Phil May Posted December 29, 2012 Share Posted December 29, 2012 Has anyone used the padded double sided tape to stick servos to plastic servo covers? I normally use two pack epoxy but was wondering how good servo tape is. Cheers Phil Quote Link to comment Share on other sites More sharing options...
Erfolg Posted December 29, 2012 Share Posted December 29, 2012 I have, but only in conjunction with the mounting screws. I have never really trusted double sided tape, sometimes sticking like, well you know what, othertimes, just failing. Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted December 29, 2012 Share Posted December 29, 2012 Hi There I have used the double sided pads that are used for Interior rear view mirrors. My local car parts shops charges 30p each Quote Link to comment Share on other sites More sharing options...
Ernie Posted December 29, 2012 Share Posted December 29, 2012 Hi Phil, I wouldn't take the slightest chance with any adhesive. I reckon the servos are just too important a part of the avionics, to take any chance. It might work 99 times out of 100, but what about that one hundredth flight (also, it doesn't do the servo case any good) ernie Quote Link to comment Share on other sites More sharing options...
FlyinBrian Posted December 29, 2012 Share Posted December 29, 2012 I have used double sided tape from DIY stores sold for sticking up mirrors etc, I think it is a 3M product. It has a tab at the end of each piece and you can remove it fairly easily by pulling on the tab. It works well on plastic and on sealed balse although I have only used it in small models < 1M Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted December 29, 2012 Share Posted December 29, 2012 Servo tape was at one time a very common way of doing an installation. But of course screws are much more common now - there is a good reason for that! Double-sided tape is great for fixing Rx's in place etc., but personally I wouldn't rely on it for a servo. If you are going to try it "No More Nails" make reels of it - sticks well under the right conditions and can be bought at B&Q. "The right conditions" means alsolutely clean, flat surface, no hint of grease or dust. Stick in place and leave 24 hours before trusting under load. BEB Edited By Biggles' Elder Brother - Moderator on 30/12/2012 18:05:36 Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 29, 2012 Share Posted December 29, 2012 Mechanical fix every time for me. No sign of tape on my servos. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted December 29, 2012 Share Posted December 29, 2012 As an after-thought: It is a technique popular with the glider fraternity (or so I believe!) perhaps one of them might comment? BEB Quote Link to comment Share on other sites More sharing options...
Erfolg Posted December 29, 2012 Share Posted December 29, 2012 Oh, BEB, no, no, no, not "No-Nails" I used it for skirting boards in the Kitchen, some fell off. I just happened to mention it to my eldest daughter, in passing, whilst discussing, completing the build. Is that the stuff, that you squirt on, was a question. Mhh, yes. You now the same thing happened at the "what ever", they all had to be refitted. Using what, I asked, do not know, but they seemed to do the things you do, you know, drilling holes and things. Although I do trust Silicon, certainly not that type of stuff. I also suspect it can be heavy. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted December 29, 2012 Share Posted December 29, 2012 No Erf - not "No nails adhedsive", I agree that's rubbish - it didn't work for me either! But their double sided tape it a beast of a different colour - it does work - and works very well! I'm on my third pack and would swear by it! BEB Quote Link to comment Share on other sites More sharing options...
Simon Chambers Posted December 29, 2012 Share Posted December 29, 2012 For foamies and small aircraft, I've taken to wrapping masking table around the sides of the servo, then Cyano the servo in. If you need to later remove the servo you can prise it out, leaving a clean servo and just need to cut out the remaining masking tape. Si. Quote Link to comment Share on other sites More sharing options...
Phil May Posted December 29, 2012 Author Share Posted December 29, 2012 Thanks guys. It is for a sloper, the wings are to thin to screw the servos in so they have to lay flat on the mentioned plastic servo mounts. I've glued in the past but if a servo has failed they are swines to remove. Edited By Biggles' Elder Brother - Moderator on 29/12/2012 23:42:16 Quote Link to comment Share on other sites More sharing options...
