Peter Miller Posted May 20, 2009 Share Posted May 20, 2009 Here is one to start you off. When marking out the holes on a nylon engine mount, paint the arms with Tippex. Then mark through with a suitable pen. I use a Parker ballpoint refill as that goes throught the engine bolt holes perfectly Quote Link to comment Share on other sites More sharing options...
Garry Pollard Posted May 20, 2009 Share Posted May 20, 2009 By goodness there are some clever blokes on this forum. Thanks for that will use it on electric Garry Quote Link to comment Share on other sites More sharing options...
Klippy Posted May 20, 2009 Share Posted May 20, 2009 That's another nice tip, but who can afford Parker? Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted May 20, 2009 Share Posted May 20, 2009 £2 is not a lot to avoid ruining an engine mount and its reusable. Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 20, 2009 Share Posted May 20, 2009 Good idea Peter ,thatll make things easier Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted May 21, 2009 Share Posted May 21, 2009 there is a tool for doing this called a great planes center, it basically a 2mm drill on a 15cm shaft it has an outer tube which centers itself in the engine mount hole and allows you to drill a small pilot hole so your proper drill bit dosent slip, you can even use it with the cowl on. also useful for marking servo holes in tight places Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted May 21, 2009 Author Share Posted May 21, 2009 I can't help feeling that mine is possibly a bit cheaper and easier to find I do have another method. LOng series drills, about 6 inches long but only 1.5 mm dia. even more expensive. Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted May 21, 2009 Share Posted May 21, 2009 hello peter the great planes DEAD CENTER to give its proper name costs about £7 and would make a nice little present for a modeller. the long drill series is a good idea i have some of these 12in long they are wood bits with a short point to start them, i bought them at our local market £1each, never thought to use them for engine mouting though. ihave 2mm 3mm 5mm 6mm, they are handy for reaching deep into fusalages for drilling holes for control snakes Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted May 21, 2009 Share Posted May 21, 2009 ps if anybody wants some ican see if they are still available and get some at cost +post Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted May 21, 2009 Share Posted May 21, 2009 I can't believe it ! (Now who said that? ) I stick a sharp pencil in the engine mounting holes and move it in every direction ---You end up with a big black blob & then you stick a pointed something in the middle to enable you to find a centre for a drill bit (don't forget your safety goggles of course ) H&S rules for idiots You don't need to buy any special tools ! ( as the artmistress said to the gardener) Sorry Ken ! Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted May 21, 2009 Share Posted May 21, 2009 I use a similar method to Peter's but I use masking tape instead of Tippex. Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted May 22, 2009 Share Posted May 22, 2009 of course you dont need special tools myron, a lada will get you from a to b but a roll's will get you there faster and more comfortably.pencils have to be sharpened if and when i can find one then wheres the scalpel?oops no blade put in new blade and then ruin it, use pencel sharpener you say had dozens cant find one, anyway i LIKE gadgets so there Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted May 22, 2009 Share Posted May 22, 2009 I'm with Phil on this one.....I bought a Great Planes Dead Centre as soon as I saw one.....brilliant, brilliant, brilliant & why didn't I think of it before!!!!!!! Used all the time for just about any hole.....engines, servos, motor mounts.....holes end up dead in the middle rather than off to one side...I can't praise it highly enough!!!! Next to an inflatable Tony Nijhuis I can't think of a more useful thing to have in the workshop........!!!! Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted May 23, 2009 Share Posted May 23, 2009 nice one steve i bought a bag of thirty pencils sharpened five and put one on each bench, where they promptly evaporated. my missus had a collection of toy pencil sharpeners ten in all, borrowed them all and they evaporated too Quote Link to comment Share on other sites More sharing options...
