Paul Marsh Posted December 24, 2015 Share Posted December 24, 2015 Started to build the Ballerina today. already had the formers cut. Fuselage so far: Engine: ASP 52 FS.; Radio: Spektrum AR610 with 5 servos. (two as Ailerons); Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 24, 2015 Share Posted December 24, 2015 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Masher Posted December 24, 2015 Share Posted December 24, 2015 Oh no, he's started early - reach for yer tin hat Quote Link to comment Share on other sites More sharing options...
Masher Posted December 24, 2015 Share Posted December 24, 2015 I'll give you a clue PV - the eye of................. I'm about finished on the build, now on to the fitting out - I've had a reminder of the amount of work involved in a build from plan - great things these ARTF's! Quote Link to comment Share on other sites More sharing options...
AVC Posted December 24, 2015 Share Posted December 24, 2015 Paul, have you built the tail from a solid sheet or have you made a build up structure. In both cases, would yoy make me a favour? Could you weigh the tail group (rud, stab, fin and elev) and let me know how much is it? Kc made his of solid sheet and the weight is 65 grams. I'll make a build up one and the more I thunk about it the more I'm convince that I can beat these 65! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 24, 2015 Share Posted December 24, 2015 Looks very neat.Much neater than mine did at that stage. Sorry! Just watching "The Two Ronnies" and it must have rubbed off on me. Edited By Peter Miller on 24/12/2015 19:29:33 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 24, 2015 Share Posted December 24, 2015 I know. I shall probably be in trouble with the moderators for starting it early. Sorry, just watching the The Two Ronnies. Itmust have rubbed off on me Edited By Peter Miller on 24/12/2015 19:30:45 Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted December 25, 2015 Author Share Posted December 25, 2015 The tail is sheeted. Didn't weigh it, as I don't have scales sensitive enough. Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted December 25, 2015 Share Posted December 25, 2015 Ahh, so that's what shape the tail fin is.You are really cracking on with the build (early), it looks good. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted December 25, 2015 Author Share Posted December 25, 2015 Fuselage is all shaped down, ready for sanding and covering. Going too fast - this project was supposed to last the xmas period, looks it might be finished before the end of the weekend. Onto the wings now... Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 25, 2015 Share Posted December 25, 2015 Posted by WolstonFlyer on 25/12/2015 15:47:11: Ahh, so that's what shape the tail fin is. Er, That is the shape onthe plan. What shape did you think it is.? Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted December 25, 2015 Share Posted December 25, 2015 I didn't realise it needed to go all the way down between the blocks of balsa, on the plan it has a heavy outline around the fin so I thought it was just a triangle without the extra bit. Don't worry I am not criticising the plan, just my own bad interpretation, I am glad I didn't cut the bits out yet.Edited By WolstonFlyer on 25/12/2015 16:49:23 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 25, 2015 Share Posted December 25, 2015 That is why it says "Scrap block each side of the fin" I am spending Christmas proof reading the book that I wrote nearly two years ago about basic building. There is a complet and long chapter on reading plans. Not sure if it is long enough. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted December 25, 2015 Author Share Posted December 25, 2015 Bit more. The inner ribs hole weren't right. Cut as in the plan, but the holes didn't align with the spar, so had to cut some balsa off and move the hole 2mm each way. Check the inner ribs before you cut them, as they are not totally accurate - issue with the CAD rendition? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 25, 2015 Share Posted December 25, 2015 Paul Tell me. How are you going to get the servo leads out to the servos? The normal method is to make 1/2" holes in the ribs and insert a paper tube. I don't see those large holes. They should be located over the smaller holes shown for the wire pushrods. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 25, 2015 Share Posted December 25, 2015 Second point.] The small trailing edge is fitted AFTER the top and bottom trailing edge sheet has ben fitted. In fact the wing is built over the leading edge sheet ans trailing edge 1/16" sheet. The trailing edge is addes after the trailing edge is complete. I am pretty sure that I described the squence in the instructions. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 25, 2015 Share Posted December 25, 2015 Posted by WolstonFlyer on 25/12/2015 16:47:53: I didn't realise it needed to go all the way down between the blocks of balsa, on the plan it has a heavy outline around the fin so I thought it was just a triangle without the extra bit. Don't worry I am not criticising the plan, just my own bad interpretation, I am glad I didn't cut the bits out yet. Edited By WolstonFlyer on 25/12/2015 16:49:23 There is a photo that shows the shapes of the tail parts in the article. I sure that there is. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted December 25, 2015 Author Share Posted December 25, 2015 There are pilot holes - I run a reamer through all the holes at once, my normal way. The l/e is not glued yet, just holding everything straight. Quote Link to comment Share on other sites More sharing options...
kc Posted December 25, 2015 Share Posted December 25, 2015 Paul, I think you are talking about the slots for spars, so surely just moving the spar by about 2mm would allow the ribs to fit? Actually Peter's instructions in RCME say " position the rear spar by using a couple of ribs to get the location correct" which should cover this slight error on the RCME plan. I have to say that Peter's own drawing shows this accurately but the RCME drawing varies by about 2mm Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 25, 2015 Share Posted December 25, 2015 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
kc Posted December 25, 2015 Share Posted December 25, 2015 If you look at Paul's photo and compare with the photo in Peter's article you will notice that Paul has not followed the same method of wing building. Peter's photo and instructions in RCME describe putting the lower LE sheeting down first and building upon that. I have followed that method on another of Peter's designs ( Swamp Rat ) and found it produced a straight wing very easily. Putting the LE edge sheeting on afterwards can cause problems. I advise others to follow the written instructions exactly- it's a good method. It allows for the slight curvature of the ribs and allows building flat on the board because the LE sheeting raises the ribs up slightly. Quote Link to comment Share on other sites More sharing options...
