Adam Lomax Posted January 9, 2010 Share Posted January 9, 2010 hi everyone im looking for a reciever for my tech one mini piaget and i have found this one on robotbirds. it says it is supplied with crystals, but can i fit my own as my transmitter is sythasysed. or are there any other ones in the same weight and price range that you would recommend and also are these crystals suitable or do i need a different one thanks Adam Lomax Quote Link to comment Share on other sites More sharing options...
Erfolg Posted January 9, 2010 Share Posted January 9, 2010 Adam I know nothing about these receivers. Yet cannot reflect there must be a lot of millage yet on 35. The size and price are so right for indoor and park fliers. Erfolg Quote Link to comment Share on other sites More sharing options...
John Privett Posted January 9, 2010 Share Posted January 9, 2010 I'm not sure I've understood exactly what you're asking - so apologies if I'm stating the obvious! It makes no difference that your transmitter is synthesised - just set it to the frequency of the xtal supplied with the receiver and ignore the transmitter crystal they send with it. If you're asking about buying additional crystals to have the option of using alternative frequencies then I'd check with Robotbirds what crystals it requires. Your second link doesn't state whether or not the crystal works with that receiver - it might, or it might not! The only way to know for sure is to ask Robotbirds.Edited By John Privett on 09/01/2010 14:12:31 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted January 9, 2010 Share Posted January 9, 2010 Adam you will probably need to buy the Rx crystal, just specify the same channel number you like to use on your Tx. Note this Rx comes with the non-standard servo plugs (lighter weight) which is fine if thats what you need, otherwise you could look at one of these http://robotbirds.com/catalog/product_info.php?products_id=2024 I have a MPX Cockpit Rx and use lots of different 35 mhz Rx's with it, just have to buy the Rx crystal to suit frequency I use. I have one of these http://www.giantcod.co.uk/corona-rd620ii-dual-conversion-receiver-35mhz-p-318.html in a 6 Channel glider and it has been very good. Quote Link to comment Share on other sites More sharing options...
Adam Lomax Posted January 9, 2010 Author Share Posted January 9, 2010 the reason i have to get another crystal is because im on a set channel at my club all of the servos and esc use the lighter plugs. to simplify, i didnt know if that reciever had to use that crystral supplied or if i could change it to one of my own small ones. sorry for the complexness Quote Link to comment Share on other sites More sharing options...
John Privett Posted January 9, 2010 Share Posted January 9, 2010 It's worth asking if they can supply one with the specific frequency you need. Presumably they have them available on a range of different frequencies. Otherwise other small ones you already have might work - or they might not. Even if they appear to work give it a good range check to see that the range is the same as with the "official" crystals. Usual advice is to make sure you match the "brand name" on the crystal to whatever you're plugging it into - so a Futaba crystal into a Futaba rx, JR crystal into a JR tx etc. Obviously this is more difficult with a "no-name" rx - but the instructions (or supplier) should tell you it uses "Brand X" crystals. Quote Link to comment Share on other sites More sharing options...
Hamish Posted January 9, 2010 Share Posted January 9, 2010 Try Giant Cod for a Corona synthesised 4 Ch £12.76 or 8 Ch Dual Conversion synthesised £14.65 I have a few of these and have no problems. Not as quick or accurate as Futaba, but good value and easy to change t suit transmitter xtal Quote Link to comment Share on other sites More sharing options...
Adam Lomax Posted January 14, 2010 Author Share Posted January 14, 2010 found one on BRC hobbies for £9.99Edited By Adam Lomax on 14/01/2010 20:53:59 Quote Link to comment Share on other sites More sharing options...
Jonathan Lewzey Posted January 15, 2010 Share Posted January 15, 2010 the mini piaget needs the lightest receiver possible so look at the falcon models stuff. JST servo plugs are a must to obtain a AUW of less than 50g. The corona is too heavy - would be alright in a larger shockie. Of course, the spektrum AR6300 would be the ultimate choice Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted January 15, 2010 Share Posted January 15, 2010 How about the mico rx that Simon Chaddock has used in his 24" Sopwith Pup? i don't know who made it but I'm sure Simon could tell you. Quote Link to comment Share on other sites More sharing options...
Adam Lomax Posted January 16, 2010 Author Share Posted January 16, 2010 i got one with the micro plugs from brc. only weighs 2g. jonathan, no spectrum 2.4 systems for me, good old 35mhz futaba works just fine Quote Link to comment Share on other sites More sharing options...
Adam Lomax Posted January 16, 2010 Author Share Posted January 16, 2010 i believe that the one simon used had standard plugs on it. i already have one in a bigger shockie of mine. Edited By Adam Lomax on 16/01/2010 22:02:57 Quote Link to comment Share on other sites More sharing options...
Jonathan Lewzey Posted January 17, 2010 Share Posted January 17, 2010 Posted by Adam Lomax on 16/01/2010 22:00:22: i got one with the micro plugs from brc. only weighs 2g. jonathan, no spectrum 2.4 systems for me, good old 35mhz futaba works just fine good choice, i just like 2.4 for the peace of mind when i'm flying 3D. also, the aerial tends to get in the way of hand catches Quote Link to comment Share on other sites More sharing options...
