McG 6969 Posted February 20, 2020 Author Share Posted February 20, 2020 Thanks a lot, Harry. I hope to complete the Dog's nose asap now as I still have lots to do... Glad also that you're back to business now. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Simon Ward 2 Posted February 20, 2020 Share Posted February 20, 2020 Chris, the Sabre Dog's looking fantastic. You're doing a wonderful job on the construction. Really looking forward to seeing this take to the air off the Great Orme in June. All the best, Simon. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 20, 2020 Author Share Posted February 20, 2020 Your words are really too kind, Simon. Albeit I feel my progress is very slow, I try to do the best I can at the speed I'm feeling comfortable with. But then, I never pretended the Dog will be able to fly at all... I fabricated the 'lips' for the Dog's mouth today. Glued, pinned and drying now. Delicate sanding session to follow next... Cheers Chris Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 21, 2020 Author Share Posted February 21, 2020 Hi, Not much done today but in my humble opinion a tedious step forward. The Dog’s mouth ‘lips’ - 2x 5mm balsa laminated together - were sanded slowly to shape. And when I state slowly, I’m not supposed to reveal publicly the amount of time it took me… At the end of the session, I added the tiny blocks that will become the fairings for the lips. Glad this one is nearly completed… Hakuna matata Chris BRU - BE / CTR Lips (!?) Control Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted February 21, 2020 Share Posted February 21, 2020 Chris - you've captured a complex, characteristic shape really well there though, time well spent in my opinion! And it does take time! - Easier to take a little bit more off than put a little bit back on! Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 21, 2020 Share Posted February 21, 2020 Looks very good Chris, soon be on the Orme flying it. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted February 22, 2020 Share Posted February 22, 2020 Beautiful work chris !A work of art ! Just a small remark if i may , On the hurricane, the previous MB i did the fairings between wing and fuse the same way you're doing the nose with bleu foam.On a very sunny PSS meeting in Macon last summer, the foam began to melt under the epoxy leaving me with a nasty surface on one side. So if you ever leave her in the sun,please take your precautions . Keep up the good job !! Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 22, 2020 Author Share Posted February 22, 2020 Thank you all three for your motivating comments, gents. Well then, it seems I will have to invest in a proper shelter/tent for the Dog as the intention is to use more foam at the tailplanes. As I knew I would have different non-modelling activities today, I decided to have some Photoshop duties done in between for the Dog. What a surprise as I discovered Phil's deco-scheme related activities on his build blog... What a coincidence... Of course, no relation whatsoever with the roundels of the BAF from that era... Hakuna matata Chris BRU - BE / CTR Roundel Control Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 23, 2020 Author Share Posted February 23, 2020 “I’m innocent, Your Honour. They were lurking at me constantly” … In fact, I’m a tiny bit guilty, but I couldn’t resist any longer to try out those Andy B’s sanding pads ! Only the front all over and the top part and sides of the aft-fuse are planked so far, but I started prudently with the coarse pad to get rid of the plank edges. Again, a bit impatient to see the next stage, I had a few passes with the medium grit… and the ‘work in progress’ area became larger… Anyhow, the Official Reason for my sanding process will remain that I needed a correct curve around the cockpit and around the fin fairing to allow for further progress… (to be continued) ... Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 23, 2020 Author Share Posted February 23, 2020 ... (continued)... due to forum restrictions... As it appears, I really couldn’t stop taking pics. REPORT > Andy B’s pads are amazingly easy to use. Different grits are an addition to this great tool. I cut the angles at 45° at the corners but found out it’s even better to slightly fold ‘up’ the corner of the pads. In one word > SUPERB tools. Hakuna matata Chris BRU - BE / CTR Pads Control Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 24, 2020 Author Share Posted February 24, 2020 Hi again, Well, Andy’s pads weren’t creating a flow of ‘enthusiasm’, it appears… As the basic construction of the front part of the fuse slowly gets to its end, one of the last bits was to shape those ‘lips’ fairings. Rather pleased with those, but now time to start pondering about the tail end… Hakuna matata Chris BRU - BE / CTR Lips #2 Control Quote Link to comment Share on other sites More sharing options...
