Richard Gordon-Davis 3 Posted July 29, 2023 Share Posted July 29, 2023 Good day fellow modellers. I have a real curly problem here as i own the original Phoenix sim with dongle etc from when I bought the Phoenix sim and have installed all the updates to Version 6. It has now become extremely jerky with propellor powered planes, but before you mention anything about updates and changing any settings, I have done all of those fixes. Here's the kicker, the moment I throttle back to idle with the powered planes, the simulator smoothes out totally, but open the throttle and the jerking starts again. This does not happen with unpowered gliders or with some EDFs which fly as they should, leading me to believe this is throttle related on any propped plane but as I said the I can throttle the edfs without any problems and I need to open throttle to launch gliders with no problems. I even tried changing all the program settings like reducing the frame rates, sound drivers-( set it back to openAl ), reduced the prop visibility.... I'm totally stumped so any help would be gratefully accepted. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted July 29, 2023 Share Posted July 29, 2023 How strange! I only dabble with mine I'm afraid....... there is quite an active group over on RCGroups - https://www.rcgroups.com/simulators-172/ - there are a few threads going.. 1 Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted July 29, 2023 Share Posted July 29, 2023 Uninstall and reinstall? Also, what OS are you running and what's the spec of the computer? 1 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted July 29, 2023 Share Posted July 29, 2023 14 hours ago, Richard Gordon-Davis 3 said: leading me to believe this is throttle related I think so too Recalibrate your sticks, as manufacture instruction Spektrum recalibration is shown on you tube Quote Link to comment Share on other sites More sharing options...
Richard Gordon-Davis 3 Posted August 28, 2023 Author Share Posted August 28, 2023 Have done... still not fixed Quote Link to comment Share on other sites More sharing options...
Richard Gordon-Davis 3 Posted August 28, 2023 Author Share Posted August 28, 2023 On 29/07/2023 at 23:12, Shaun Walsh said: Uninstall and reinstall? Also, what OS are you running and what's the spec of the computer? I have done many times... still not working Quote Link to comment Share on other sites More sharing options...
Richard Gordon-Davis 3 Posted August 28, 2023 Author Share Posted August 28, 2023 I'm running windows11... thanks Saun. I have even tried two different radios my radios are JR3810, Futaba 9CAP which are both on the transmitter setup menu... Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted August 29, 2023 Share Posted August 29, 2023 A couple of things you may/may not have tried... Set up a radio that's not on the menu Experiment with changing throttle throws Ask on RCGroups Quote Link to comment Share on other sites More sharing options...
Richard Gordon-Davis 3 Posted August 29, 2023 Author Share Posted August 29, 2023 Thank you so much Grumpy.... much appreciated. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted August 29, 2023 Share Posted August 29, 2023 And finally, possibly turn down the graphics resolution... Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted August 29, 2023 Share Posted August 29, 2023 7 hours ago, GrumpyGnome said: And finally, possibly turn down the graphics resolution... Indeed, that's why I asked about the spec of the PC, graphics card or processor may not quite be up to the job. Quote Link to comment Share on other sites More sharing options...
PDB Posted August 29, 2023 Share Posted August 29, 2023 It's possible Pheonix is grumpy with Windows 11, running it in "compatibility" mode might help. It's a simple process and there are lots of guides on how to do this on the net, for example HERE and easy to revert if it doesn't help. Quote Link to comment Share on other sites More sharing options...
PDB Posted August 29, 2023 Share Posted August 29, 2023 35 minutes ago, Shaun Walsh said: Indeed, that's why I asked about the spec of the PC, graphics card or processor may not quite be up to the job. By running Task Manager you can see if this is the case, a guide on running it HERE Run Task Manager while using Phoenix and see if it's CPU, Memory or Disk usage increases when you're experiencing the stuttering in Phoenix. Quote Link to comment Share on other sites More sharing options...
Richard Gordon-Davis 3 Posted August 29, 2023 Author Share Posted August 29, 2023 13 hours ago, GrumpyGnome said: And finally, possibly turn down the graphics resolution... I have done that....and graphics card is a goody as I run some serious games which are way more detailed than the sim. Also as I stated that when I deadstick the plane with power off it runs as smooth as silk... it's got me totally beat. Quote Link to comment Share on other sites More sharing options...
Richard Gordon-Davis 3 Posted August 29, 2023 Author Share Posted August 29, 2023 5 hours ago, PDB said: It's possible Pheonix is grumpy with Windows 11, running it in "compatibility" mode might help. It's a simple process and there are lots of guides on how to do this on the net, for example HERE and easy to revert if it doesn't help. Hi, I've tried in compatibility mode and have even updated DLL files.... Quote Link to comment Share on other sites More sharing options...
Richard Gordon-Davis 3 Posted August 29, 2023 Author Share Posted August 29, 2023 5 hours ago, PDB said: By running Task Manager you can see if this is the case, a guide on running it HERE Run Task Manager while using Phoenix and see if it's CPU, Memory or Disk usage increases when you're experiencing the stuttering in Phoenix. thanks PDB this is something that I have not tried 🙂 ... I will give it a go when I get back home from a business trip. Quote Link to comment Share on other sites More sharing options...
