Ernie Posted April 14, 2022 Share Posted April 14, 2022 Hi all, I'm thinking about the joints on a piano wire undercarriage. Usually, I bind them with fuse wire or suchlike, and soft solder them. This works fine, but, I can never get a really fine finish. I wonder about silver soldering them, but am wary that the great heat will effect the temper/strength of the wire Any thoughts ernie Quote Link to comment Share on other sites More sharing options...
Don Fry Posted April 14, 2022 Share Posted April 14, 2022 Two ways to help. 1. Buy some soldering braid, it’s woven copper sheath. Pull it longer and it tightens in the joint, which solder on for a nice finish. 2. Clip the joint. Get a piece of brass tube, slit it down its length threw one wall, and open it out with a screwdriver, so it will just spring over the joint, and as it goes over, it self clamps over the joint. Solder it up. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted April 14, 2022 Share Posted April 14, 2022 Used MIG welder to modify UC for suspension on Bristol fighter I am fixing up. When it comes to the effect of temperature on most metals they will return to their normal state if allowed to cool naturally. Sudden cooling / quenching can result in hardening and or it becoming brittle. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted April 15, 2022 Share Posted April 15, 2022 ernie,make sure everything is as clean as you can get it,and use plenty of heat you should get a first clast job... ken anderson...ne..1....1st class job dept. Quote Link to comment Share on other sites More sharing options...
Ernie Posted April 15, 2022 Author Share Posted April 15, 2022 thanks to all of you, I'll give it a go, and report back ernie Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 15, 2022 Share Posted April 15, 2022 (edited) 59 minutes ago, Ernie said: thanks to all of you, I'll give it a go, and report back ernie This is the way I was shown in Tech College Earnie, and it works for me as it reduces the three hands that you need to do any job. Clamps, that hold the job, but can be released later are a great help in not having wire in your joint. All clean, as the lads say, and brush some wet flux in the joint/ joints Now add the Pallions, Small pellets of Silver Solder that you have cut from your rod, 3mm is ok Place these along your joint, perhaps 2mm gaps between pallions. Now you have no need to feed in the silver solder and have your hands free to sort the heat. Heat the undercarriage near to the joint to red heat and watch the solder flow Having placed the solder 1st, then you cannot add to much by feeding in too much. Allow to air cool and all will be well Edited April 15, 2022 by Denis Watkins 1 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted April 15, 2022 Share Posted April 15, 2022 You can use the coaxial braid from older TV antenna cable. Quote Link to comment Share on other sites More sharing options...
