Andy C Posted November 26, 2017 Share Posted November 26, 2017 I managed to land my WOT 4 a little too early yesterday and as a result took the nose and the undercarriage off. I was going to simply buy a new fuselage, or even new model, but have been encouraged by those at my club to have a go at fixing it all back together. BUT, the more I read about adhesives, the more I am not sure what to use, so would like some simply advise about it please? Also, should i be looking to put some longitudinal strengtheners along the front of the fuzz or is the old saying the glue is stronger than the foam actually enough? Thanks all. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted November 26, 2017 Share Posted November 26, 2017 I assume it's a foam Wot4 rather than a wooden one and, if that's the case, UHU Poris pretty good. If there are gaps to fill then Gorilla glue, used carefully because it swells as it sets, is another useful adhesive. It all depends on where and how it's damaged. Geoff Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted November 26, 2017 Share Posted November 26, 2017 Like Geoff says, UHU POR is brilliant But follow the instructions Use a cocktail stick to ease the glue into any cracks as you apply it And allow some minutes to pass as it becomes more tacky The hard bit is to align the parts exactly before contact If it is not possible to align after the glue goes off a bit Then just hold the bits still while fresh glue is wet Quote Link to comment Share on other sites More sharing options...
Colin Bernard Posted November 26, 2017 Share Posted November 26, 2017 For foamies, if it is structural, then I always use Gorilla glue. If cosmetic then UHU Por. As Geoff says, a little gorilla goes a long way so be careful! Also be aware, if you have not bought Gorilla before, that they do a range of glues, and that it is the original brown treacly 'Gorilla Glue' that you need. Quote Link to comment Share on other sites More sharing options...
John Lee Posted November 26, 2017 Share Posted November 26, 2017 Three adhesives work well on EPO foam models (such as the WOT 4 foam-e): Ordinary medium cyno, with or without the activator (NOT the foam friendly, keep that for the depron type of foam). UHU por Gorilla glue (my least favourite but favoured by many) PVA is unsatisfactory & has difficulty in drying out. Epoxy gives a superficially sound joint but will fail if the structure flexes. Quote Link to comment Share on other sites More sharing options...
Colin Carpenter Posted November 26, 2017 Share Posted November 26, 2017 I have used Deluxe Materials Foam to Foam very successfully ! My foamy Acrowot had the front off twice and the glue line didn't break. It's transparent so repairs are not ugly like Gorilla Glue . My clubmates EFlite Spit nose came off on a daft downwards roll and having used F2F and repainted you can't see the join (as Eric used to say ) !😉 It flies just the same after the repair ! Colin Quote Link to comment Share on other sites More sharing options...
trebor Posted November 26, 2017 Share Posted November 26, 2017 Uhu Por for me, very flexible, you can pick leftovers off when dry. Strong enough for foam, I've even used it on bath tap tops which were brass and ceramic. I also use it for shake proofing on small metric screws n nuts. Quote Link to comment Share on other sites More sharing options...
Andy C Posted November 26, 2017 Author Share Posted November 26, 2017 Thanks all for the information so far. Must admit though having just checked, the motor is not running true as well. Hopefully I'll be able to get it straight enough otherwise not sure fixing the fuselage will be worth it! I may as well end up buying a new one!. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted November 26, 2017 Share Posted November 26, 2017 It's probably only the motor shaft that's bent. You easily buy and fit a new one. I've done it myself when I inadvertently switched off my new and unfamiliar transmitter whilst trimming out my Acrowot foamie. It headed for the ground on fail-safe as it needed up trim Not one of my better days. Geoff Quote Link to comment Share on other sites More sharing options...
