john stones 1 - Moderator Posted December 6, 2017 Share Posted December 6, 2017 Built as plan for me, electric version. Sports model finish or made to look military ? I don't know yet. Probably need help with the choice of motor etc, all the lecky stuff I've built flys well but I'm always disappointed with the flight times, 10 minutes + would be nice. First twin, so new for me, like the lines of it and the wing section, looks a good un. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted December 6, 2017 Share Posted December 6, 2017 Certainly looks a good un, John. I'm struggling myself with EP specs at the moment, but I'm sure some gurus will show you the way. I guess AUW and ground / fuselage clearance for your props will be the dictating factors here. Subscribed, young man. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted December 7, 2017 Share Posted December 7, 2017 Interesting comment John, I get 10 mins with my Skywriter set up using a 3300 mAh battery . I never fly to more than 80% capacity and it is generally more like 70% unless I tear round the sky a bit ! So my very limited experience with electric set up says go for the largest capacity battery you can fit . Remains to be seen what endurance I get from the Tigercub but again I went for the biggest I could fit which was a 3700 mAh. Many will say that spending money on a premium battery is better value as they hold their voltage for longer and for same wattage requirement use less amps and therefore flight time is better. That was certainly the advice I got from George at 4 max and I having got one of his LiPo’s I have not been dissapointed. Tim Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 8, 2017 Author Share Posted December 8, 2017 I don't think it's the gear I'm using Tim, more like it's me not choosing the correct package. Flown in a scale like manner, lovely, what a sound. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 8, 2017 Share Posted December 8, 2017 And this **LINK** Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 8, 2017 Author Share Posted December 8, 2017 Magic, scale colours are growing on me. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 9, 2017 Share Posted December 9, 2017 Awesome!!! Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted December 13, 2017 Share Posted December 13, 2017 I think I want smoke too now ! Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 15, 2017 Author Share Posted December 15, 2017 Daft question alert. How do you do radio set up for twin lecky models ? Y lead for esc's or separate channels ? Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted December 15, 2017 Share Posted December 15, 2017 John, Y lead into normal throttle channel. Perceived wisdom is to remove the red power lead (= cut one of the esc wires) from one of the esc’s. This supposedly stops any duality of which esc drives the UBEC power. The 4 max website has some excellent how to pages if you want more detail/options. Tim Quote Link to comment Share on other sites More sharing options...
Ace Posted December 15, 2017 Share Posted December 15, 2017 I know "cut " was a figure of speech but for clarity, just lift the plastic tab and remove the red wire from one esc plug and tape it back. You can then replace it later and use the esc as normal in another model Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 15, 2017 Author Share Posted December 15, 2017 Cheers lads, I'll have a read of 4max threads thanks Tim. Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted December 17, 2017 Share Posted December 17, 2017 Posted by john stones 1 on 15/12/2017 17:07:06: Daft question alert. How do you do radio set up for twin lecky models ? Y lead for esc's or separate channels ? Go for a separate channel if you have one on the receiver (and if you have the knowledge to program a mix on your transmitter). This gives you the following possibilities: compensate for any differences between the ESC's and motors (starting point, max RPM etc.) turn off one motor and do a low pass with one propeller stopped (you have to program the ESC to stop the propeller so it will not freewheel) Mix rudder to motors. Manouvrer on the ground like a full size does, i.e. pulling more with one motor pulling more then the other for turns. Regards, Lucas ps and indeed never use the BEC from 2 ESC's. Some with burn with "feeded" with another power source. Edited By Lucas Hofman on 17/12/2017 10:01:39 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 2, 2018 Author Share Posted January 2, 2018 Made an hi tec start on mine, trace the parts out, nowt to show you, so few pics of Sonny. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted January 2, 2018 Share Posted January 2, 2018 Lovely dog 🐕 you have there. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted January 2, 2018 Share Posted January 2, 2018 ... for sure not a 'tiger'... not even a 'cat'... ... but indeed a great companion you have there, John. Cheers Chris Edited By McG 6969 on 02/01/2018 21:01:37 Quote Link to comment Share on other sites More sharing options...
FastFlyer Smyth Posted January 2, 2018 Share Posted January 2, 2018 GSD or cross ? unusual colouring.... Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 2, 2018 Author Share Posted January 2, 2018 GSDX, rescue dog, fell in love at first sight. confident/friendly/daft. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 2, 2018 Share Posted January 2, 2018 You or the dog John, or both? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 2, 2018 Author Share Posted January 2, 2018 Both I hope Ron, We've both big ears/ nose as well. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 3, 2018 Share Posted January 3, 2018 We had rescue dogs for many years. Some of them can be kinked but you learn to live with that. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 3, 2018 Author Share Posted January 3, 2018 Ribs/formers traced out and t/plane fin/rudder drawn in for built up ones...scrap box job, not coz I'm worried about the weight. Fixed u/c, I fancy flaps and deeper/shorter ailerons as well, just to be different. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted January 4, 2018 Share Posted January 4, 2018 Glad to see some movement around your GTC, John. But now please, stop playing with Sonny and show us some wooden bits... Cheers Chris Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 5, 2018 Author Share Posted January 5, 2018 Wooden bits. Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted January 6, 2018 Share Posted January 6, 2018 Hurray for build up tail surfaces! Lucas Quote Link to comment Share on other sites More sharing options...
