Andy-H Posted April 19 Share Posted April 19 I suspect something has gone awry with the main board of my lipo charger, but worth floating this issue in case anyone might know of a solution. I have several Toolkitrc chargers, one of which is an M6DAC which can be ac or dc powered. Firmware updates are undertaken via on board USB-C socket to a pc port using a fairly standard usb cable. Whilst this worked when first bought in 2022 (so now out of warranty) it updated without any problem. However, when I tried to do so recently, the pc gives a current surge error message. Same thing trying with a different pc. Interestingly, when I plug it into a usb hub which has an independent power supply, the power light on the hub goes out, even when the hub isn’t connected to the pc. Have also tried several different cables. No solutions shown on YouTube or through Googling so I guess there’s a hardware problem associated with the on board usb port. It is charging and discharging properly but I just can’t update the software. No issues updating my other chargers. Anyone else had a similar issue and any suggested solutions ? Many thanks. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 19 Share Posted April 19 Start by checking this bit Andy Firmware upgrade After connecting the M6DAC to the computer with the USB cable in the box, the computer will recognize a USB disk named Toolkit, download the upgrade file app.upg on the official website Copy and Paste the new file to overwrite the previous files in the USB disk, and the firmware can be upgraded. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted April 19 Share Posted April 19 If it's working, why do you need to update the firmware? What extra functions do you need? Quote Link to comment Share on other sites More sharing options...
Andy-H Posted April 19 Author Share Posted April 19 The error message shuts down the usb port on the pc which means the device isn’t recognised and doesn’t show in File Explorer. My understanding is firmware updates usually rectify glitches rather adding new features which why I thought it worth trying to update. Quote Link to comment Share on other sites More sharing options...
RottenRow Posted April 19 Share Posted April 19 Are you using the same USB lead that you used successfully on previous occasions? I’m just wondering if there is something non-standard about the on-board USB socket. Brian. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted April 20 Share Posted April 20 Firmware updates typically contain one or more of....... extra/amended functionality, defect fixes, security updates. Unless you need any if these, "if it 'aint broke, don't fix it" would be my view. That's the same view taken by all major financial institutions, so if it's good enough for them....... Quote Link to comment Share on other sites More sharing options...
Andy-H Posted April 20 Author Share Posted April 20 4 hours ago, GrumpyGnome said: "if it 'aint broke, don't fix it" would be my view ……….. Same here, but it was worth asking……. BTW was using the original cable plus tried several others. I think the usb socket (or associated internal gubbins) is faulty Thanks all. Quote Link to comment Share on other sites More sharing options...
Phil Green Posted April 20 Share Posted April 20 >>However, when I tried to do so recently, the pc gives a current surge error message. ... >>when I plug it into a usb hub which has an independent power supply, the power light on the hub goes out These two symptoms both suggest its simply taking too much current, usb usually limits at an amp or two, do you have a USB current indicator? (if not get a couple, they're very handy!) 'why' could be excessive inrush to smoothing caps, or the charger is 'on', or its got itself in a weird state... Presumably you havent got the charger powered up when plugging into your PC's usb? I would first check the excessive usb current isnt a fault :-) Quote Link to comment Share on other sites More sharing options...
