Darran a Dawn Flyer (A first ever build)
Darran
DamageOk so having calmed down and had coffee as BEB advised I started to think if I can recover anything. Above is the extent of the damage. My thoughts are carefully cut out the fus side and f2 and refit new ones. Is this possible with a little care. My concern would be ensuring I don't add a twist etc into the fus and that everything is in line.
as you can see there is a replacement fus (I have one and one half cnc packs) I can slot in.
Edited By Darran on 23/03/2014 13:14:42
Darran
I know how you feel, Looking at the pics I think if it was my DF I'd pull into all back into shape using PVA as the adhesive, wrap it together with masking tape and you will be surprised at the result., it doesn't look like the damage you'd want to write the whole fuselage off or try picking bits out of it.
Good Luck.
John
PS. I pancaked a Funtana resulting in a two piece fuselage and two piece wing where they began life as one, it would have easy to bin it but it was repaired and reflown within a week.
That fuselage split looks repairable to me Darren. Whats stopping you getting a bit of aliphatic or PVA along that split and clamping it closed? If the former is broken - again can it be rejoined? A good aliphatic joint is stronger than the wood itself - especially if the joint dries whilst firmly clamped. So provided you can get in to clamp it I would think that, as bad as it may all look, its actually quite repairable.
BEB
Edited By Biggles' Elder Brother - Moderator on 23/03/2014 14:52:11
It looks like an easy repair! If in doubt see some of the recent articles about repairing models....didn't Peter Miller do one in his column in RC Flyer recently?
Almost any split wood can be glued back together unless it is an old oil soaked model.
Posted by John Milne on 24/03/2014 19:08:01:
Darran
If I hadn't have seen the earlier photo I'd never had guessed there was a repair. Very neatly done.
I wonder if the fuselage sides were to be covered in some type of material it could resist splitting.
John
John
i didn't believe it myself. I was certain when I posted the pics everyone would say start again. Just shows how little I know about all of this building game.
Darran
John
Strange you should say that John.
During a fit of madness I contemplated skinning mine with THIS.
Kev
Posted by Kevin Fairgrieve on 24/03/2014 19:39:38:
Darran
John
Kev
Kev
That would look good.
Posted by Biggles' Elder Brother - Moderator on 24/03/2014 21:32:16:
There you go Darren - lovely job. Well done that repair is completely invisible, thumbs up.
Now don't drop it again!
BEB
Thanks BEB I am pleased with how it turned out.
Ok I am after some tips now on covering with oracover. It's time whilst the build progresses to practice a little with covering.
Looking at previous posts etc it seems that there are a number of ways to go about it.
As a test I have created a second rudder piece so I planed to firstly cover one side then the other overlapping onto the side I originally covered.
Never done this before so wish me luck
I think the trick with covering is to realise that its a two stage process. And you have to find two iron temperatures:
1. the temperature that activates the adhesive - this is the lower of the two temperatures.
2. the temperature that actually shrinks the covering - this is higher temperature.
You can only find these for each covering material by trial and error really. Cut a small square of the covering material. Place it adhesive side up on an inverted warm iron - ie adhesive away from the iron! If it goes wrinkley - sort of bumpy - the iron is at the right temp for shrinking. About 10% lower than this will be the temperature to activate the adhesive.
So, cut your covering, lay over what you want to cover. Set your iron to the lower temperature. If its an open framework, like all the covering on the DF- start by "tacking" down the mid points of the sides, then the corners. By tacking I mean just touch the iron to the surface. Like a "dab". That stick just a little spot. Work your work about the outside, tacking spots diagonally - like you would loosen cylinder head bolts!
Then work to getting all the perimeter stuck down. When that's done then stick the middle bits down.
Once its all stuck, turn it over and do the otherside.
With both sides done, crank up the iron to the shrinking temp and laid it flat on the surface slowly moving it around so you shrink the covering evenly. Do this on both sides.
Don't worry if it looks like a badly wrapped parcel after the sticking down phase! It always does, then when you shrink it, it all transforms into a thing of beauty!
If your covering a sold surface - not an open lattice - the only difference is you start in the middle and work outwards, rather than at the edges as above.
Good luck - covering is a knack really, like soldering, and it comes with practice - again like soldering!
BEB
Get the covering warm & pliable and stretch it around the curves whilst tacking it in place with the iron. Also you can seperate one crease into many smaller ones that may shrink out.
Finally one trick I used on my Ellipse recently was to tack down the covering to the flatter surfaces then heat the film with a craft heat gun whilst pulling & stretching it over the curves but this can go very wrong if the film stretches too much!
Best advice is probably to practice and play with it.
There used to be a good video on the Solarfilm website - dunno if its still though there - take a look.
As Chris says, with film you pull and stretch it round compound curves. With Solartex the other technique works better, work along the edge - gradually drawing it round with the iron. You will get hundreds of tiny little creases forming - but they will shrink out as you flatten it down.
Chris is also right about practice - as I say its a knack. Once you crack it its easy, but it takes a few goes to sus it out. Its much easier to do than to describe!
BEB
Edited By Biggles' Elder Brother - Moderator on 25/03/2014 22:10:06
Darran,
Take your time when doing the tacking as it's easy to try and rush it, I prefer using the iron to purely tack the edges and pull round corners then a heat gun to pull the film into shape over the structure,
Have a look at my pics mid way down the page and you'll see my wing when the edges are tacked and the excess trimmed off, it looks a right old mess but soon pulls into shape after the airgun treatment, don't linger too long in one place though as I did.
Re your last post you may have to put some slits in to stop the rucking up around the corners. If you're not sure I'll post a picture.
Good Luck
John
