Peter 'Ivanna Crashalot' Savage Posted November 7, 2008 Share Posted November 7, 2008 if i found the magazine , do i get the proper size plan free? Quote Link to comment Share on other sites More sharing options...
Bosh Posted November 10, 2008 Share Posted November 10, 2008 I'm now at the stage with my Typhoon where I need to get the retracts and servos for the wings before I can continue. Which will suit this plane better, mechanical or electronic retracts? I've been looking here and also at the irvine model here but don't know which to go for. The model will be slightly smaller and heavier than the original (see above posts). Quote Link to comment Share on other sites More sharing options...
Bertrand CHOUPIN Posted November 10, 2008 Share Posted November 10, 2008 I would go for the mechanical Irvine or Hangar 9 set. Bertrand Quote Link to comment Share on other sites More sharing options...
batcho99 Posted May 10, 2009 Share Posted May 10, 2009 Hi all. Just started cutting out the formers for the tiffy,(i know i'm a way behind everyone else!!) but wanted to fit a four stroke. I've been reading thru the thread and found that it's difficult to fit a four stroke without changing the design? I've got a spare ys63 thats a possible contender for the power plant. How many people actually managed to fit a four stroke?? Your help will be much appreciated. Or should i wait til the next special? I missed the hurricane or I reckon i'd have a crack at that Quote Link to comment Share on other sites More sharing options...
alula Posted May 17, 2009 Share Posted May 17, 2009 Apart from the obivious ,having to make a new cowl/ canopy/ retracts /wheel size,. would it still be possible to scratch build this from the magazine plan. and maybe fit a 46 -52 size two stroke. anyone else done this Quote Link to comment Share on other sites More sharing options...
jwims01 Posted November 14, 2009 Share Posted November 14, 2009 What are good IC engine options (2 and 4stroke) for the model , according to the plans that were printed in the magazine? I've already started building, and can make my own cowl/ canopy myself. Since I've already started, I'm going to "roll with it" as is, but I'm giving second thoughts to a subscription.I'm kind of stuck in the middle, here. It would be nice to know what the hell I'm doing. Quote Link to comment Share on other sites More sharing options...
Don Harvey Posted January 27, 2010 Share Posted January 27, 2010 I have been considering building the Tempest from the RCM&E Special and by reading the forum have found the the plan is somewhat smaller than intended - I also read about the 'solution'... what is the solution? Having decided to build the model a couple of years since buying the Special I am not aware what this solution is. I would most probably go the plan pack way, so does this mean I will have to buy the 'right' plan? Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted January 27, 2010 Share Posted January 27, 2010 The correctly sized plan is included with the plan pack Don. That printed with the magazine was 10% too small. There were explantory pieces on this site and in subsequent issue of the mag' along with a free plan replacement offer. Edited By David Ashby - RCME Administrator on 27/01/2010 12:30:50 Quote Link to comment Share on other sites More sharing options...
batcho99 Posted September 21, 2010 Share Posted September 21, 2010 Antbody still building this or just starting it? Just been looking thru some old plans and i'm still keen on this one. I haven't got anything on the building board at the mo. Not doing the BT Hurri like I originally planned. Need something else a bit easier for now. Iain. Quote Link to comment Share on other sites More sharing options...
Tony Woodhouse Posted November 17, 2010 Share Posted November 17, 2010 I've nearly finished mine (after 3 years !!!)It has come out much heavier at 91/2 lbs with over 1lb lead. I fitted a rcv 90cd and had to cut a box into the firewall to accommodate the carb. The engine is still a bit forward and there is a gap between the spinner and cowl, but, hey ho, its not for scale comps, so won't matter too much when its in the air (if it gets that far!!) Any comments on what it may be like to fly being so much overweight? I'm not that experienced a flyer. Just how critical is the CoG? I think mine is at the most rearward point given on the plan. Cheers Tony Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted November 18, 2010 Share Posted November 18, 2010 Hi Tony, I built one soon after it came out but it flew like a brick, lasting a couple of flights. I put an OS 70FS upfront which was around the recommended power source but with in excess of 1lb in lead upfront to balance the wing loading was dangerous. As with alot of plans the AUW estimate is extremely optimistic to the extend of almost being misleading. I have built quite a few models from scratch, but I think this TN design is over-rated. THat's my view and I am sure there loads out there that disagree, but you can only speak as you find. Best of luck with it mate! Quote Link to comment Share on other sites More sharing options...
Tony Woodhouse Posted November 20, 2010 Share Posted November 20, 2010 Adrian,thanks for the comments, I'm now more nervous than ever!!! I'll let you know how it goes when I eventually get up the nerve to try it! I have fitted flaps to mine, so that may help, and I'm told that it will need to be flown fast to keep it in the air , so landing may be a very high speed and interesting affair as our strip is not that wide. Cheers Tony Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 22, 2013 Share Posted March 22, 2013 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Bucksboy Posted April 12, 2013 Share Posted April 12, 2013 Good luck with yours Andrew, I've always hankered after one of these but that short nose always worried me. Please post any pictures of your build. I'm halfway through his 72" Spitfire at the moment and must say, I'm enjoying the build. Quote Link to comment Share on other sites More sharing options...
