Max Z Posted December 30, 2015 Author Share Posted December 30, 2015 After establishing the battery position to get the CofG in the right spot, I stuffed a piece of polystyrene foam underneath the wing to act as a stop to mount it in that position every time. I used a couple of packing foam wedges (seemed appropriate ) to create a home for the battery. I then jam a piece of semi-flexible foam between wing and battery to fix it in position. I am not too worried about fixing the esc to the fuselage, it usually floats somewhere between firewall and battery. I don't recommend using velcro to fix the battery since it will be really difficult to remove it from underneath the wing. Max. Edited By Max Z on 30/12/2015 21:42:07 Quote Link to comment Share on other sites More sharing options...
Tim C Posted January 5, 2016 Share Posted January 5, 2016 Wiggo is nearing completion, just a few small jobs and she will be ready to go. Quote Link to comment Share on other sites More sharing options...
Max Z Posted January 5, 2016 Author Share Posted January 5, 2016 Quote Link to comment Share on other sites More sharing options...
trebor Posted January 5, 2016 Share Posted January 5, 2016 That's really nice Tim. Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted January 6, 2016 Share Posted January 6, 2016 Thumbs up from me here, I'm not too far behind. Let us know how she flies. Quote Link to comment Share on other sites More sharing options...
Jim Mchugh Posted January 6, 2016 Share Posted January 6, 2016 That scheme is excellent! Got to get back into building the fuz on mine... Very well done! Quote Link to comment Share on other sites More sharing options...
Tim C Posted January 6, 2016 Share Posted January 6, 2016 The scheme is a cartoon take on Riccardo's F1 car, maybe his off time flyer! The Helmet was fun, just a piece of pink foam covered in Deluxe Foam Armour and sprayed white, the Smiling Daniel Helmet decal was a trial and took several attempts before an acceptable but not perfect application getting the decal to adhere to the double curvature. Quote Link to comment Share on other sites More sharing options...
Max Z Posted January 6, 2016 Author Share Posted January 6, 2016 Tim, I detect a serious flaw: the tail fin is missing! Max. Quote Link to comment Share on other sites More sharing options...
Tim C Posted January 6, 2016 Share Posted January 6, 2016 Max, no panic just not yet fitted! attaches with two skewers, decided to fit after tail was glued to ensure it was straight Quote Link to comment Share on other sites More sharing options...
Max Z Posted January 6, 2016 Author Share Posted January 6, 2016 Posted by Tim @ ModelMarkings.com on 06/01/2016 15:33:05: ...attaches with two skewers,....... That's how I did it. I hope you are not taking my comment too seriously, I'm sure it will fly just fine without the little triangle. Max. Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted January 9, 2016 Share Posted January 9, 2016 Once more I seek your advice please. I am at the covering stage. I thought it might be best to cover the wing and fuse separately before assembly, due to the difficulty of covering where they join if I don't. I have found that I cannot slide the wing through the fuse unless I remove one servo first as the splined shaft is obviously proud of the wing surface. Therefore it makes the wing profile too large to shove through. But if I remove it I cannot cover the wing before fitting obviously. It would seem to me, that I will have to cut a notch both sides, bottom of wing aperture, but this will spoil the fuse covering, and leave the on show. Catch 22? I hav probably got my knickers twisted, please let me know. Thanks in advance, Glyn. Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted January 9, 2016 Share Posted January 9, 2016 PS What is the best method of bonding wing to fuse? Quote Link to comment Share on other sites More sharing options...
