Carbon Fibre Wing Tube for Phoenix 2m Glider V1
Neil67
Looking for sources to purchase, 9mm ext dia, 5mm int dia by 400mm carbon fibre tube or solid rod for above model.  Can't find any stockists and difficult to get correct diameter.  Adverts for cheap  rod on ebay but huge delivery costs.
Similarly, if anybody has one for sale please let me know.
Neil
The Paper Aviation Eezee Peezy uses dowel as a wing joiner and IIRC the instructions are to wrap masking tape round the dowel to get it to fit tightly in the wing tube.  Obviously it's not a high performance/high G model but it seems to work very well despite my initial doubts when I built mine.  I'm sure using a slightly smaller diameter (but still adequately strong) wing tube could be packed out to accurate size and be perfectly OK.  I used several bands of 50mm cheap masking tape rather than try to wrap the whole tube.  After all the Phoenix 2k isn't a high performance/high G model either.
If very slightly smaller OD tubes are available the masking tape method as indicated by Geoff works well. Another trick is to use suitable heat shrink tube over the carbon tube to take up any slack. If worried about the strength of the lower OD tube, one can use the next smaller size carbon tube telescoped inside the larger one (can be epoxied inside). That will probably be much more stronger than a single tube (with a slight weight penalty).
I have used the masking tape with double tube and also the heat shrink tube method
