2017 11:08:11: My copy arrived on Saturday. Having had a read (it didn't take long; half a page tucked away near the back that sadly most will miss) it seems the BMFA have adopted a more conciliatory tone compared to their response to the prototype rules; based on their interpretation there does seem reason for cautious optimism. I think we are a long way from being in the clear though. On paper delegating that authority to the CAA (who have always seemed pragmatic and not overly worried when it comes to organised model flying) seems a good outcome for us. However I just cannot see the commercial interests involved who want access to that airspace below 400ft (Amazon, the logistics companies etc) supporting this approach. Allowing each country CA to negotiate and define it's own exception criteria for the rules with their local modelling associations will make the "U-Space" concept more costly and time consuming to legislate and implement; it would certainly make cross border operation far trickier. As a result I fully expect these organisations to put out lots of publicity and deploy employ expensive lobbying groups to set out why a top down, centralised approach across the EU with far less local variance is critical to the success of the commercial drone industry. It then becomes a political decision as to which way the EU/EASA want to go - problem is all the £££s are on one side of the argument, and it isn't ours... Edited By MattyB on 22/05/2017 11:13:12 I see your point Matty on the commercial drive - but maybe it might not be so difficult to get them to accept - I believe this why EASA are so keen to make flying outside a club context more difficult for us. By corralling us into clubs on registered sites they know exactly where we are and what our flying zones are. This can be made public domain information - shown on suitable UAV aviation maps. Flight programming of commercials can avoid such areas and should not encounter significant model activity outside of those areas. This has two advantages, one us and one for them: 1. For us it means that as long as we stay within the designated club flight zone we shouldn't have to worry about U-Space - we can be exempted form those requirements on full commercial operators because our airspace is protected via an exclusion zone for all except the club. 2. The commercial operators can proceed, as safe as they can be, in the knowledge that as long as they avoid those zones they should not encounter any operations not showing on U-Space. The big disadvantage for us of course is what happens to those not in a club, or participating in an activity like sloping that doesn't tend to be club orientated? The fear is that such flyers will have to comply with the full gammit of controls on commercial fliers to operate in U-Space - that would be difficult. While we can hope that Sloping Sites will be able to be registered - even without a formal club (that's a job of work for BMFA et al), I can see little able to save the lone flyer in a local farmer's field I'm afraid at the moment. Note I'm not saying he won't be able to fly - but I do think he is going to pick up a huge raft of additional requirements needed to operate in that context outside of the protected airspace of a club where all the exemptions can be in place. BEB Quote Link to comment Share on other sites More sharing options...
MattyB Posted May 22, 2017 Share Posted May 22, 2017 Posted by Biggles' Elder Brother - Moderator on 22/05/2017 12:02:20: ...The big disadvantage for us of course is what happens to those not in a club, or participating in an activity like sloping that doesn't tend to be club orientated? The fear is that such flyers will have to comply with the full gammit of controls on commercial fliers to operate in U-Space - that would be difficult. While we can hope that Sloping Sites will be able to be registered - even without a formal club (that's a job of work for BMFA et al), I can see little able to save the lone flyer in a local farmer's field I'm afraid at the moment. Agreed, I think prospects for the lone flyer are now pretty bleak - irrelevant of price I am not sure the tech even exists to allow many fixed wing model comply at the present time, and certainly not gliders. Selfishly it is slope sites I am really concerned about as that is my favourite form of flying and so many sites do not have a tenant BMFA club to look after them. When I floated the idea of an over-arching "UK Soaring Club" to look after these sites the BMAF stated they did not think it would be needed given the direction of negotiations, but looking at the latest NPA draft I think such an organisation may have become more likely with this iteration, not less. You could be right though, there is no reason that the BMFA could not just ask it's members (country and club) to mass register slope sites centrally online without such an organisation being required; every BMFA member could then use them legitimately. Even so some sites will be missed and some pilots will end up flying illegally, whether aware or not. Edited By MattyB on 22/05/2017 12:43:21 Quote Link to comment Share on other sites More sharing options...
