Djay Posted January 24, 2014 Share Posted January 24, 2014 Thanks to Peter Millers articles in RCME I decided to give designing and building my own model a go. So using the back of a roll of xmas paper I laid out the basic guide lines and sketched in some outlines using the old control line models of the 60s and 70s as inspiration. Then this was photocopied, pages joined together to make a working plan. After taking measurements the wood cutting began. Darryl Quote Link to comment Share on other sites More sharing options...
Djay Posted January 24, 2014 Author Share Posted January 24, 2014 first the formers then the sides and doublers. Then the building of the fuse begins. the building and cutting is not the best but the joints are strong and fitted correctly Darryl Quote Link to comment Share on other sites More sharing options...
Djay Posted January 24, 2014 Author Share Posted January 24, 2014 the tail is built up and sheeted in 1/16th balsa for strength and light weight. the wing rib used is a modified flat bottom profile drawn to meet the size required on the plan, ribs made using the sandwich method,.hard wood spars used and only takes minutes using superglue to knock up two basic panels plywood joiner fitted ready for joining panels only one side sheeted as this allowed me to leave rib 1 loose on the un-sheeted panel to get the correct dihedral, then glued in place as the panels are joined. Quote Link to comment Share on other sites More sharing options...
cymaz Posted January 24, 2014 Share Posted January 24, 2014 Good work . It's the wing that flies the plane. So if the wing is true and the tail is square then it will be a flier. Edited By cymaz on 24/01/2014 12:43:22 Quote Link to comment Share on other sites More sharing options...
Djay Posted January 24, 2014 Author Share Posted January 24, 2014 basic sheeting of the fuse begins, tailplane just resting on top, starting to come together, wing dowels, u/c blocks and wing mounting plates/bolts added tank bay Quote Link to comment Share on other sites More sharing options...
Djay Posted January 24, 2014 Author Share Posted January 24, 2014 MK1 cockpit being fitted. Quote Link to comment Share on other sites More sharing options...
Djay Posted January 24, 2014 Author Share Posted January 24, 2014 starting to cover with belly fairing Quote Link to comment Share on other sites More sharing options...
Djay Posted January 24, 2014 Author Share Posted January 24, 2014 wing top wing bottom Quote Link to comment Share on other sites More sharing options...
Djay Posted January 24, 2014 Author Share Posted January 24, 2014 I was not happy with the canopy so ripped it off and made MK2 now looked more like the plan and an old control liner Quote Link to comment Share on other sites More sharing options...
Djay Posted January 24, 2014 Author Share Posted January 24, 2014 servos fitted engine and nose leg All done test flight day Quote Link to comment Share on other sites More sharing options...
Djay Posted January 24, 2014 Author Share Posted January 24, 2014 it took about 2 1/2 weeks from design to finish using only parts from my scrap box. Engine is an old SC 52 2st, servos are standard Futaba 3001 with 2.4 R/X. No balance weights needed. weight unknown but was built extremely light. Covering is scraps of Solartex to add strength to the build. On the day of the test flight it took off in about 2 meters and went vertical, after throttling back and adjusting the aileron trim and elevator trim it flew absolutely amazing. It is probably one of the best flying aircraft I have ever flown in 30 years off modeling, kits, plan builds and ARTF's. I am so pleased with it that I had 3 flights without altering a thing. It flies hands off straight and level, all aerobatic maneuvers are carried out with ease, inverted flight needs the slightest of fwd stick pressure and it floats in so gently for landing even in a cross wind. Now to decide if I want to build a cowling or just enjoy it as it is. And it needs a name. Any suggestions? My next project is already being drawn up ready to cut the parts. thank you Mr Miller for the inspiration Darryl Edited By Djay on 24/01/2014 13:11:39 Quote Link to comment Share on other sites More sharing options...
Martyn K Posted January 24, 2014 Share Posted January 24, 2014 That looks good and the proportions look absolutely fine. noname mk.1 Well done, looking forward to hearing about the maiden.. Martyn Quote Link to comment Share on other sites More sharing options...
Djay Posted January 24, 2014 Author Share Posted January 24, 2014 thanks Martyn. test flight was perfect as mentioned above. Forgot to add, it knife edges all day with only a small rudder input so the fin area is more than adequate for the aircraft. The canopy will hopefully house a camera now I know it flies a treat. C of G is on the spar, 30% back from L/E and this is perfect. Darryl Quote Link to comment Share on other sites More sharing options...
Roger in Dubai Posted January 24, 2014 Share Posted January 24, 2014 Well done Darryl and was a pleasure to witness the test flight and put in the bit of trim you requested. Great landing and will attempt to put the video taken with my DSLR on here when I find out how to post videos. Looking forward to seeing it again next Friday at the field. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted January 24, 2014 Share Posted January 24, 2014 fantastic sir. well done. Quote Link to comment Share on other sites More sharing options...
Plummet Posted January 24, 2014 Share Posted January 24, 2014 Name? How about Albacore? **LINK** Plummet Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 24, 2014 Share Posted January 24, 2014 good on you DJay as nobody else in the whole world has one how's about Uneek? Quote Link to comment Share on other sites More sharing options...
Fats Flyer Posted January 24, 2014 Share Posted January 24, 2014 Very nice,well done.....I would call it BOXEY...suits it well with that fuselage. Quote Link to comment Share on other sites More sharing options...
Tim Hooper Posted January 24, 2014 Share Posted January 24, 2014 Djay, Well done mate! There's nothing to compare with the satisfaction of maidening your own design. tim Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted January 25, 2014 Share Posted January 25, 2014 brilliant , well done , I must have a go at designing something sometime , but I've got a hurricane to build very shortly Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 25, 2014 Share Posted January 25, 2014 Well done Djay. Now you will never look back. Keep them coming and I am feeling highky chuffed to have got another designer working. Quote Link to comment Share on other sites More sharing options...
Christian Hollyer Posted January 26, 2014 Share Posted January 26, 2014 I was standing next to Djay on the maiden on Friday at Al Lisaili. Once trimmed out it looked really good in the air. I've asked Djay to scale it up to something into which I can stick a spare DLE 30... Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted January 26, 2014 Share Posted January 26, 2014 Good job Djay. For some reason it makes me think of Dougal from the Magic Roundabout, so how about that - or Florence? Quote Link to comment Share on other sites More sharing options...
Chuck Plains Posted January 26, 2014 Share Posted January 26, 2014 Posted by Roger in Dubai on 24/01/2014 13:47:36: Well done Darryl and was a pleasure to witness the test flight and put in the bit of trim you requested. Great landing and will attempt to put the video taken with my DSLR on here when I find out how to post videos. Looking forward to seeing it again next Friday at the field. Upload your vid on Photobucket, or a similar site, then post the link on here. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Chuck Plains Posted January 26, 2014 Share Posted January 26, 2014 I like it! But I would like it more if you shaped the canopy as per your drawing. Great job though. Quote Link to comment Share on other sites More sharing options...
