Why am i Chipping in ?
Hi John, if you do go to the museum can you see if you can get a shot of the elevator trim tab. I think I know how I'm going to do it (only simply nothing ott) but a photo would help.
No problem if you don't, it won't hold me up for a few months yet. I may get there myself by then anyway.
Nev.
Danny,
looking at the elevators in that picture, seems like the ribs are evenly spaced. I have just glued mine on this evening, and it now strikes me, that the first gap is bigger on the plan. i will have to check these with fresh eyes, in the morning!
While I think about it, shouldn't we be doing the top of the rudder with ribs, instead of solid?
Alex
Hi Alex, I completely agree, the plan is not accurate. But it is what it is. If you want to move the ribs I see no problem with that, another trick is to put the rib tapes in the right place, and try to fool the observer.
Yes the top of the rudder will need treatment to simulate the ribs and tapes. I discussed this with Kev I think on his thread, but well spotted
Cheers
Danny
According to the maker's original information the wing incidence on the full size is 2 degrees. As they don't describe the figure for the tailplane separately I'm sure it's datum zero. Also worth noting that dihedral is 5degrees.
They also describe the intention to build a DHC2 variant with side by side seating and space for a third seat behind, possibly with retractable undercarriage. Clearly that came to nothing, as did the plan to build a jet trainer version.
