john marsh Posted September 23, 2020 Share Posted September 23, 2020 Can someone help after. period of storage I seem to have lost bind on trying to. Rebind transmitter says bind complete but recv and satt lights continue to blink? Batt OK bypassed switch no different. Thanks for any help John. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted September 23, 2020 Share Posted September 23, 2020 Hi John Are you removing the bind plug before powering off the receiver as per the instructions and then checking whether bind has been achieved by powering up again? Quote Link to comment Share on other sites More sharing options...
john marsh Posted October 3, 2020 Author Share Posted October 3, 2020 Hi Steve Thanks for your reply sorry for not to getting back to you before. The problem is I cannot get to that stage the transmitter is confirming bind complete but actually it isn't recv lights not going solid but still flashing they need to be solid before removing bind plug. I don't have spare recv to try think I should get one, unless you have any more thoughts? Thanks John. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 3, 2020 Share Posted October 3, 2020 Which Transmitter John ? Edited By Denis Watkins on 03/10/2020 14:57:08 Quote Link to comment Share on other sites More sharing options...
bert baker Posted October 3, 2020 Share Posted October 3, 2020 Is the plugs for servos and power the right way up. have you ever had this bound to the transmitter before Quote Link to comment Share on other sites More sharing options...
john marsh Posted October 3, 2020 Author Share Posted October 3, 2020 Thanks Denis you solved it Transmitter is DX7 Dsmx my mistake Thanks John. Quote Link to comment Share on other sites More sharing options...
Glenn Philbrick Posted October 3, 2020 Share Posted October 3, 2020 Glad you managed to sort your binding issues out. I have another query regarding Ar 8000 rx with DX9 tr. When I switch on and the receiver carries out its initial checks it moves a couple of servos, one of which is the retract. This has the effect that they retract often dumping the model on its wheels if I don't remember. Is there any way of changing this so it moves say a rudder servo? Thanks Glenn Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 3, 2020 Share Posted October 3, 2020 I/C or Electric power model Glenn? Basically, am asking, do you use a standard 4.8v receiver supply? Edited By Denis Watkins on 03/10/2020 18:51:53 Quote Link to comment Share on other sites More sharing options...
Nick Cripps Posted October 3, 2020 Share Posted October 3, 2020 Glenn, I believe your problem is due to initially binding the receiver with the retract switch set in the "up" position. Rebind the rx with the switch in the position you require and it should be fixed. Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted October 4, 2020 Share Posted October 4, 2020 Yes, the Rx initially goes to the failsafe position, re-bind it as Nick describes. Quote Link to comment Share on other sites More sharing options...
Glenn Philbrick Posted October 4, 2020 Share Posted October 4, 2020 Thanks Nick & Trevor. I hadn't thought of that it has fixed the issue only another three warbirds to bind and then test out. Quote Link to comment Share on other sites More sharing options...
