Phil Cooke Posted February 8, 2015 Author Share Posted February 8, 2015 Spent a bit of time in the garage this afternoon although most of it was sanding with little to show for it. I did get the rear top 3/8th sheet fitted to both fuselages, so that's the basic assembly finished now pending the spine and canopy, the fitting of the fin, tails and air intakes. The top rear sheeting went on much simpler than the bottom as expected - the former shoulders are all perfectly co-planar in this region. The sheeting still needs sanding to length in the first photo having been rough sanded to the top and side profiles. Will look a lot more Tornado like once all the rads are sanded in... I need to continue to build rear of F8 to fit the 2 engine exhausts at the right point too... the plan is not too specific in this respect, but I have some ideas which we'll no doubt cover later. Final shot shows the fin and air intake pinned into position for the camera... getting there slowly but still a lot to do, and only 9 weeks now until the first PSS event of the year!! Quote Link to comment Share on other sites More sharing options...
Matt Jones Posted February 8, 2015 Share Posted February 8, 2015 Lovely Phil, that assembled shot looks the nuts! Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted February 9, 2015 Share Posted February 9, 2015 Very inspiring that photo Phil. Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted February 9, 2015 Author Share Posted February 9, 2015 with less than 9 weeks to go to the Fly-In and with 2 airframes at this stage, inspiration and motivation is just what I need Mark! Adding another coat of paint here to the pilots before work... Quote Link to comment Share on other sites More sharing options...
Steve Houghton Posted February 9, 2015 Share Posted February 9, 2015 Beautiful craftsmanship as usual, Phil. I can almost smell the balsa from here. I'm not getting the same whiffs from my latest Zlin build, just some noxious foam fumes so far! Quote Link to comment Share on other sites More sharing options...
Andy Blackburn Posted February 9, 2015 Share Posted February 9, 2015 That does look good Phil. I hadn't realised it was only 9 weeks... Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted February 9, 2015 Share Posted February 9, 2015 counting from tomorrow.......60 days and 10 hours ( less your drive time to the Orme ! ) Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted February 11, 2015 Author Share Posted February 11, 2015 Thanks Mark... becoming more conscious of time (!) hence last night a very late nights modelling - painting 4 pilots and ejector seats until silly hours. Prior to that I did get some work done on the fins and the exhaust arrangement. Rez has very kindly modelled the complex exhaust nozzles and actuator in CAD for 3D printing, more on that soon. To fit these accurately onto the model I need to build the fuselage rear from F8, forming effectively the thrust reverser bucket doors top and bottom - there's a big change in section and this will be created in 1/16th balsa - hence a coupe of guide formers are needed to aid the sheeting to conform to the shape required - and to mount the printed parts to. I found last night I needed to supply Rez a slight scale factor to get the width of his CAD model to match my fuselage build on width - 138.0mm between the elliptical fairings at the correct axial station. Still need to hollow out this former so when viewed from the rear the exhausts appear to have some depth to them, and mounted 13mm upstream of the rearmost part of the fus as shown the exhausts are positioned correctly front to back. Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted February 11, 2015 Share Posted February 11, 2015 Wait...what?! Oh right now Rez has offered, it's all systems go for 3D printing eh? What happened to modelling them out of balsa as it doesn't feel right getting them printed? Hehehe I'd be panicking too by now! Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted February 11, 2015 Author Share Posted February 11, 2015 hehehe thanks Andy. I'll take that one on the chin as I DID say I would make them from balsa, you are right. Rez was really keen to model them and presented me with a finished job - it would have been awfully selfish of me not to employ them now, wouldn't it. Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted February 11, 2015 Share Posted February 11, 2015 Don't blame you Phil, I think it's great with the advent of cheaper 3D printers - just buying one myself at the moment! I fancied getting the ejector seat for the A10 printed, but it was quite expensive, so I have designed and will print my own. Sorry for the abuse! Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted February 11, 2015 Share Posted February 11, 2015 If I may.... Yep, I fancied having a go at modelling the tailpipes and being quite pleased with the results have offered them to Phil. If anyone wants the file to print their own then let me know and I'll send you the .STL files... I'll even scale them to suit your dimensions. Rez Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted February 12, 2015 Author Share Posted February 12, 2015 Hey Rez, thanks for posting the pics of the modelled nozzles - these are going to finish the back end off very convincingly indeed I can't wait to get them fitted and painted up! Quote Link to comment Share on other sites More sharing options...
Matt Jones Posted February 12, 2015 Share Posted February 12, 2015 Don't they come pre-painted Then? Quote Link to comment Share on other sites More sharing options...
Andy Conway Posted February 12, 2015 Share Posted February 12, 2015 Hey Rez, I would like a copy please of this file, would this be ready for 3D printing? Don't know much about this printing method would be ideal for my EDF version at the sizes shown. Cheers Andy C Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted February 12, 2015 Share Posted February 12, 2015 I also found it interesting. Don't have such a printer. Would be interested in buying the part printed? Any offers? Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted February 12, 2015 Share Posted February 12, 2015 Andy C, I've messaged you regarding the files. Peter G, Wish I could but I'm struggling to get Phil's done. Rez Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted February 13, 2015 Share Posted February 13, 2015 FWIW, I'm making enquiries to see how much it would cost to get them printed. As soon as I have a cost I will get back to you and we can discuss if anyone is interested in getting them printed through this source. Rez Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted February 13, 2015 Share Posted February 13, 2015 I was looking at the leaflet that Real Model Pilots sent. They do 3D printing of accessories such as this. Maybe if they know a few of us are interested? Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted February 13, 2015 Share Posted February 13, 2015 Yup RMP can print your STL's. I'd do it, but my printer isn't here yet Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted February 13, 2015 Share Posted February 13, 2015 That's who I've emailed. As soon as I hear anything I'll let you know. Alternatively if any of you know the RMP guys personally then by all means get in touch with them independantly. Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted February 13, 2015 Share Posted February 13, 2015 RMP have quoted £15+P&P for a complete set of nozzles and TR mech for one Tornado. If this is of interest then reply to this effect and I will upload the files to RMP and you can order from them direct. Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted February 13, 2015 Share Posted February 13, 2015 Sounds good Rez. Excellent. I will contact them. Quote Link to comment Share on other sites More sharing options...
Fly_Boy_Rez Posted February 13, 2015 Share Posted February 13, 2015 Right, the files have been sent to Sean at RealModelPilots. Feel free to order direct through RMP. Cheers! Rez Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted February 13, 2015 Author Share Posted February 13, 2015 Rez, many thanks for releasing the model files you've so skilfully created - I'm sure other Tonka builders will take advantage of the work you've done today with Sean at RealModelPilots and treat themselves a set of printed nozzles. They are going to look great!! I've built up the rear fuselage now to the former axially positioned for the nozzles. Before the curvaceous 3/32" sheeting could be added I created a little step on the rear of F8 using 1/8th balsa, like this on the top... and like this on the underside... These will act as a ridge onto which the sheeting could be glued. Quote Link to comment Share on other sites More sharing options...
