Engine Doctor Posted August 30, 2022 Share Posted August 30, 2022 As per title . Its the early type that the bolts go through the muffler flange and screw into the crankcase. Bolt centres approx 32mm. Looking for one for a mate . Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted August 30, 2022 Share Posted August 30, 2022 For a friend? You would say that, wouldn’t you! Actually, I still have a couple of MDS engines in occasional use (38 and 58) and they’ve given really good service. Some are definitely better than others but once carburation is sorted they don’t necessarily deserve a lot of their reputation as Metal Door Stops. 1 Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted August 31, 2022 Author Share Posted August 31, 2022 Agreed . Providing you don't wring every last rev out of them they go quite well with a decent carb. My mate , really your honour 🤥, turned up with a new unused example with gold head and prop driver. He asked me to sort it . I have fitted a SC carb for him and intended to make an adapter for an sc muffler. The mounting screws spacing is too similar so decided to look for a original. Most are probably in landfill now. Thinking back most mds engines were sold when castor oil was still used in lots if fuels. Might last better with decent oil ? Quote Link to comment Share on other sites More sharing options...
David Davis Posted August 31, 2022 Share Posted August 31, 2022 Doesn't Just Engines have anything suitable? Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted August 31, 2022 Author Share Posted August 31, 2022 Hi Dave they probably do but he wants a cheap original if poss. Quote Link to comment Share on other sites More sharing options...
Nick Cripps Posted August 31, 2022 Share Posted August 31, 2022 5 hours ago, Engine Doctor said: Most are probably in landfill now A former Hobbystores employee told me that he has half a dozen buried under his patio! Quote Link to comment Share on other sites More sharing options...
Don Fry Posted August 31, 2022 Share Posted August 31, 2022 Idiot post, redacted. Quote Link to comment Share on other sites More sharing options...
Martian Posted August 31, 2022 Share Posted August 31, 2022 I have 2 MDS muffler appears to be approx 33 between centres and 35 between centres on other free is they are any use Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 1, 2022 Author Share Posted September 1, 2022 Hi Martian any chance of a pic of the 33 bc to determine if they are the correct type ? The 35 bc won't be of any use as too wide. Regards E.D. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted September 1, 2022 Share Posted September 1, 2022 I seem to recall that MDS silencers were quite good (perhaps the best thing about them). IIRC (and I often don't) they fitted Irvine engines as well and shared a standard hole spacing. Quote Link to comment Share on other sites More sharing options...
Martian Posted September 1, 2022 Share Posted September 1, 2022 here you go pics as requested Quote Link to comment Share on other sites More sharing options...
David Davis Posted September 1, 2022 Share Posted September 1, 2022 1 hour ago, Geoff S said: I seem to recall that MDS silencers were quite good (perhaps the best thing about them). IIRC (and I often don't) they fitted Irvine engines as well and shared a standard hole spacing. They also fit Webra engines. I used to have a Webra 40 fitted with this silencer. I gave it away to a twelve year old lad. It currently powers his ancient trainer. We had to remove one of the internal washers for optimum performance. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 2, 2022 Author Share Posted September 2, 2022 Thanks Martian for pic . That appears to be a later type as far as I can tell . Are holes threaded ? The type I'm looking for has the bolts go through the silencer lugs into the engine. If the holes are not threaded then it might, just might fit. E.D. Quote Link to comment Share on other sites More sharing options...
Martian Posted September 2, 2022 Share Posted September 2, 2022 holes go straight through no threading Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 2, 2022 Author Share Posted September 2, 2022 Hi Martian PM sent. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 3, 2022 Author Share Posted September 3, 2022 Found one thanks for replies. E.D. Quote Link to comment Share on other sites More sharing options...
