Bob Jennings 1 Posted September 2, 2016 Share Posted September 2, 2016 Anyone able to provide a solution to this mystery. I have two multiplex escs plugged into a Y-lead. One motor turns fine and the other beeps. And beeps.... I tried all the permutations of changing leads, isolating the positive lead in one of the esc's didn't make a difference. I bought an identical esc with the same result. I have put them in separate channels and slaved one to the throttle. Nah. I have even programmed two separate channels to throttle. Nah The beep is driving me mad. Now its feasible that the offending ESC is duff, its also possible that the replacement ESC I bought arrived in a duff state. Hm. Anything else I can try? Twinstar still unflown! Cheers, Bob Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted September 2, 2016 Share Posted September 2, 2016 I have been flying a brushed motor Twinstar 2 for about 10 years but have not yet tried brushless motors. However this website shows three schematic wiring diagrams to wire up two brushless motors and may be of help? www.4-max.co.uk/pdf/How-to-wire-up-a-twin-Brushless-aircraft-rev2. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted September 2, 2016 Share Posted September 2, 2016 Do they both work OK individually? Have they both been taught the throttle range? Quote Link to comment Share on other sites More sharing options...
Geoff S Posted September 2, 2016 Share Posted September 2, 2016 Have you tried connecting just one esc to one of the motors so that the drive system 'thinks' it's just dealing with a simple single motor model? If that works, then change the esc and try again. Does that work? If both esc work individually then they should (will) work as a pair provided you only use the BEC from one of them to power the receiver and the servos. Geoff Quote Link to comment Share on other sites More sharing options...
Tony Richardson Posted September 3, 2016 Share Posted September 3, 2016 I have a multiplex sonic liner with two brushless mpx 480 inrunners controlled by two castle creations esc's through a y lead powered by a single battery, no wires are disconnected and I have never had an issue with this setup, as Martin says have they been taught the throttle range? are you using a single battery or two? one for each motor this may make a difference I'm not sure, test the esc's independently you may have been unlucky and got a duff one "twice" if you switch them with the motors do they still behave in the same manner, bear in mind no matter how well matched they are one will always behave a little different from the other. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 3, 2016 Share Posted September 3, 2016 Trim the throttle right down, Bob Even go into travel adjust on the TX and make the throttle travel minus Quote Link to comment Share on other sites More sharing options...
Bob Jennings 1 Posted September 3, 2016 Author Share Posted September 3, 2016 A great big thank you to everyone who has responded. I can't seem to get the ESCs to respond individually and go into programming mode! I'm using the supplied single 3S lipo More beeping. I'll try trimming the throttle right down. Meanwhile... I have A4 Skyhawks to finish off for next weekend. Cheers all. Quote Link to comment Share on other sites More sharing options...
Bob Jennings 1 Posted September 3, 2016 Author Share Posted September 3, 2016 Just had another curious tinker with the throttle setting in the transmitter. Success, both motors are working, although one has braking, the other doesn't. I have a starting point. Cheers Denis. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted September 3, 2016 Share Posted September 3, 2016 I have a very old twin star which I converted to brushless, had problems with the ESCs (not MPX) on a Y lead, plugged them into separate channels and providing the 2nd channel was at min throw when the throttle was at idle it worked, but if the throttle didn't reduce the ESC to throttle off and min trim on the mixed channel it wouldn't arm. I ended up putting the two ESCs on a V tail mixer with input from the throttle channel and a 2nd input from a channel mixed to rudder to give differential throttle. Must get it out again. Quote Link to comment Share on other sites More sharing options...
Former Member Posted September 3, 2016 Share Posted September 3, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Mike T Posted September 3, 2016 Share Posted September 3, 2016 Brushless gives a quantum leap in performance and I believe motor mounts in the latest version have been modified to make brushless installations easier. It is a superb (and superbly presented) model, which lends itself to all sorts of adaptions and conversions. Quote Link to comment Share on other sites More sharing options...
