David perry 1 Posted June 20, 2016 Share Posted June 20, 2016 Just bought a new 3s lipo for my FF9, but my FF9 has just died. Thinks...oh I'll use the 3s in my new taranis, but of course the taranis plug is 2s thus smaller... It was all going so well... D Quote Link to comment Share on other sites More sharing options...
MattyB Posted June 20, 2016 Share Posted June 20, 2016 I wouldn't worry about it - the Taranis comes with a LSD NiMH pack that offers plenty of duration outbid the box. Personally I cannot understand why anyone gores for a multi-cell, high C rated lipo on a TX unless you plan to run a high power UHF or other module - it really is the worst of all worlds (requires balancing, requires removal from TX to charge, high C rating has no purpose in a low far TX and storage at elevated voltage degrades capacity and cycle life). LIFe or NiMH is definitely preferable in my book. Quote Link to comment Share on other sites More sharing options...
PatMc Posted June 20, 2016 Share Posted June 20, 2016 David, if the battery is the same size or near the size of a standard Futaba one it probably will be too bulky to fit in a Taranis. If you do get a lithium battery remember it must not be charged via the charging socket. Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted June 20, 2016 Author Share Posted June 20, 2016 Thanks guys. I was aware of the charging issue, but thanks. I now have a brand new Tx battery I cant use I think . D Quote Link to comment Share on other sites More sharing options...
MattyB Posted June 20, 2016 Share Posted June 20, 2016 Just sell it for half what you paid for it safe in the knowledge it is only a tiny offset to all those £££s you are saving going FrSky over Futaba, Spek or JR! Edited By MattyB on 20/06/2016 20:05:06 Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted June 20, 2016 Share Posted June 20, 2016 Simply do what I did and get a HK Life 9.9V 1500mA/hr Tx pack for about £5.50 and change the plug to suit. You will of course need to us a Life charger. Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted June 20, 2016 Share Posted June 20, 2016 Are you sure the FF9 is dead? One of my old Fuby radios had a 20mm fuse on the pcb that blew meaning the Tx waojld no longer switch on....a new fuse & hey presto....radio working again.... Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted June 20, 2016 Share Posted June 20, 2016 I use one of these. Made my own conversion lead from the standard Futaba plug to the 2 pin used by my Taranis. **LINK** Just remember to remove it for charging. I leave the smaller home made bit in situ, so as to not put extra strain on the Taranis connector. If you would like my spare one just PM me your snail mail adress and I will pop it in the post free gratis and for nothing. Kev Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted June 20, 2016 Author Share Posted June 20, 2016 Thanks. ref my ff9, when I use it the servos jitter quite wildly but never settle down. If I move the sticks only the right hand stick makes a difference but all it does is to bias the jitter one way then the other. Ive never seen anything like it in 30 years! I wondered at first if it was the spekky module but I managed to find a 35MHz receiver and put the original module back in...nope, same fault I am pretty sure its a fault in the transmitted signal because the actual binding signal, and the carrier, is all there fine and dandy...so Im assuming the modulation has gone awry. The jitters arent small. like yiou might see under some circumstances, but large amplitude, high frequency ones. Weird. David Quote Link to comment Share on other sites More sharing options...
PatMc Posted June 20, 2016 Share Posted June 20, 2016 Have you always used the same servos & Rx battery when you've tried this with different modules ? I ask because I had something similar happen on two occasions to me some time ago. First time it was an undervolt [4.8v] Rx battery, next time it turned out to be one faulty servo upsetting the rest. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted June 20, 2016 Share Posted June 20, 2016 You haven't accidentally switched the modulation to PCM? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 21, 2016 Share Posted June 21, 2016 Agreed, under voltage from the 4.8v pack will cause jitter David, and try too range testing with an assistant, to get some distance between the Tx and Rx Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted June 21, 2016 Author Share Posted June 21, 2016 Thanks for the ideas. Alas it's jittery with several models, several different set ups etc etc. I'll take the case apart just in case there's something obvious like a wire or something. I tried it on 2.4 band 35mhz AND. 40mhz so quite happy it's the tx itself. The tranny owes me nothing so if it is BER then so be it, shame though as I have really enjoyed the 9. It's a great size and weight for my mitts. D Quote Link to comment Share on other sites More sharing options...
PatMc Posted June 21, 2016 Share Posted June 21, 2016 Have you checked Martin's suggestion re PCM/PPM ? Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted June 21, 2016 Share Posted June 21, 2016 Sounds to me that your stick pots are completely worn out. They don`t last forever. Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted June 21, 2016 Share Posted June 21, 2016 Ive got a FF9 and when it was new I failed to appreciate the implications of correctly setting PCM/PPM mode depending on the type of Rx I was using and I got jittering. Before you strip anything down I recommend you use the "Servo" function in the Tx to see what the Tx thinks its transmitting.... Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted June 21, 2016 Share Posted June 21, 2016 I fly JR stuff but when it was on 35 nothing would happen if the PCM/PPM setting was wrong. Don`t know too much about Futaba in that situation. Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted June 21, 2016 Share Posted June 21, 2016 Well it definitely does something because it had me driven crazy for a few hours one day when I had the wrong setting. The OP hasn't confirmed if he has tried changing his setting - it may just sort his problem or at least eliminate it as a potential factor. Edited By Alan Gorham_ on 21/06/2016 22:09:19 Quote Link to comment Share on other sites More sharing options...
David perry 1 Posted June 22, 2016 Author Share Posted June 22, 2016 Sorry. Yes sure did try PCM and PPM. I spoke to the recommended engineer and he reckons it might be a failed schottky diode in the power circuit. Ill-get it off to himD Quote Link to comment Share on other sites More sharing options...