Erfolg Posted December 29, 2012 Share Posted December 29, 2012 Ahhhhhh BEB. I will look for next time I am in B&Q, seems to be useful stuff. Although I cannot immediately think where to look, with the Velcro perhaps? Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted December 29, 2012 Share Posted December 29, 2012 That's the spot! BEB Quote Link to comment Share on other sites More sharing options...
bouncebounce crunch Posted December 30, 2012 Share Posted December 30, 2012 G'day Phil, came in late here. I have used double sided tape for servos in Glider / thermal and slope up to 2 metre spans with no problems and then refit / renew for a new season or sooner if need be (bad landing). doing this since the eighties i reckon adhesives might have improved since then too. but it is a good way of keeping the servos in place for gliders. bbc. Edited By bouncebouncecrunch on 30/12/2012 06:46:47 Quote Link to comment Share on other sites More sharing options...
Erfolg Posted December 30, 2012 Share Posted December 30, 2012 Why not use thin servos I used these, they do the job. Better still, select from the vast range at low cost, such as these or if digital For thin wings these days, I would not think of any other way, you can just about get most into a 12-15mm thick wing Quote Link to comment Share on other sites More sharing options...
Romeo Whisky Posted December 30, 2012 Share Posted December 30, 2012 Of course a lot depends on the size and weight of the model and the servos, but for small (9-18g) servos in foam models I always use a hot-melt glue gun. (Doubt if this would work on plastic servo covers though - for that I'd use the black double-sided VERY strong stickies form Maplins AND screws as well). Quote Link to comment Share on other sites More sharing options...
bouncebounce crunch Posted December 30, 2012 Share Posted December 30, 2012 Erfolg you have just made me cry, Nostalgia has been fogging my eyes, I never even looked for this stuff, so big thanks owe you one of theseororif you are copping that bad weather. bbc. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted December 30, 2012 Share Posted December 30, 2012 Romeo Snap, I have used hot glue on foam wings mainly EPO, although one Polystyrene (where they still remain). I found that it does hold well, essentially by adhering well to the foam (being rough/grain like/bobbly texture). On the case, I just overlapp slightly onto the top surface. Initially i did this, because that is what happened. On the removal of one servo for replacement, I did find that the bond is best described as flat surface to flat surface, that you get on surface plate, or slip gauge to similar surface, or where a water film acts as an apparent glue, or more technically, low inter atomic Vandrvell forces. In short, a thin blade inserted between the case and glue, it suddenly parts. I found this by noting, that the edges were showing signs of separating. Just a slightly differing shade. Why do I dwell on this? Only because, it works well on foam, If that mechanical lock is not there, and one surface is prone to movement, I would not have long term confidence. Quote Link to comment Share on other sites More sharing options...
IanN Posted December 30, 2012 Share Posted December 30, 2012 For micro 5g/9g servos in the smallest models where vibration isn't an issue (sub 30" span electric) I have wrapped servos in masking tape and then glued (evostik) without any problems at all Otherwise its ALWAYS screws Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted December 30, 2012 Share Posted December 30, 2012 Very strong double sided tape is often used to fix bits of trim to car bodies (side rubbing strips etc) It is very thin & very strong & widely available at car accesory shops or fleabay.....comes in different widths too... typical example here Quote Link to comment Share on other sites More sharing options...
Erfolg Posted December 30, 2012 Share Posted December 30, 2012 It does fall of. Granted the conditions the average car has to endure are savage. I have had one trim come off, although it had double sided tape, it was also secured with those press through type mechanical studs. Quote Link to comment Share on other sites More sharing options...
SkippyUK Posted December 30, 2012 Share Posted December 30, 2012 I use double sided foam on my foamies but usually smear UHU POR over both the servo and the location which then makes the doable sided foam really stick. Other times I have used hot melt - especially on EPP and have released the servos using a temperature controlled hot air gun on low setting to soften the glue and the servo comes out but the temperature and direction has to be regulated. I've found this gun invaluable in re-tightening covering and providing very localised heat. Quote Link to comment Share on other sites More sharing options...
Colin Bernard Posted December 30, 2012 Share Posted December 30, 2012 I have used the 'No Nails' tape on a glider and small Cub very successfully. The trick is to make sure you are sticking two non porous surfaces, so as others have suggested, I first wrap insulating tape around the servo and then prepare a ply plate by coating one side in epoxy and letting it set and then gluing the other side to the fuselage side. The tape is then stuck to the epoxy side which now being non porous makes a good bond, and the servo pressed home against the tape. Seems to hold rock solid - both models have lasted two seasons like this and he servos are still firm. Woud not use it for larger models though - I would still want the assurance of servos that have been screwed to bearers. Edited By Colin Bernard on 30/12/2012 19:18:15 Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 30, 2012 Share Posted December 30, 2012 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
