The 2011 Christmas Build
Many thanks Jim and Weasel or as we say down here Jim Jaguar SS,I think Ive solved the main problem .Once I had figured out how to tie this flipping Turkey into a cookeable semblance and wrapped it in Foil I was away with everything else.The Sparrowhawk will be a doodle Night and the bird goes in the oven at 8.30 am
Next 2 jobs were the engine mounts and tank.You remove a plate at the bottom of the fuselage held in by 2 screws.Then fit a tank support onto the inside bulkhead.Slide the tank in,hold it in place with a rubber band.Glue another support at the back of the tank.Engine mounts just screw into place,the captive nuts are already there. Next job is the under carriage
