trebor Posted February 8, 2015 Share Posted February 8, 2015 I tried to type the list out but the forum wont let me, I've got to paste it or do it on a note pad or something. Quote Link to comment Share on other sites More sharing options...
John Francis 3 Posted February 8, 2015 Share Posted February 8, 2015 Hi all Completed loading my first model details for my glider on my new DX6 and have been flying it for some days. I then decided to upload the latest software and transferred it to my transmitter yesterday. Went flying today and bingo --no model memory loaded, absolutely nothing. What a struggle to get it all back again. The motor control would not function and I got a string of 1/2 second beeps from my ESC which suggested a problem with the throttle low position. I eventually found the problem under `servo travel`, I found the throttle bar was central and not moving when I opened and closed the throttle.. I went to `warnings` and had to reverse the 1,2,3 on the motor. The throttle movement was ok before I lost all model data?????????? I believe you can loose model memory when you download updates if you do not save model memory on a SD card before downloading. My question is- How do you download model memory. The manual just states `export all model memories to an SD card separate from the SD card containing the update`. Quite frankly I think the instruction manual on the DX6 is lacking in detail. I have the DX8 manual which is much better and a JR PCM9X manual which is terrific. Can anyone please help in pc language suitable for idiots. Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 8, 2015 Share Posted February 8, 2015 Can't you just type 'SPMTX.SAX' or 'English_v1_07.svx'? They should be the only files on that card. A yes or no will do Pete Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 8, 2015 Share Posted February 8, 2015 John, make sure you have a card in the Tx. Go to 'System Setup' and scroll down to 'Transfer SD Card' Select 'Export All Models', the select the 'Export' option. There will be a transfer bar, which will revert to the option screen when done. Switch off the Tx before extracting the card. Put the card into your reader and cut the file to a folder on your PC/laptop/whatever. The model memories will remain on the Tx - you're just taking a backup. Pete Quote Link to comment Share on other sites More sharing options...
trebor Posted February 8, 2015 Share Posted February 8, 2015 Posted by Pete B - Moderator on 08/02/2015 20:56:00: Can't you just type 'SPMTX.SAX' or 'English_v1_07.svx'? They should be the only files on that card. A yes or no will do Pete Here you go Pete I got fed up trying to type it as this box kept popping up. Copy of what`s on my card. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted February 8, 2015 Author Share Posted February 8, 2015 Ah, I know why, you've saved it 5 times, so SPMTX has now got a "5" or should I say "(5)" after it, and therefore won't work. The file should be: SPMTX.SAX , nothing else. Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 8, 2015 Share Posted February 8, 2015 Paul's got it Right click on the file and rename it as above. Do the same with the sound file, too. Pete Edited By Pete B - Moderator on 08/02/2015 21:18:34 Quote Link to comment Share on other sites More sharing options...
trebor Posted February 8, 2015 Share Posted February 8, 2015 When it downloaded I couldn't open it or send it anywhere. I found out by dragging it onto the computer it worked that`s why I did it 5 times. Quote Link to comment Share on other sites More sharing options...
trebor Posted February 8, 2015 Share Posted February 8, 2015 BINGO !!!!!!!!!!!!!!!! Thanks Pete n Paul. Not sure if it works though, how can I test it. Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 9, 2015 Share Posted February 9, 2015 Well done, trebor! If you've got a model already programmed in the Tx, nothing should have changed but you can never be sure, as John above found out. Check that your model is responding as it should according to your programming. Flying is the best test.... If you've successfully loaded the sound file update, you'll find that the voice files have been sorted into numerous categories rather than one single list. Pete Quote Link to comment Share on other sites More sharing options...
Bugbear Posted February 9, 2015 Share Posted February 9, 2015 Does anyone have, or know of, a complete printable list of the voice files ? Or should I sit down with a pencil and paper and create one Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 9, 2015 Share Posted February 9, 2015 Someone on the RCG thread usually compiles one and it's been mentioned already for this latest revision, which will be somewhat different in content to those already uploaded. An earlier version is here. It's worth subscribing to that thread as that is where you'll find an answer to just about everything - if you look hard and long enough...... Pete Quote Link to comment Share on other sites More sharing options...
Bugbear Posted February 9, 2015 Share Posted February 9, 2015 Thanks Pete, much appreciated. Quote Link to comment Share on other sites More sharing options...
Bugbear Posted February 10, 2015 Share Posted February 10, 2015 Updated voice files list from latest software update. http://www.rcgroups.com/forums/showthread.php?t=1967153&page=1641 Halfway down the page. A lot of work for the author and much appreciated. Quote Link to comment Share on other sites More sharing options...
trebor Posted February 10, 2015 Share Posted February 10, 2015 Just had a look and on the other halfs iPad it comes up as gobbledygook must be missing something, I'd best go to evening classes. Quote Link to comment Share on other sites More sharing options...
Bugbear Posted February 10, 2015 Share Posted February 10, 2015 It's in Microsoft Excel format. Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 10, 2015 Share Posted February 10, 2015 The voice file list has also been put on Google Docs, if that's any easier to view. Pete Quote Link to comment Share on other sites More sharing options...
trebor Posted February 10, 2015 Share Posted February 10, 2015 Computers, electronics the only invention I liked was the ignition system that did away with cleaning points on my motor bike. Quote Link to comment Share on other sites More sharing options...
Bugbear Posted February 10, 2015 Share Posted February 10, 2015 The good thing is that these files can be organised into categories that the individual actually uses thus avoiding having to trawl through the lot when setting up a new model. Nice one Spektrum Quote Link to comment Share on other sites More sharing options...
Simon Hall 2 Posted February 11, 2015 Share Posted February 11, 2015 I am a little disappointed with the full speaker volume of the spoken voice alerts. About 20% louder would be nice for me. I'm not hard of hearing either. I don't fancy using headphones. I still like the TX though overall. Quote Link to comment Share on other sites More sharing options...
trebor Posted February 23, 2015 Share Posted February 23, 2015 Here we go again I'm having trouble allocating switch F to Gear on my Rx for a servo to operate a tow line. I've got flaps programmed onto switch D through Aux1. Throttle on / off is on switch C but for the life of me I can't get switch F sorted. I love this hobby but I hate programming these things. The instructions are severely lacking. Oh my Rx is a Ar610. Also is it possible to program a voice for Throttle on or off ? Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 23, 2015 Share Posted February 23, 2015 It might help to know for which model you want this and the current wing type you have set as you might not have the gear channel available. Try going to System Setup, then Channel assign and click 'Next'. Scroll to Gear and set the switch to 'F'. If you come back to the Monitor screen, you'll see that the 3-position switch F moves the bug as necessary. Hope this helps... Pete Quote Link to comment Share on other sites More sharing options...
trebor Posted February 23, 2015 Share Posted February 23, 2015 It's for the Fun Cub, I have it set on wing dual alleron, tail normal. For some reason it won't allow me to select Aux 1 to assign a switch to it. Quote Link to comment Share on other sites More sharing options...
trebor Posted February 23, 2015 Share Posted February 23, 2015 I'm on the Channel input configure screen. Unable to select position 6 Aux1. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted February 23, 2015 Share Posted February 23, 2015 If you've set the wing to dual aileron, isn't the Tx expecting to see the aileron servos plugged into the aileron and aux 1 Rx ports, hence the Aux 1 is already controlled by the aileron stick. Wouldn't you be better with the tow release on the Gear channel. Can you summarise what servos you've got plugged into which Rx outputs. Quote Link to comment Share on other sites More sharing options...