Dave Cunnington Posted February 24, 2020 Share Posted February 24, 2020 Smooth indeed ! Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 24, 2020 Share Posted February 24, 2020 Looks like Wallace. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 25, 2020 Author Share Posted February 25, 2020 Thank you both for visiting and commenting, gents. ... but then, not the slightest clue who 'Wallace' might be, John... ??? Cheers Chris Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted February 25, 2020 Share Posted February 25, 2020 Some lovely neat planking showing after the sanding, great job. I think the mouth may be a little like Wallace, from Wallace and Gromit Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 25, 2020 Author Share Posted February 25, 2020 Thank you for your kind and motivating comment, Andy. Now at least I know who 'Wallace' stands for... He 's not a well known character here in BE, but there is without doubt a close resemblance to the Dog's mouth... ... Actively working on those tail drawings at the moment. They really are 'very' different compared to the standard F-86's tail parts. Update soon to follow, I hope... Cheers Chris Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 26, 2020 Author Share Posted February 26, 2020 Hello to all, After a bit (a lot?) of pondering, I started to draw the tail end of the Dog. Starting from the datum line, I drew the fin and its fairing - rake? - as a compromise of my documentation, pics and the plastic model. Measuring the angles of the different parts to the datum was a big help to finally achieve the following drawing. When you have the scaled coordinates, it becomes a lot easier to integrate them to Martin’s plan. As foreseen - more or less, I guestimated 40mm - earlier, the fin appears to be 37mm taller than the standard F-86 without the tips. The fairing also is triple the height of the ‘normal’ one. Close enough to prepare some wood, now, I guess… On a side note, the calculator in the pic is a Marksman. Before even Texas Instruments did, they made a solar powered calculator with a genuine leather lid to protect the solar cell. The thing has no batteries at all and it still works perfectly. No idea how old it is now… but the funny part about it, is when I discovered it was made in… China. Hakuna matata Chris BRU - BE / CTR Drawings Control Edited By McG 6969 on 26/02/2020 19:10:50 Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted February 26, 2020 Share Posted February 26, 2020 great work Chris, your model will certainly stand out in the line up with its longer nose and taller fin! Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 27, 2020 Author Share Posted February 27, 2020 Thanks a lot, Phil. To be honest, I'm not really worried about the 'line up' - if I ever get there, that is - but more by 'standing out' regarding the overweight of the Dog. Longer nose, fatter fuselage, taller tail... not that good, I'm afraid... Cheers Chris Quote Link to comment Share on other sites More sharing options...
Martin Gay Posted February 27, 2020 Share Posted February 27, 2020 Longer nose? Taller tail? I don't think your model will be the only one there with those attributes! Edited By Martin Gay on 27/02/2020 14:58:44 Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 27, 2020 Author Share Posted February 27, 2020 Hi Martin & thanks for commenting, Are you referring to Ade's 'dual stick' machine? ... or is there another Dog somewhere... ??? If it is the 'trainer' version, the TF-86F was indeed 6 feet 'longer', but not at the nose. It is between the moving part of the canopy and the wing's LE. I was surprised that it wasn't a 'sliding' canopy, but 'tilting' like the Dog series... The 'nose' in front of the windscreen is the same. The wing itself was built 8" more forward for CoG reasons. Regarding the tail unit, IMHO it seems the same as the standard Sabre including the dihedral. By the way, were you not using your Turnigy MG's for the elevator as well? I've been reading recently that you are using 'standard' sized on the elevator. A bit confusing for this apprentice... Cheers Chris Quote Link to comment Share on other sites More sharing options...
Martin Gay Posted February 27, 2020 Share Posted February 27, 2020 I used standard sized for the elevators because I had them available. Because of the amount of tailplane in front of the pivot point there is less load on the servo so the 2.4kg pull Turnigy will be fine in my opinion. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 28, 2020 Author Share Posted February 28, 2020 Thank you for your answer, Martin. I'm thinking of using a larger one for the elevator as well. I have a 'widow' Corona 238MG somewhere from an previous job lot. If I can locate it, it would allow me to keep the Turnigys 'paired' and it gives 4.00 kg @ 4,8V. Cheers & thanks Chris Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted February 29, 2020 Author Share Posted February 29, 2020 Hi to all, I had some progress with the tail end and finally some wooden bits were prepared. I decided to go for the Dirk/Phil method for the elevators. A triple lamination of two 5mm parts sandwiching a 3mm central part. The joiners ‘tunnelling’ has still to be made in the 3mm sheets but pretty convinced that this will be a very accurate method. Then I started having the first ‘big blooper’ of the Dog’s build… As my fin is quite ‘high’, I thought of having a 12mm part at the bottom made cross-grain. Same amount of wood, a bit extra glue, but the fin gets a lot stiffer. All good so far, except that I forgot to add the bottom beam when drawing the bellcrank and the F10 cuts out… so, they ended cut way too ‘high’… No way I was going to bin all that nice wood and I decided to glue the missing bits back in before adding the bottom wood and the fin tip. Let’s play it a little safer from now on… Note to self > that cheap red marker pen is definitely NOT waterproof… Hakuna matata Chris BRU - BE / CTR Blooper Control Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted March 1, 2020 Author Share Posted March 1, 2020 Hello again, Not an enormous progress, but just one ‘bite’ at the time… The joiner tunnels were cut out of the central 3mm sheet and the bits laminated together. Then followed by both elevator tips. Really no brain bashing here, but I can suppose it’s not that far away… This is a view of the root side of the elevators so far. As I can imagine, people must be wondering what I’m ‘trying’ to do… I had a search recently on the net and found this one. As you can see, the Dogs tail end is totally different compared to a F-86. Not only fin & dorsal fairing dimensions, but also the lateral fairings of the fin itself. Not to mention the turbine exhaust shape… I decided to go for the Dog, I really got it… May the Dog be blessed… Hakuna matata Chris BRU - BE / CTR Brain Bashing Control Quote Link to comment Share on other sites More sharing options...
