Zorba Posted June 30, 2024 Share Posted June 30, 2024 Good day, Does anyone know of a UK shop which may still have these modules for sale? I want it to convert my 9ZHP. I’ve scoured the internet and eBay as well but no luck. Thanks. Quote Link to comment Share on other sites More sharing options...
James Green2 Posted June 30, 2024 Share Posted June 30, 2024 (edited) I have seen some of the plug in ones that go in the back online. this is what I have in the back of my 9ZAP WC2. I don't think there is any room in the case for the DIY module. Edited June 30, 2024 by James Green2 Quote Link to comment Share on other sites More sharing options...
Phil Green Posted June 30, 2024 Share Posted June 30, 2024 Yes a DFT would plug straight in, if you can find one! Quote Link to comment Share on other sites More sharing options...
MattyB Posted June 30, 2024 Share Posted June 30, 2024 (edited) 2 hours ago, Zorba said: Good day, Does anyone know of a UK shop which may still have these modules for sale? I want it to convert my 9ZHP. I’ve scoured the internet and eBay as well but no luck. Thanks. I’d be surprised, if they do as they haven’t been made f for many years and aren’t legal to sell any more… since the Etsi EU changes of some years back. Edited June 30, 2024 by MattyB Quote Link to comment Share on other sites More sharing options...
John Wagg Posted June 30, 2024 Share Posted June 30, 2024 The DHT module was replaced with the XHT module to conform to EU rules..:- https://www.frsky-rc.com/product/xht/ Can't find any of these either except maybe Banggood or Aliexpress. Both units look to have been dropped. There are other manufacturers of TX hacks but I have no info' on them. I understand there is an option to take the innards out of an XJT unit to make it into an XHT module. :- https://forum.alofthobbies.com/index.php?threads/converting-a-xjt-into-an-xht-for-vintage-radios.454/ Quote Link to comment Share on other sites More sharing options...
Zorba Posted July 3, 2024 Author Share Posted July 3, 2024 Hello everyone, Thank you to all. A forum member has contacted me and I’ve found both modules I’m looking for. Regards, Jack 2 Quote Link to comment Share on other sites More sharing options...
wuftymerguftyguff Posted June 16 Share Posted June 16 (edited) Where did you get the DIY modules in the end? I have a Futaba 6XSuper I want to convert to 2.4 GHz Or is there another way for now? ta Jeff Edited June 16 by wuftymerguftyguff Quote Link to comment Share on other sites More sharing options...
Wookman Posted June 17 Share Posted June 17 Lemon rx might be the way to go. Quote Link to comment Share on other sites More sharing options...
Dale Bradly Posted June 17 Share Posted June 17 I used one of these recently: https://www.aliexpress.com/item/32958574623.html Quote Link to comment Share on other sites More sharing options...
Dale Bradly Posted June 17 Share Posted June 17 19 hours ago, wuftymerguftyguff said: Where did you get the DIY modules in the end? I have a Futaba 6XSuper I want to convert to 2.4 GHz Or is there another way for now? ta Jeff Quote Link to comment Share on other sites More sharing options...
Phil Green Posted June 17 Share Posted June 17 (edited) 1 hour ago, Dale Bradly said: I used one of these recently: https://www.aliexpress.com/item/32958574623.html Not that theres owt wrong with them, and I know there are many happy users, but I wouldnt advise that module for a current conversion. Its obsolete by 15 years and much has improved since then 🙂 Despite what the label says, its not DSSS, it uses a CC2500 which is a hopper and is incapable of DSSS - same chip as Frsky which evolved from Corona. Of the two receiver aerials, one is fake and does nothing - added for 'aesthetic reasons' according to Corona tech Billy Chou. The most popular conversion module now is the Lemon, which is bang up to date and for which there is a wide range of receivers including stabilized if thats your bag 😉 Cheers Phil . Edited June 17 by Phil Green 1 Quote Link to comment Share on other sites More sharing options...
Phil Green Posted June 17 Share Posted June 17 (edited) Also, (forgot to add this but its vital) the PPM input of the Corona RF module is completely unprotected and will eventually blow if fed with battery-level PPM. The processor does have clamping diodes to the 3.3v and ground rails but IIRC these are rated at only a couple of milliamps or so. Its a long time ago but we got around it by using a Schottky diode in series with the PPM lead, banded end to the encoder, such that logic low from the encoder pulled the Corona PPM low, but a logic 1 from the encoder allowed the Corona pull-up resistor to provide the 3.3v 'high'. This problem was carried through into the Frsky V8 which was actually sent out by Frsky with a Schottky diode in the PPM lead. This was all well documented at the time but has been buried under 15 years of other posts 🙂 More 'current' modules such as Frsky DHT, XHT, Lemon etc have PPM protection built-in so levels aren't a problem. . Edited June 17 by Phil Green Quote Link to comment Share on other sites More sharing options...
Wookman Posted June 22 Share Posted June 22 On 17/06/2025 at 14:10, Phil Green said: This problem was carried through into the Frsky V8 which was actually sent out by Frsky with a Schottky diode in the PPM lead. Presumably, this problem is only with the V8 hack module and not the V8 "JR" plug in module? Quote Link to comment Share on other sites More sharing options...
Phil Green Posted June 22 Share Posted June 22 Thats right 🙂 1 Quote Link to comment Share on other sites More sharing options...