Max Z Posted January 9, 2016 Author Share Posted January 9, 2016 Posted by Glyn Calow on 09/01/2016 10:05:18: PS What is the best method of bonding wing to fuse? Assuming that you did not fit parts F13 and F14 yet as per the building instructions, just put a bead of PVA glue on the wing saddle, slide the wing in with the trailing edge lifted, then press against the forward end of the opening and rotate down until it sits on its saddle properly. Weight the wing down until the glue has set, then fit and glue F13, and lastly F14. I used PVA for most of the joints. As for the protruding servo's, just don't cover the servo bay and install it at a later stage. You may want to install some paper tubes to guide the servo leads as I wrote in the building article. It should not be very difficult to cover the whole plane after assembly, but I choose to cover the wing first, leaving a void near the fuselage to allow for wiping off excess glue. I covered this void with a strip of covering material in the same colour after assembly. Max. Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted January 9, 2016 Share Posted January 9, 2016 When I have a difficult wing to Fuselage covering I use a 2" wide strip to work around the Wing to Fuselage area then covering the rest of the wing with a large section. With regards to your bonding long time set epoxy is the better option. Quote Link to comment Share on other sites More sharing options...
Tim C Posted January 9, 2016 Share Posted January 9, 2016 Glyn, I covered the wing first, leaving the area covered by the fuselage uncovered. I then glued in the wing before covering the fuselage, I used two balsa blocks each side to add glueing area between the lower wing and the fuselage, I then fitted the triangle shaped fuselage sides to the top of the wing, I used PVA resin glue throughout Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted January 9, 2016 Share Posted January 9, 2016 Cheers guys, I've got the idea now. Will take out the bits of info that suit and do as you suggest. Brilliant thanks again. Glyn. Quote Link to comment Share on other sites More sharing options...
Rene Wallage Posted January 11, 2016 Share Posted January 11, 2016 Glyn, you asked for pictures of battery placement. This is how I did it. ESC and Rx are velcroed to the sides. I glued a velcro battery strap to a piece of scrap balsa, and glued that to the bottom of the fuse. KISS. Quote Link to comment Share on other sites More sharing options...
Rene Wallage Posted January 11, 2016 Share Posted January 11, 2016 Here's hoping that next Friday will be dry and not stormy... Quote Link to comment Share on other sites More sharing options...
Tim C Posted January 11, 2016 Share Posted January 11, 2016 Glyn, My arrangement is similar, a strip of light ply held off the bottom glued on, with a Velcro strap, ESC Velcroed to side, but TX is mounted on top of wing near CG position as its a Lemon RX 3 Axis Gyro and needs to be mounted flat and central to CG point Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted January 11, 2016 Share Posted January 11, 2016 Cheers that info will be a great help. Rene, good luck for Friday. I'm sure you'll give us good news later. I have some adhesive from the heat shrink marking the outer surface, my fault, anyone know how I can remove it? Otherwise I may have to recover the wing. Quote Link to comment Share on other sites More sharing options...
Rene Wallage Posted January 15, 2016 Share Posted January 15, 2016 Disaster struck (well, sort of...) While walking to my car this morning, arms full of flying stuff, I stumbled. The tail of my Wiggo hit the car, helped by my not inconsiderable weight, bend, and pulled out the control horn. An easy fix, but no maiden today. Not doing any fixing this coming week because I'll be on holiday abroad; London, UK! Stay tuned... Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted January 15, 2016 Share Posted January 15, 2016 Whoops Rene, Sorry to hear that . It was better than reversing your car over it though. I've seen that done twice. Bring your woolly jumper to England, -4*C this morning. Have a good visit, and welcome. If I can be of help email me. [email protected]. Cheers, Glyn. Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted January 18, 2016 Share Posted January 18, 2016 After 10 days and at least 5 recovers, I have finally got the wing tips covered to my satisfaction. I hate them!! Quote Link to comment Share on other sites More sharing options...
Rene Wallage Posted January 19, 2016 Share Posted January 19, 2016 I concur. After 2 attempts I took her to a friend of mine. He's more experienced than me with sort of thing. The trick (or at least, his trick) was using a third an d fourth hand, to stretch the material over the tip... Quote Link to comment Share on other sites More sharing options...
Glyn44 Posted January 19, 2016 Share Posted January 19, 2016 Oh yes, now that would ease the job no end. Must find a mate! Quote Link to comment Share on other sites More sharing options...
