The Ohmen
EarlyBird
A ruler helps to position the sheet.
Damp the top of the sheet to help it bend and while it soaks in apply the glue, no rush, then lay the sheet in place and hold down with weights.
I used a 600 mm Permagrit for the leading edge, with the rough side down it stayed in place even close to the edge.
After a few minutes I moved the ruler and used 1/16" scrap to balance the wood block and batteries close to the back edge and the Permagrit as far forward as possible, adding a bit of hand pressure just to make sure.
Here it is with the weights removed.
Looks and feels good to me.
Top cap strips next.
Steve
  • Like 2
Sanded LE and tip rib then set up a 1/4" jig.
Using a piece of 1/4" spruce for the width of the cut.
The length of the cap strips was a consistent 119.5 mm so I cut a piece of scrap 1/16" exactly to this length then used the jig to cut eight strips and glued in place.
IMG_20231223_140326.thumb.jpg.76b234eb94d47ace83e60f63c53c7502.jpgIMG_20231223_140421.thumb.jpg.02714486f9da8f77ec724468ef31f825.jpg
and after some sanding here we have it.
I must be learning.
Next, I cut the bottom strips and at that gave up for the day.
Steve
Alot of shaping and fitting over the last few days.
Starting with the LE and top spar then the TE,
I use the David Plane to start, just catching the ribs.
Then use the Perma grit block to finish, again just catching the ribs and removing the burnt wood.
We now come to the tricky bit of joining the wings. With the wing propped up 1 1/2" then the join is test fitted.
TLAR, after lots of careful sanding and test fitting.
Next is to glue it together then finish the top LE and the rest, including the cap strips.
Steve
TE is next so add the scrap balsa first,
Then using the LE offcut which will fit perfectly.
or maybe not, I must have cut the wrong side of the line. 😞
Only thing to do is cut another one.
and use a ruler for a straight edge so that the rib cap strips are 119.5 mm to match the first wing.
Steve
Which brings us to the top centre sheeting.
I make this from two pieces of balsa fitting tp the LE and TE respectively.
Then using a sharp pencil mark the cut line.
Cut on or to the correct side of the line.
Edited by EarlyBird
I check the fit and when happy (TLAR) tape the top.
Turn over and tape the full length which will form a hinge.
Turn over and remove the temporary tape which will enable the hinge to be opened for glue.
When glued it will look like this
and fit, we hope.
On the back draw the lines for the desired shape.
and cut. I also score along the centre line.
When happy glue it.
Steve
Next is the bottom sheeting but first the paper tube,
Then repeat the process used on the top sheeting.
The hinge opened up and glue applied.
Close the hinge and wipe off the excess glue then place on a flat surface and weight down with anything heavy and to hand.
Soup for lunch now I have taken it out of the cupboard above, which was to hand.
While the glue dries I can have a cup of Tea.
Steve
