Danny Fenton Posted October 14, 2014 Share Posted October 14, 2014 Interesting Colin, the three view i have states 8 degrees but the drawing is of one of the first 26 did the dihedral change do you know? Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 14, 2014 Share Posted October 14, 2014 Just double checked my drawing WITH MY GLASSES ON and it does indeed say the dihedral is 5 degrees, sometimes I shouldn't be trusted to cross the road alone..... Cheers Danny Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted October 14, 2014 Share Posted October 14, 2014 John, I've got the book. Danny, you just answered your question! Glad the two sources of information confirm each other. It was interesting to read that they originally planned to do a side by side two seater version, then lost the chance of the Australian contract because they didn't do it. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 17, 2014 Author Share Posted October 17, 2014 More planking got a bit fed up with it, am full of cold. I pick one of the long permagrit sanders up at every show then think, no too expensive !!! bad move. John Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted October 17, 2014 Share Posted October 17, 2014 "WOW" thats looking good John. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 17, 2014 Author Share Posted October 17, 2014 I keep reading PVA won't sand !!! yes it will, buy a good one and sand with the right paper. I use evo stik and sand with green oxide paper, no problems. Wing next that looks fun John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 17, 2014 Author Share Posted October 17, 2014 You made me smile Tony John Quote Link to comment Share on other sites More sharing options...
Nev Posted October 17, 2014 Share Posted October 17, 2014 Looking very good John cold or not. I started with cold 3 weeks ago and only just getting over it, so sympathise I've got a weekend of decorating to look forward to now so not much building will get done this weekend either. But browny points in the bank are worth having it might stop the "are you ever going to fly All these aeroplanes" comments for a while. Quote Link to comment Share on other sites More sharing options...
Nigel Day Posted October 18, 2014 Share Posted October 18, 2014 Great work John. You're streets ahead of me. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 18, 2014 Author Share Posted October 18, 2014 Thanks fellas Building wings is usually my favourite bit, I suspect this time may be different John Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted October 18, 2014 Share Posted October 18, 2014 John well done sir, I have just started my fuz, and your posts are most helpfull Cheers Baarry Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 18, 2014 Author Share Posted October 18, 2014 Cheers Barry Hope you enjoy it, I did. John Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted October 18, 2014 Share Posted October 18, 2014 John, the problem I have is cutting the strips parallel, altho I have a "balsa stripper", they tend to vary in size down the length, there must be a secret to using it. (4 hands holding down the sheet) Cheers barry Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 19, 2014 Author Share Posted October 19, 2014 I cut planks with a long ruler and scalpel Barry, the trick with the stripper is don't be to aggressive, go over a few times if needs be. John Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted October 19, 2014 Share Posted October 19, 2014 Yes JOhn, I have reverted back to the ruler method, does a better job, the ones I have done have been locked inbetween to pieces timber and sanded flat, so as not to waste them Cheers barry Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 20, 2014 Author Share Posted October 20, 2014 Not much to say today, I had to give myself a good talking to fiddly stuff like the hinges and bellcranks I usually duck but not this time, ordered from Slec so I know they are accurate. I cut a few ribs out and used datum line to add jigging tabs. John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 21, 2014 Author Share Posted October 21, 2014 Still not started wing, but only the doublers and braces to cut now, not a lot of fun to do However, now I have cut the parts, the build don't look so bad , may be a few expletives when I get to the hinges though Single servos and bellcranks for me, piano wire through nylon tube in ribs (less slop little weight) and ball and socket at servo with differential on, hope I don't get it wrong way round...been a while since I've done it mechanically. U/C as plan, I can cut off later if I go with oleos, no lighting on mine so i'm adding a few webs instead. John Quote Link to comment Share on other sites More sharing options...
Nev Posted October 21, 2014 Share Posted October 21, 2014 I've never used bell cranks, well not since flying control line, so was going for separate servos but like you I've gone around the houses a bit and then decided to go with the plan. Hopefully this time I will take more care and build them without any slop, unlike 40 years ago ! Parts look good John, soon get to the fun bit. Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted October 21, 2014 Share Posted October 21, 2014 Nev, like you, it's yrs since I've used bellcranks, I think I'll stick with direct coupling with servo's I feel there is less resistance, easier to instal and set up. Are you going to add greater strength to the U/C mount plates/ribs?? Barry Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 21, 2014 Author Share Posted October 21, 2014 I want one of these one day Nev so i'm sticking with the scale methods John Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted October 21, 2014 Share Posted October 21, 2014 Ambitous young Jedi never really fancied the 190 but that short nosed variant looks very brutal and purposeful..... maybe one day I can be turned to the dark side Cheers Danny Quote Link to comment Share on other sites More sharing options...
Nev Posted October 21, 2014 Share Posted October 21, 2014 I think your flying skills must be better than mine John. Always wanted to build a decent ME 110 though, maybe after this I will have a proper look at finding a plan. Personally I'm going to leave the u/c as is, no strengthening, I'm trying to get into the scale mind set and not keep trying to build a Sunday hack. And yes I have changed my mind since yesterday! Edited By Nev on 21/10/2014 23:52:33 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 22, 2014 Author Share Posted October 22, 2014 Have done a lot of flying Nev, 190's are well mannered for a warbird nice to fly I am only adding a little not going mad with it on the u/c It's got beautiful shape n attitude Danny, I love it John Quote Link to comment Share on other sites More sharing options...
Charles Galloway Posted October 22, 2014 Share Posted October 22, 2014 I remember many years ago Brian Woods flying his BrianTaylor 190 at our club field. It's a small model by today's standards but flew really well. I have the plan and think the retracts don't look too bad to get right. Maybe Danny could lead us in a build of that one. He likes his BT models. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 22, 2014 Author Share Posted October 22, 2014 I built it Charles and sold it to a club mate 60 1/2 span I think ? with mechanical retracts ? enjoyable build but I want a bigger one. I keep eyeing the Meister scale one up John Quote Link to comment Share on other sites More sharing options...
