Tim Flyer Posted July 24, 2016 Share Posted July 24, 2016 That's the front view with partially blanked out intake. The C of G came out perfect with no lead !!! Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted July 24, 2016 Share Posted July 24, 2016 Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 25, 2016 Share Posted July 25, 2016 I ordered carbon pushrod sets from kcmodelaccesories shop on Ebay. 5 sets of them. I assumed that if they were being sold as sets then the supplied adaptors would match the supplied carbon. Nope. What is it they say about assumptions? I've contacted the seller to see what he proposes but I don't intend sanding the carbon down to fit the adaptors. Meanwhile I've recycled some old pushrods to fit. At least the clevis in the pushrod kits are servicable unlike those provided by Ripmax. Instant response apologising and refunding my payment - way to go KC Model Accessories! Edited By Bob Cotsford on 25/07/2016 19:22:17 Quote Link to comment Share on other sites More sharing options...
Rich too Posted July 25, 2016 Share Posted July 25, 2016 aPosted by Bob Cotsford on 25/07/2016 19:06:26: I ordered carbon pushrod sets from kcmodelaccesories shop on Ebay. 5 sets of them. I assumed that if they were being sold as sets then the supplied adaptors would match the supplied carbon. Nope. What is it they say about assumptions? I've contacted the seller to see what he proposes but I don't intend sanding the carbon down to fit the adaptors. Meanwhile I've recycled some old pushrods to fit. At least the clevis in the pushrod kits are servicable unlike those provided by Ripmax. Instant response apologising and refunding my payment - way to go KC Model Accessories! Edited By Bob Cotsford on 25/07/2016 19:22:17 Bob, I used some Ripmax ones recently and I had to sand them to fit I had never used them before and thought it was normal. Quote Link to comment Share on other sites More sharing options...
Rich too Posted July 25, 2016 Share Posted July 25, 2016 Nice job Tim. Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted July 26, 2016 Share Posted July 26, 2016 Cheers Rich. was very lucky weight was spot on. By the way I had to sand my carbon rods which were 3mm to get them into adaptors but with liberal epoxy use they are many multiples stronger than the servos, but would expect them to fit if part of a set. It's going to be 2 weeks now till I can fly it. Anyway I wish you all happy building and success.. Tim Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted July 26, 2016 Share Posted July 26, 2016 One last minute bodge I did do was applying thin rocket cyano to the tail wheel collet/steerer as the axle was still moving . It worked well and the wheel tracks the rudder much better now. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 26, 2016 Share Posted July 26, 2016 I've used various carbon rod kits in the past and never had to sand anything. In fact the ones I recycled were two brands, one used 3.5mm-ish tube, the other 3mm rod and the adaptors on both were sized for the supplied rod. You just can't get the staff these days I need to put the U/C on before i go any further, I'll take note of your experience with the tailwheel Tim. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted July 26, 2016 Share Posted July 26, 2016 If you are stuck for quality push rod sets, try Pete Tindall. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 26, 2016 Share Posted July 26, 2016 Is he still in business Martin? I thought I'd read that Pete Tindall accessories weren't available now. I must have been lucky with the tailwheel as mine went together with no issues - though getting tubes on the link springs to lock them was a bit of a game. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted July 26, 2016 Share Posted July 26, 2016 Sorry Bob, I was unaware of that. Shame. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 27, 2016 Share Posted July 27, 2016 Thought so, as you say they were good quality products. I've filled in two of the lightening cutouts in the side to fit a dual failover switch/regulator for dual power supply and a separate slide switch for ignition. Does anyone know whether it'll be ok extending the hall sensor lead to reach the platform provided for the ignition unit? Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted July 27, 2016 Share Posted July 27, 2016 Don`t think that these have screened leads so I see no reason why not to. Used to use similar at work for car speed sensors which were extended with no problems. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 27, 2016 Share Posted July 27, 2016 That will make life easier, thanks Martin. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 28, 2016 Share Posted July 28, 2016 My second NTH GF38 just arrived - much better presentation than the first one which just happens to power my Acrowot XL so nicely. They now come with a pre-drilled and tapped alloy mount and Just Engines have improved the exhaust adaptor. Guess where the drilled holes in the mount put the prop driver? Yep, 177mm from the mount face. What's more it's only 150ish gms heavier than the ASP FS180, or 400gms less than the Evolution 35. And the Savox servos I put in the tail are quite hefty and a couple of hefty batteries would fit each side of the rudder servo moving the CofG back... Decisions, decisions. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted July 31, 2016 Share Posted July 31, 2016 Got one now, ready for flight. Did the elevator mod, as per the Acro Wot XL. Much better. Engine Asp 180FS Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 1, 2016 Share Posted August 1, 2016 Couldn't resist it, it's petrol power after all Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted August 1, 2016 Share Posted August 1, 2016 with the elevator mod would it be better to have the push rods the same length or does it not matter Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted August 1, 2016 Share Posted August 1, 2016 If the line of the rod is straight and angles the same it doesn't matter. I have my rods same length and both servos opposite each other just under the front of the tail plane . That was because I wanted to minimise extra tail weight. Both my servos are low profile savox ones. I am using a laser 155 glow 4 stroke , so that weighs less than 4s petrol engines with their batteries and ignition units . With a 4200ma life battery in the nose I did no need to add any extra weight . Edited By Timothy Harris 1 on 01/08/2016 15:27:50 Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted August 1, 2016 Share Posted August 1, 2016 It looks good Bob! Look forward to hearing reports of maiden flights. I have to wait as I am on holiday. Edited By Timothy Harris 1 on 01/08/2016 15:30:56 Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 1, 2016 Share Posted August 1, 2016 Posted by Phil 9 on 01/08/2016 13:14:16: with the elevator mod would it be better to have the push rods the same length or does it not matter Mine is like Paul's in the photos above, one behind the other. I had to play about setting travel volumes to get equal movements but that's because one servo is reversed and even Savox 0251MGs aren't 100% linear. WWXL is on temporary hold while I sort out a couple of OS 120 Surpass engines that decided to play up at the weekend. It'll be interesting to see how the balance works out with 1250 gms of NGH in the snout. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 4, 2016 Share Posted August 4, 2016 and with 1250gms of NGH up front, two 1450mAh LiFe packs alongside the rudder servo and two Savox 0251MGs down the back the balance was.... Perfect!. Now to run a tank or two through the engine before it gets maidened. I'm sure the neighbours will understand Quote Link to comment Share on other sites More sharing options...
Rich too Posted August 5, 2016 Share Posted August 5, 2016 As usual I am moving along at a snails pace, and so I made an effort tonight and got the engine mounted. It is nice when the firewall is factory marked for the engine being installed. Quote Link to comment Share on other sites More sharing options...
Rich too Posted August 5, 2016 Share Posted August 5, 2016 I had to cut down the Just Engine supplied threaded rods, but the result is nice and sturdy. Edited By Rich2 on 05/08/2016 19:38:31 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted August 5, 2016 Share Posted August 5, 2016 Nice lump up front Rich John Quote Link to comment Share on other sites More sharing options...
