SIMON CRAGG Posted November 4, 2022 Share Posted November 4, 2022 Our club are thinking about starting a "Drone Section", and I thought I might join in. After a LOT of research , I had more or less settled on a HolyStone HS 125D. (Used / as new £80). It was all systems go, until I found out that it "needs" 5G for the wi-fi, and my phone (Vodaphone Smart N10), is only 4G!. More research gives conflicting results, some say it will work, some not. Is there anybody out there that can help please?. Obviously, I don't want to waste valuable Stella coupons on something that is not going to work 100%. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted November 4, 2022 Share Posted November 4, 2022 5G is the mobile phone signal not the wifi, I can't understand why the drone is talking to the phone over the mobile network. What happens if you are operating the drone where there is no 5G network. Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted November 5, 2022 Author Share Posted November 5, 2022 4 hours ago, Frank Skilbeck said: 5G is the mobile phone signal not the wifi, I can't understand why the drone is talking to the phone over the mobile network. What happens if you are operating the drone where there is no 5G network. Thanks Frank. I find the whole drone thing VERY confusing. The market is absolutely flooded with all sorts of variations. The prices have dropped a lot, but obviously I don't want to waste Stella tokens. I am getting so many conflicting answers, I am thinking of binning the idea. I have sorted out the sort of drone I would like (GPS, Brushless motors, stabilised camera etc.), its just this phone thing I just do not understand. I certainly don't want to have to buy a new 5G capable phone just to get the system to work. Hopefully, somebody on here can explain what's what in SIMPLE terms!. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 5, 2022 Share Posted November 5, 2022 What kind on drone section ?, racing, aerobatic ( a question of programming ) photo or filming , they are all different,,, Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted November 5, 2022 Author Share Posted November 5, 2022 Photo Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted November 5, 2022 Share Posted November 5, 2022 Simon, I'm not familiar with that drone, but reading the info (BTW I assume it's a HS175D or HS120D I couldn't find a 125D) it looks like it uses wifi to send the video directly to the camera, using 5GHz Wifi (not 5G) instead of 2.4 GHz. 5GHz allows more data transfer but with a reduced range. So you'd need to check that your phone supports dual band Wifi, which is completely separate from 4G/5G which is the connection to the phone network. The problem with using 5Ghz transmission for the video feed is a lack of range, Camera World say you are pushing it beyond 100m. Note this drone is a photo/video drone designed to take photos/video not flying like a regular model aircraft. I have a DJI Mini 2 which uses the transmitter for both the control and video feed (the phone is hardwired to the Tx) and that is very fussy on the phone, if you have a low spec phone not all features work, your N10 might stuggle 2 Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted November 5, 2022 Author Share Posted November 5, 2022 Thanks Frank, I think I'll give it a miss for a while or maybe get a cheap and cheerful that does not need a phone. Any suggestions?. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted November 5, 2022 Share Posted November 5, 2022 (edited) Any Phantom 1, 2 or 3 are probably the safest and cheapest bet, second hand. or go all the way and get a new Mavic,,, i built a 450 Dji long ago with a go-pro on it, a second camera and a video switcher, still in service, a must is the RTH ! Edited November 5, 2022 by Paul De Tourtoulon Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted November 5, 2022 Share Posted November 5, 2022 2 hours ago, SIMON CRAGG said: Thanks Frank, I think I'll give it a miss for a while or maybe get a cheap and cheerful that does not need a phone. Any suggestions?. The latest DJI Mini 3 controller has the display built in so doesn't need a phone for display etc, but it's not cheap................ Sorry I'm not that well up on what other photo drones are available. Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted November 11, 2022 Author Share Posted November 11, 2022 Still struggling with this!. If a drone says it works on 5G, will it work ok on my phone that only has 4G? I don't think it will, but I may be wrong!. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted November 11, 2022 Share Posted November 11, 2022 I think this has already been answered. The requirement is for your camera phone to work on the 5.8 GHz wi-fi band in order to receive video. There is no 5G requirement - this is a totally different system used for cellular data and voice communication. Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted November 11, 2022 Author Share Posted November 11, 2022 This is my phone spec. Still non the wiser! https://www.devicespecifications.com/en/model/317550db Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted November 11, 2022 Share Posted November 11, 2022 7 minutes ago, SIMON CRAGG said: This is my phone spec. Still non the wiser! https://www.devicespecifications.com/en/model/317550db According to that your phone supports IEEE 802.11n which means it should be cap[able of wifi communication using the 2.4 and 5 GHz bands at 72 to 600Mb/s Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted November 11, 2022 Author Share Posted November 11, 2022 Great, thx Shaun!. Quote Link to comment Share on other sites More sharing options...
