Baby Ballerina
That's a lovely build. Very neat and impeccable wood work. Very very impressive.
I thought that was your kitchen at first and I thought lucky person (or something like that) he is allowed a grindstone in there - then the penny dropped. Now even more impressed
Martyn
Posted by John Milne on 04/02/2016 12:33:13:
it seems to take four or five cycles of "where is it ?" "search, search, search", "find it", "put it back again" before I develop a mental index of where everything is smiley
Regards
John
Lucky you, only four or five...
My problem is that is takes much more than that, and once the place sticks in my (limited) grey matter, I change the place, and back again to cycle one...
Posted by Peter Miller on 04/02/2016 15:16:15:
Sounds like your bench is due a spring clean Peter. Dare you give us a picture of it ?
You asked for it!!
Peter, I see that I'm in the right path to become a great designer and builder: my workbench looks almost as "professional" as yours smiley
Well, one of my Swann Mortons and two brand new packets of Du-Bro modelling pins are currently AWOL but are lurking somewhere.
Your bench Peter, now I'm no scientist but that picture is living proof that the Chaos Theory exists in the modelling world. wink
John
Made a start in the wing department.
Usual method of laying down the bottom sheeting and cap strips which I'll then add spars, ribs and GOP sheeting.
I measured , hopefully accurately, the position of the holes in the ribs to give me the correct dihedral from the wing joining tube.
I've done a rough fit of the ribs and tube and it looks OK. I think I mentioned before there is no rational reason for a two piece wing, I just fancied the challenge.
Wing update.
The method I use for the top sheeting is to glue together and trim to size the whole piece then pin and glue to the false leading edge, when fully dry I dribble some glue down into the gap between rib and sheet at the front then the other contact areas. The whole assembly is then weighted down.
The little reinforcing blocks on the leading edge will be for the cannon and MG mounts.
Edited By John Milne on 06/02/2016 22:13:51
The ribs do look a bit thick Peter as they've been made from off cuts given to me, I'd guess they were about 1/4 inch.
Colour scheme/fit out is leaning towards a 109G for something different. As Chris says, the ribs could handle some recoil.
Just finished an Airfix 1/24 Messerschmitt 109g which I think I'll use as a reference.
John
Nearly finished the bulk of the wings.
My usual method to get a snug fit between root rib and fuselage is to angle the first rib in the wing as accurately as possible, in my case I didn't do it very well crying, then cut an oversize root rib which fits over the wing tubes, glue this rib to the first rib then slide onto the wing joiner and pin the root rib to the fuz side.
I had some 1/2 block which I used for the wing tips. I profiled one block then split it on the bandsaw.
Homemade sanding blocks for squaring things up and a slim one for facing off the trailing and false leading edge.?
Just finished this Airfix 1/24 109 so for a bit of fun I'll use it as my reference for fitting out and colour scheme smile.
John
Nearly finished the balsa battle.
I use a piece of scrap balsa cut to the right height for my hinge line to guide the blade.
I made a jig for drilling the holes to take the Robert hinges for the flaps.
I've set the hinge line outside the wing profile so I get a nice clean wing section when closed.
Regards
John
yea great hinging John ,ive got a HK jet with the same hinge setup and i tried to copy it once,i should of made a jig like yoursthen it might of worked properly. i should of joined the forum years ago,the quality of building on here is superb not like me bish bash bosh,but it makes me happy.
Nothing wrong with bish bash bosh whatsoever AndyD and if you look closely at my bui!d you will find that method at work in a few places but carefully framed pictures are the secret wink.
Not sure how affective they will be John but they are enjoyable to build and I'm still managing to use materials in stock, until tomorrow when I need to pick up a motor.
John
Nice hinging there. Always a bit of a pain.
I recently did slotted ailerons and flaps with inset hinges. Now that really did drive me mad.locamp flt (69).jpg
The buildoer of the full size had not flown the prototype at this stage and he asked ME what trim change I was getting when I put the flaps down
Actually the answer was "None"
Edited By Peter Miller on 11/02/2016 08:32:24
