Acro Wot ARTF (balsa) chat
Niall
Your bulkhead does look slightly different to mine, however, I am using the O.S. 55 AX in mine and did remove the smaller cutout piece on my bulkhead and still had to use an extension. It will not cause you an issue and will help chuck the exhaust further from the fuselage, if you use the extension. Mine needs hardly a wipe after an engine run, using a rubber extension on the exhaust stub. It’s a case of what fits best.
S
Niall
My bulkhead had two “cut out” pieces, one I can see in your picture, the other, much smaller sat in line with where your exhaust sits and the “recess” is hidden by covering film, this lies where the exhaust fits. I hope this makes sense. Even opening this up I needed the extension from Just Engines. It however works a treat.
Sorry, rubbish with computers else I’d do a picture for you.
S
