Eric Robson Posted June 2, 2020 Share Posted June 2, 2020 It fits!! After removing the undercarriage and prop I was able to shoehorn it into the car there is only 2wing bolts and 2 grub screws + the radiator to remove instead of all the rigging etc. Quote Link to comment Share on other sites More sharing options...
Martian Posted June 2, 2020 Share Posted June 2, 2020 Well done Eric just a bit of padding required 😎 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted June 2, 2020 Share Posted June 2, 2020 Well don Eric Mine is the later model and the tailgate is narrower. Could have tried going in through the back doors i suppose..... Anyway easy to take the two panels off, certainly easier than the undercarriage on mine. Cheers Danny Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 5, 2020 Share Posted June 5, 2020 With the change in the weather I have managed to get the tail rigging on the Fury done. It is more tuneful than the wing rigging, Quote Link to comment Share on other sites More sharing options...
Martian Posted June 5, 2020 Share Posted June 5, 2020 It's fun isn't it Eric 😜 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 5, 2020 Share Posted June 5, 2020 Great fun Martian, I don't know any tunes by the Fury's but I did get the first bar of Apache. No chance of playing Nimrod.. Cheers Eric. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted June 5, 2020 Share Posted June 5, 2020 Excellent well done Eric, mine just makes a dull thud How much have you left to do on yours? Cheers Danny Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 6, 2020 Share Posted June 6, 2020 Hi Danny and all, I have the undercarriage. windscreen and the radiator to sort out along with details like the carb intakes etc. I marked the fuselage for the squadron markings but at the moment I have chickened out of painting them as I don't think I have enough paint and with the local shop closed at the moment I will leave it in works delivery condition, which is marked with K 2065, roundels and fin flash. Cheers Eric. Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 7, 2020 Share Posted June 7, 2020 Today I cut the numbers and letter k for the underside of the lower wing , I think it would have been quicker to paint them on .Must get that undercarriage finished. Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 11, 2020 Share Posted June 11, 2020 Thanks for the tip Danny, I have made my exhausts in my usual way out of Fosters cans. They have a kind of shellac on the inside which when heated turns brown , I have only done the cowl at this time, need to cut out the holes for the fuselage. Cheers Eric. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted June 11, 2020 Share Posted June 11, 2020 Necessity, the mother of all invention, they look great Eric. Much better than just holes eh? Well done. Cheers Danny Quote Link to comment Share on other sites More sharing options...
Martian Posted June 11, 2020 Share Posted June 11, 2020 Very nice Eric but would Newcastle brown cane be better 😜 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 11, 2020 Share Posted June 11, 2020 Thanks Danny & Martian, unfortunately Newcastle brown ale is no longer made in Newcastle. I doubt if the Fury will fly in a straight line with all the beer cans I have used. hic! hic! Now attempting to put the leather around the cockpit. You can tell the weather is not good I am working on the Fury. Cheers Eric. Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 13, 2020 Share Posted June 13, 2020 My treatment of the rear panel, holes made for lacing I will probably paint it on with a bow pen. The rudder is closed loop using rods instead of wire cable with adjustment at the rudder end as when built up the servo's are inaccessible. Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 15, 2020 Share Posted June 15, 2020 IT FLYS!!, test flight today after ground handling, the rudder works really well on the ground I lined it up and took off. With light breeze it took off on just over half throttle dead straight I had to hold the elevator down even after full trim was reached. After 4 mins. flying I lined up for a landing (not my best ) it needs more nose weight as I had it balanced on the rear cg point on the plan. I flew it without a spinner as I have not sorted out how to fasten it on, the prop shaft is 10 mm aluminium and the spinner bolt is 6 mm. I think I could drill through the hub a 4 mm hole but any bigger would weaken the prop driver as it is only 9mm measured in the depth of the thread. The motor is a boost 60 with an 80amp esc. the prop is APC electric 15x 8 and the battery is 5s 5000. After 4mins. it still had 80% left but I only flew it on half throttle. I wish I had made the servos accessible through the cockpit Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 15, 2020 Share Posted June 15, 2020 By the way Danny I can get it in the car with out removing any thing, got to keep the wings high up to get over the wheel arch trimming. Cheers Eric. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted June 15, 2020 Share Posted June 15, 2020 Brilliant news Eric, well done. Did you leave your tail-plane incidence as per plan or did you alter it? That is great news indeed First to fly I think, or did I miss somebody? You already said about the Fury going in the car, though great that you don't have to remove U/C. Mine is a later model Mondy than yours and it wont fit. I knew the rear hatch was smaller. No Damage on your less than perfect landing I hope? Cheers Danny Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 15, 2020 Share Posted June 15, 2020 Hi Danny, I built it as plan as it was I had to hold down in as I had run out of trim . If I levelled the tail plane I think it would have just looped all the time. I will add some weight to the nose my battery is behind f1 so I can't move it forward. No damage on landing one of the wing struts popped out but went back OK . Considering it has a tail skid it turned on the ground as if it had a steerable tail wheel. I was thinking of getting another car mine is a Mercedes B class which I have had from it being 3 months old. I just said the Mondy was off the list when you could not get the Fury in built up. I am keeping the Merc. as it has been so reliable. If I am first to fly I was last to build as I just started it in March this year, It would not have been finished now if it had not been for the lockdown. Cheers Eric. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 15, 2020 Share Posted June 15, 2020 @ Eric - this will maybe suit your needs - Just Engines Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 15, 2020 Share Posted June 15, 2020 Thanks Ron. that looks like the answer I shall contact them in the morning. I am not sure what the pitch is on the M.10 shaft but it appears to be standard iso metric. Cheers Eric. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 15, 2020 Share Posted June 15, 2020 Standard pitch for 10mm is 1.5, fine is 1.25 and extra fine 1.0. Looking at some photos of the Boost accessories it looks like it is 1.5 (but appearances can be deceptive!) Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 15, 2020 Share Posted June 15, 2020 Posted by Ron Gray on 15/06/2020 22:32:46: Standard pitch for 10mm is 1.5, fine is 1.25 and extra fine 1.0. Looking at some photos of the Boost accessories it looks like it is 1.5 (but appearances can be deceptive!) In that case it looks like I will have to have the nut that fits the Laser 180 which is 1.5 pitch. it would be the most expensive Cheers Eric. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 16, 2020 Share Posted June 16, 2020 This may, or may not help! If you haven't got a thread gauge then rub a Sharpie or pencil on the threads and then press a piece of paper against the threads he impression of which will then get transferred to the paper. Measure a 10mm space and count the number of threads, like this (8 is the 1.5 (Laser) pitch, 10 is fine pitch). Crude but it works! Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted June 16, 2020 Share Posted June 16, 2020 Hi Ron, as expected it is 8. Looking at the Laser nut it appears to be turned down at the end that fits against the prop. probably to locate in the washer or the other nut as 4 strokes generally have 2 nuts holding the prop. I have a new Boost 60 for my next project and having opened it last night to look at the possibility to drill through the centre and tap M4 the shaft with the new motor is 8 mm. but the nut is 10. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 16, 2020 Share Posted June 16, 2020 I think that the Laser one Just Engines sell is designed to fit in place of the Laser prop nut, with no lock nut as with the thickness of most props there isn't enough thread on Laser engines for one. But if you have a special, non standard, requirement, Just Engines will make an adapter for you. Quote Link to comment Share on other sites More sharing options...
