Eric Robson Posted December 16, 2023 Share Posted December 16, 2023 Day 2 pins removed from fuselage after leaving over night pva Gorilla wood glue used, I find this glue sands very well. Construction straight forward, no problems 4 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 16, 2023 Author Share Posted December 16, 2023 After sanding the fuselage top I cut the canopy and found the sides of the fuselage did not come high enough, no great problem to add some balsa from the offcut. Another point when assembling F2 onto the sides and crutch make sure it is vertical as if not it can alter the side length when pulling the sides together at the rear. 1 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 16, 2023 Author Share Posted December 16, 2023 Not done much today on the 190, nose skid fitted and shaped and cowl wrapping support stringers fitted, note wrapping not parallel. I had a spare Overlander 3548/05 900kv which adequately powered a heavier model, to get the prop in the right place I packed the motor mount 1/2" back from F1. 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 16, 2023 Share Posted December 16, 2023 11 hours ago, Eric Robson said: Day 2 pins Cor, do you have different pins for each day Eric? Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 16, 2023 Author Share Posted December 16, 2023 Well they had different coloured rivets each day on Spitfires, Ron Quote Link to comment Share on other sites More sharing options...
Graham Bowers Posted December 17, 2023 Share Posted December 17, 2023 Good progress. I've dry assembled the fuz and want to get it all worked out before applying glue. Can I ask, what did you use as a "stern post" between the two fuzelage sides please? A bit of scrap 8mm thick? Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 17, 2023 Author Share Posted December 17, 2023 Hi Graham, I used a piece of 1/8"×1/2" cut from the fuselage side offcut and tapered it to fit in. Also on a prior photo of the canopy fit at the rear I have marked the offcut as shown in the photo below where I am going to cut it to fill the gap. 1 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 17, 2023 Author Share Posted December 17, 2023 The added strip, held on with today's pins. I cut the canopy to the line it may be better to leave 6mm on to attach it to the side but I think it will still need some packing at the rear 1 1 Quote Link to comment Share on other sites More sharing options...
Graham Bowers Posted December 18, 2023 Share Posted December 18, 2023 Thanks for that Eric. I think I can't put off reaching for the glue for much longer 😉 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 18, 2023 Share Posted December 18, 2023 7 hours ago, Eric Robson said: today's pins I think you’ve got a couple of yesterday’s in there Eric, but then looking at the time of your post they would be as it’s now today, which means the others must be the day before’s. 1 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 18, 2023 Author Share Posted December 18, 2023 Ron, I need to get some different coloured glass head pins to avoid confusion. Your right two of the pins were today's. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 18, 2023 Share Posted December 18, 2023 41 minutes ago, Eric Robson said: Ron, I need to get some different coloured glass head pins to avoid confusion That would be a great help Eric because I'm easily confused but if you could avoid Green, Blue, Red and Yellow please as I already have those for Monday, Wednesday, Friday and Sunday and I use sticky tape on the between days, unless I'm flying, then I don't bother. Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 18, 2023 Author Share Posted December 18, 2023 Just a little tip for those unfamiliar with foam wings, keep the foam they were cut from to support the wing whilst sanding. 2 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 18, 2023 Author Share Posted December 18, 2023 The canopy fit after adding the strips, just needs sanding 3 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 18, 2023 Author Share Posted December 18, 2023 Not mentioned in the instructions, what instructions? Where the upper fuselage side splays out at the front it leaves a gap and it felt a bit weak so I cut two pieces from the fuselage side offcut and glued them in for support. Using a David plane and a permagrit sanding block I managed to keep my fingers intact doing the wing tips. 1 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 18, 2023 Author Share Posted December 18, 2023 My servo mount cut out tool for foam wings. Use in a well ventilated area. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 18, 2023 Share Posted December 18, 2023 My one is a similar shaped bit of wire fitted to a soldering gun. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted December 19, 2023 Share Posted December 19, 2023 Don't know how I'll approach it - it is literally decades since I 'built' a foam wing....... Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 19, 2023 Author Share Posted December 19, 2023 Not a problem GG the wings are well cut with the dihedral angle ready set, the aileron cut out is straight forward I used a new Stanley knife blade. There's a template in the kit so no problem. Use a 30min epoxy for gluing up, only awkward part is the servo wells, I made up the tool from 2mm piano wire with a tailwheel collet for a depth guide. 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted December 19, 2023 Share Posted December 19, 2023 This is what I use for cutting out recesses in foam wings (these were some shots when using it on the WR LA-7). 3 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 19, 2023 Author Share Posted December 19, 2023 30 minutes ago, Ron Gray said: This is what I use for cutting out recesses in foam wings (these were some shots when using it on the WR LA-7). More useful than mine for retracts. Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 20, 2023 Author Share Posted December 20, 2023 Servos installed, wiring routed in the best Oriental tradition, a slot and a strip of sellotape. The wing bandage is stuck on with pva ,less messy than epoxy and I have never had one fail. I cover it with masking tape before covering. Next job the wing fillets. For the new builders this is best done with the wing attached, protect the wing with plastic film to stop it being a one piece model. 4 1 Quote Link to comment Share on other sites More sharing options...
Flying Squirrel Posted December 20, 2023 Share Posted December 20, 2023 Looking good, thanks for adding the 'newbie tips' we are listening! 1 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 20, 2023 Author Share Posted December 20, 2023 (edited) Wing fillets, the triangle section in my kit was quite hard and after putting a lot of saw cuts at the front it was reluctant to form , cutting a long piece from the rear to the top the curve,this formed OK I then cut short pieces and glued them to the fuselage, when set I sanded and filled the with wood filler. Then a final sanding to shape, to get the concave shape I used a felt tip pen with 120 grit wrapped around. BE careful when sanding, if you are unsure mask the fuselage at the top of the fillets because it is easy to put a groove in the fuselage side. Stage one 2 and 3. Despite loading them in order they have appeared 231 Edited December 20, 2023 by Eric Robson 5 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted December 20, 2023 Author Share Posted December 20, 2023 (edited) At the tail end where the elevator slots in to fill the gap use a piece of the tailplane offcut after the tail plane is fitted DO NOT PUT IT IN BEFORE THE ELEVATOR JOINER WIRE. at this point it is not glued as I have to cover the elevator. Edited December 20, 2023 by Eric Robson 1 Quote Link to comment Share on other sites More sharing options...
