Rene Wallage Posted October 6, 2015 Share Posted October 6, 2015 So what glue should I use to attach the frame to the cowl?So far I've used thin, medium, and thick CA, without kicker all around. Quote Link to comment Share on other sites More sharing options...
Max Z Posted October 6, 2015 Author Share Posted October 6, 2015 I have used medium thick CA, and it hasn't failed me yet. Max. Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted October 26, 2015 Share Posted October 26, 2015 Hi Max and fellow Wiggo's,, I have bought the kit, just have a few bits and bobs to finish on other projects, then I will be joining you all. Thanks for all the tips, tricks and ideas for a successful build. Only one regret. I took all my back issues of the mag upto the flying club for people to help themselves to, so do not have the July issue! Ah well, that's what you get for being such a nice guy eh! Regards, Glyn. Quote Link to comment Share on other sites More sharing options...
Max Z Posted October 26, 2015 Author Share Posted October 26, 2015 Hi Glyn, good for you! Among the planes that I designed, the Wiggo is easily my favored aeroplane for flying. Incidentally, if you want to re-read my construction article, go to the RBCkits website and look among the shortkit info. Have fun building it! Max. Edited By Max Z on 26/10/2015 13:06:40 Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted October 26, 2015 Share Posted October 26, 2015 Cheers Max, I will do just that. Glyn. Quote Link to comment Share on other sites More sharing options...
Rene Wallage Posted October 27, 2015 Share Posted October 27, 2015 I'm now at my least favorite part of the build: covering! Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted December 7, 2015 Share Posted December 7, 2015 I'm ready to buy the hardware, I just wondered what physical size of 1000kVa motor to buy. I.e.will be the best fit without a lot of spacers etc. Cheers Glyn. Quote Link to comment Share on other sites More sharing options...
Max Z Posted December 7, 2015 Author Share Posted December 7, 2015 It is difficult for me to answer that, Glyn. As you can see from the drawing, the distance from the firewall to the rear of the prop is about 50 mm, but the motor suppliers are not very detailed in the specifications with regards to axial dimensions. I could give you a reference to the one I use in my Wiggo, but that model has been withdrawn for some time now ( it did already survive two other planes ). Max. Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted December 8, 2015 Share Posted December 8, 2015 Hi Max, Thanks for the reply. I'm sure I'm onto it now. I had only read the mag article when I posted, where it doesn't give the motor physical sizes. Later I fetched out the plan and it states the info on there. Manufactures standardisation would be fantastic, along with servos, ah well. Cheers, Glyn. Quote Link to comment Share on other sites More sharing options...
Rene Wallage Posted December 13, 2015 Share Posted December 13, 2015 The picture is very flattering. What you can't see, is that I am going for the "most wrinkled covering" trophy... Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted December 13, 2015 Share Posted December 13, 2015 Hey Rene, Looks god from here, hope it flies like a dream. I just started my build on Sat. Finished the wing, apart from sanding, then noticed I had fitted the wing tips in reverse! Removed and turned round ok. Raining here today, so more building I hope. All the best, Glyn. Quote Link to comment Share on other sites More sharing options...
Rene Wallage Posted December 13, 2015 Share Posted December 13, 2015 Still need to do the pushrods, fasten the tail wheel, finish the pilot, and make the windscreen. Oh, and a prop would be nice. Quote Link to comment Share on other sites More sharing options...
Tim C Posted December 13, 2015 Share Posted December 13, 2015 Here is my Wiggo, airframe completed, just final sanding and covering to complete. Its a Balsa Depron composite, Depron Ribs, and Fuselage sides, with the Lower longerons extended full length . AUW is 25.7oz with 3s 2200MAH LIPO and without covering. Power is a 400 sized 1100kv Outrunner (about 260w on a 10x7), all the running gear (servos, motor etc rescued from a deceased OD 40 inch Stick) most of the balsa, depron was out the scrap box, so a cheap build Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted December 14, 2015 Share Posted December 14, 2015 Hi Max, I only seem to have been supplied with 5 CA hinges in the full kit. Just thought you might like to know. Not got the plan to hand, but I'm sure that the elevators alone used 3 apiece! Otherwise build going ok. Nice one Tim. Cheers Glyn Quote Link to comment Share on other sites More sharing options...
Tim C Posted December 14, 2015 Share Posted December 14, 2015 Glyn, I used 6 hinges on the ailerons, 4 micro hinges on the elevator, and one on the rudder, the wire for the tail wheel acts as the second hinge Quote Link to comment Share on other sites More sharing options...
Rene Wallage Posted December 15, 2015 Share Posted December 15, 2015 I am notoriously bad with lining up hinges. So I used two (big ones, not from the kit) for the rudder and hinge tape for the ailerons and elevator. Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted December 15, 2015 Share Posted December 15, 2015 Hi guys, I need a little help please. F7 and F8, the motor mount/firewall. As far as I can see they are actually touching face to face on the plan, but I have the heads of the four captive nuts holding my two pieces apart. Is it just a simple case of enlarging the four holes in F7 to accommodate these heads, or have I got something wrong? I'll attach two photos, and I apologise that they are 180' rotated, they are the right orientation on my iPad, but self invert when I upload them, sorry. Glyn. Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted December 15, 2015 Share Posted December 15, 2015 Quote Link to comment Share on other sites More sharing options...
Max Z Posted December 15, 2015 Author Share Posted December 15, 2015 Hi Glyn, just fit the captive nuts in F7, they are shown incorrectly on the drawing (my fault I am afraid ). Cheers, Max. Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted December 15, 2015 Share Posted December 15, 2015 Ah cheers Max. I thought so, but just wanted a check from the experts. Have great Christmas all, and happy flying in 2016. Quote Link to comment Share on other sites More sharing options...
Rene Wallage Posted December 17, 2015 Share Posted December 17, 2015 Quick question about the elevator link. Because of the unusual angle of the elevator servo arm to the control horn, should the servo arm's center be slightly forward? Or am I overthinking this? Quote Link to comment Share on other sites More sharing options...
Max Z Posted December 17, 2015 Author Share Posted December 17, 2015 Hi Rene, I made a quick sketch to explain how the linkage should be to get an approximate linear response on the elevator. If you followed the construction drawing, the elevator control horn should be offset as per this sketch. Max. Edited By Max Z on 17/12/2015 21:59:59 Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted December 21, 2015 Share Posted December 21, 2015 Hi Max, My build is almost complete! So after the hols I'll be ready to cover. I fancy using some of the small red and white chequered covering as per your photo. Where do I get it from. Cheers for now, Glyn. Quote Link to comment Share on other sites More sharing options...
Max Z Posted December 21, 2015 Author Share Posted December 21, 2015 Hi Glyn, this is what I used for the checkered bits. Cheers, Max. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 21, 2015 Share Posted December 21, 2015 Some on H.K as well Glyn, cheaper but good stuff. John Quote Link to comment Share on other sites More sharing options...
