Peter Christy Posted September 3, 2017 Share Posted September 3, 2017 Cymaz, I don't like the look of those crush marks on the wires, where the back of the case has obviously been trapping the wires. Proceed with caution! -- Pete Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted September 6, 2017 Share Posted September 6, 2017 THESE are a bargain at the moment. Ideal for petrol with electronic ignition. Switch for the ignition, switch for the receiver and a fuel dot for the juice. Also ideal for glow with battery / switch redundancy. I ordered some and they have arrived this morning. Proper AGM switches in sealed packets. Edited By Gary Manuel on 06/09/2017 12:54:18 Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 8, 2017 Author Share Posted September 8, 2017 Posted by Peter Christy on 03/09/2017 23:09:20: Cymaz, I don't like the look of those crush marks on the wires, where the back of the case has obviously been trapping the wires. Proceed with caution! -- Pete I filed out the indents on the back cover to release the bending strain when the lid clipped on. It seems to work. Have holiday today so will work on my other switches. I have a hot glue gum and will experiment with that. If it works then it will be quicker than epoxy. Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 13, 2017 Author Share Posted September 13, 2017 My new switch arrived. Its a Etronix from RCWorld The switch movement is very positive and needs firm movement to move the toggle. It should not be able to switch it accidentally. The quality of the machined body is very good. The charge socket has its own separate bay and is fixed by a plastic grub screw. The only problem I can see is water getting into the back of the switch through the plastic sleeve. I filled this with hot glue. This will also stop the wires being pulled Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted September 13, 2017 Share Posted September 13, 2017 Much better than the old slider. You should have no trouble with that. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted September 13, 2017 Share Posted September 13, 2017 You'd think so, but the only switch that I've ever had fail on me (a couple of weeks ago!) was a miniature toggle switch very similar to the one built in to that unit. I do change standard switches if I feel or suspect the slightest iffyness. Luckily it happened (a) while I was checking the model over prior to its use for toffee bombing at our open day a couple of days later and (b) on a model equipped with dual batteries and switches so a failure at a more critical time should have avoided disaster. A clubmate mentioned that it wasn't unusual for these to fail if they get knocked inwards and sure enough, the toggle did float in and out, although the switches are inside the model and unlikely to get hit by anything. P.S. I do like the look of those double switches that you posted Gary... Edited By Martin Harris on 14/09/2017 00:00:02 Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 14, 2017 Author Share Posted September 14, 2017 I forgot to say that the original switch that arrived from RCWorld had Deans plugs, even though it was labelled as jr sockets. A quick email to Martin and the problem was quickly sorted with a new switch...Thanks Martin. The wholesaler had mislabelled the packet. Quote Link to comment Share on other sites More sharing options...
flight1 Posted September 14, 2017 Share Posted September 14, 2017 Well i got the dual switch as mentioned before on this thread and it looks good switches are good with firm switching action will be going in a 30% tiger moth very good price so i got two. its machined aluminum so is light Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 14, 2017 Author Share Posted September 14, 2017 Rich, make sure the back of the switch connectors cannot get damp or wet. That's why I filled mine with hot glue. Also it adds some strain relief Quote Link to comment Share on other sites More sharing options...
flight1 Posted September 14, 2017 Share Posted September 14, 2017 Posted by cymaz on 14/09/2017 17:21:01: Rich, make sure the back of the switch connectors cannot get damp or wet. That's why I filled mine with hot glue. Also it adds some strain relief Pete on the back of these switches there is a specially made plastic cover covering the terminals offering protection and I won't be using it out in the rain and my shed is not damp Edited By flight1 on 14/09/2017 21:33:34 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 14, 2017 Share Posted September 14, 2017 Posted by flight1 on 14/09/2017 21:33:00: Posted by cymaz on 14/09/2017 17:21:01: Rich, make sure the back of the switch connectors cannot get damp or wet. That's why I filled mine with hot glue. Also it adds some strain relief Pete on the back of these switches there is a specially made plastic cover covering the terminals offering protection and I won't be using it out in the rain and my shed is not damp Edited By flight1 on 14/09/2017 21:33:34 You could fit one of those little brollies that you get in cocktails over it. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 14, 2017 Share Posted September 14, 2017 Finishing a model off so i'll get one of those agm ones for it...never had an heavy duty switch let me down though...have you ? Quote Link to comment Share on other sites More sharing options...
Mike T Posted September 14, 2017 Share Posted September 14, 2017 Can you guys let us know the make and tech specs of the actual switches mounted in those units, please? I notice that they are wired to switch both +ve and -ve wires. When making up my own harnesses, only the -ve wire is switched, but both poles are used, so doubling the contact area and increasing current handling capability. I'm pretty sure that's how the bog-standard JR and Futaba type harnesses are made up these days, as well. It would be interesting to hear pros and cons to both approaches. Quote Link to comment Share on other sites More sharing options...
gangster Posted September 14, 2017 Share Posted September 14, 2017 Just done a dissection of a big standard little switch not sure of the make but suspect Hitec. As suggested both poles are used switching the positive. I retire these switches regularly In this case it was a retired switch which I was using whilst gearing up a new model. Although both sides were parallel the radio worked perfectly The on board voltage monitor showed instantaneous bolt drop on servo movement. The new switch that I had on order arrived and did not show the same drop. JR in their transmitters use a grotty little switch and switch two circuits separately. Suspect it's something to do with buddy boxes. Beware of minature toggle switches some of these are as dodgy as little slide switches Edited By gangster on 14/09/2017 22:40:08 Quote Link to comment Share on other sites More sharing options...
flight1 Posted September 14, 2017 Share Posted September 14, 2017 Well had a look at the toggle switch both the neutral and positive are switched ( belled it out) and what i can read on the side says 5a at 125v so it would be more for our approx 6v usage . and i have checked the agm site and they state * With heavy duty switch 2A/250V AC max 20A DC for 10 min * Very good quality Gold plating connectors so reading into all that it will be good for 8amps continuously and if you are using 8 amps continuously then OOOh!! you got some big servos. I change my switches out every few years as a safty messure before they get worn and fail or develop a poor contact leading to volt drop on load, been there !! Quote Link to comment Share on other sites More sharing options...
