Basil Posted May 20, 2023 Share Posted May 20, 2023 Can anyone help me please. I am puzzled about the motor running. Set up Lipo, Motor, 4M-ESC60A-40 ( smax)speed control. 1) complete wiring circuit with RX. 2)Insert bind plug and start bind . 3)starts to bind then motor starts.TX has no control over motor. Bind completes. motor still runs on. 4)to stop remove supply to RX. 5) motor connected to esc alone, 3 beeps. 6) ESC has been programed in line with 4max recs Earlier during my efforts to get a correct bind the motor refused to work regardless of any settings. My only thought is a faulty ESC , this one is brand new never been used. Tried different RX same result. Has any body got any thoughts. This is the only ESC that has the correct plug etc for any trails. The motor is used, second hand but was tested upon reciept months ago, any wy it runs ok. Meanwhile I will order a further ESC. Quote Link to comment Share on other sites More sharing options...
Basil Posted May 20, 2023 Author Share Posted May 20, 2023 Hi again. Using a self binding type RX , AR620 bind again. OK all controls work but no motor at all. Ordered a new ESC. Will try again once received. Bas Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted May 20, 2023 Share Posted May 20, 2023 (edited) Have you plugged the esc lead into the correct socket on the 620. I had the same problem, no motor, turned out I had plugged the lead in the wrong place I had plugged it into the batt socket instead of channel 1. Edited May 20, 2023 by Shaun Walsh Quote Link to comment Share on other sites More sharing options...
Geoff S Posted May 20, 2023 Share Posted May 20, 2023 Connect the esc/throttle lead into a rx channel that you know works (elevator, rudder or aileron) and try that. 1 Quote Link to comment Share on other sites More sharing options...
Basil Posted May 20, 2023 Author Share Posted May 20, 2023 Hi Shaun, yes you are correct about the connections re the AR620. many thanks. That still does not solve the probs with the other different RX. But I now assume that it may be a simillar situation.Bas. Quote Link to comment Share on other sites More sharing options...
Outrunner Posted May 20, 2023 Share Posted May 20, 2023 Bas, I usually bind the Rx before plugging in the ESC then at first startup with esc plugged in you can calibrate the throttle. 2 Quote Link to comment Share on other sites More sharing options...
Geoff S Posted May 20, 2023 Share Posted May 20, 2023 3 hours ago, Outrunner said: Bas, I usually bind the Rx before plugging in the ESC then at first startup with esc plugged in you can calibrate the throttle. I usually bind my receiver to the pre-setup channel before I do anything else to the electronics and definitely before fitting it into the model. I just attach a servo to make sure it's bound and then attach the servos in the model (inc the esc) once the receiver is in situ. 2 Quote Link to comment Share on other sites More sharing options...
Basil Posted May 21, 2023 Author Share Posted May 21, 2023 19 hours ago, Shaun Walsh said: Have you plugged the esc lead into the correct socket on the 620. I had the same problem, no motor, turned out I had plugged the lead in the wrong place I had plugged it into the batt socket instead of channel 1. Shaun, ( And all those that answered) I have got so used to setting up, whilst constructing, with a dry cell pack,( and I am a novice) that I just forgot that its different when connecting for real. Many thanks and apologise to all of you. Bas Quote Link to comment Share on other sites More sharing options...
MattyB Posted May 21, 2023 Share Posted May 21, 2023 Simple safety rule - never bind an RX with an ESC and motor attached. Always bind up your RX out of the model where it’s far easier to do, and attach a single servo to the throttle channel attached so you can verify you have control and that it responds as desired. Even so, when you plug in with the motor and ESC connected for the first time, make sure that prop is off! 1 Quote Link to comment Share on other sites More sharing options...
Basil Posted May 22, 2023 Author Share Posted May 22, 2023 20 hours ago, MattyB said: Simple safety rule - never bind an RX with an ESC and motor attached. Always bind up your RX out of the model where it’s far easier to do, and attach a single servo to the throttle channel attached so you can verify you have control and that it responds as desired. Even so, when you plug in with the motor and ESC connected for the first time, make sure that prop is off! I always run without a prop until its ready to fly. Always fitted once I am sure all is OK. Bas Quote Link to comment Share on other sites More sharing options...
Nigel Heather Posted June 3, 2023 Share Posted June 3, 2023 It's not one of these ESCs where you have to teach it what full stick and zero stick is? That is separate for programming. Myself, being on Futaba until recently, some ESCs have always been a bit fiddly because Futaba throttle signal is the reverse of all other brands. Quote Link to comment Share on other sites More sharing options...
