Tim Flyer Posted July 30, 2017 Share Posted July 30, 2017 Cheers John . Can't wait but sadly we r on hols next Sunday and Saturday is a Drone comp at our club 😳. So it will have to wait a few weeks . The 100 is a BRILLIANT engine . Thanks for recommending!Darn fantastic noise and certainly pulls. As I used the heavy oversized retracts this plane needed no lead too😊 Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted August 20, 2017 Share Posted August 20, 2017 The big maiden flight day was today. I hadn't flown for a couple of weeks due to a holiday but the wind was perfect. Almost straight down the runway and 9-15mph. The laser 100 started by hand almost too quickly! so I had to get her into the air. I had already set the carb idle setting at home a few weeks ago in my garden and given it a short run .and throttle up. I had two initial taxiing stalls as the tail lifted as I hadn't given it enough up elevator travel. I had used the inner hole on the servo arm and only 70%rates. In the end I put elevator rates up to 120% and that seemed perfect. Take off was very smooth and the engine pulled nicely on the 15x6 prop. In the air the plane needed a lot of trim and pulled left and down . I soon had that sorted. It was a joy to fly though and I was soon doing rolls etc . The flaps are big and worked well . With flaps deployed and undercarriage down I noticed just a slight nose down attitude which was perfect. Slow flying was excellent and I didn't notice tip stall tendency. I had two great flights both with lovely landings ! On the second flight I certainly put it through its paces with loops rolls etc and the plane flew beautifully. Thanks again Jon for your excellent advice. I might try the 15x8 prop once run in as you suggested. The Laser 100 is certainly a strong engine and sounded lovely. Next flight I will try to coax out a few "pops" too! Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted August 20, 2017 Share Posted August 20, 2017 Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted August 20, 2017 Share Posted August 20, 2017 At the field today! Quote Link to comment Share on other sites More sharing options...
Jon H Posted August 20, 2017 Share Posted August 20, 2017 winner winner Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted August 29, 2017 Share Posted August 29, 2017 Managed two great p47 flights again this weekend. This plane is a really "silky" flyer and lands incredibly smoothly. I did drop out of loops a couple of times due to me pulling back too hard near the top, but it was easily recovered with a roll out. I moved my LIFE receiver back a few inches to see if that made any difference to handling but didn't notice much and the trim hardly changed. I will probably leave it as it is now. What I might try are some larger wheels if they will fit as the standard foam ones are a bit notchy on our hard grass strip if the plane us static and sometimes it tries to nose over when moving off after being left standing. The Laser 100 is spot on perfect in this plane next time I fly it I will try the 15x8 prop as I think it's becoming run in now. I also flew my much liked BH Chipmunk on Saturday and I would say this plane is even smoother to fly. 😊 Edited By Timothy Harris 1 on 29/08/2017 11:23:51 Quote Link to comment Share on other sites More sharing options...
Rich too Posted August 29, 2017 Share Posted August 29, 2017 Nice one Tim Quote Link to comment Share on other sites More sharing options...
Jon H Posted August 29, 2017 Share Posted August 29, 2017 Really good news Tim. If i had been paying attention id have invited you over again, we had a great weekend of flying at my end. With your wheels, bigger is better for sure as most artf models come with pathetic little bottle caps. I would say 3.5 inch is probably scale for the P47. you could also put a 1/16 or 3/32 ply shim under the rear u/c mount to just tweak the gear forward a bit. Even moving them forward half an inch will help a great deal. Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted August 29, 2017 Share Posted August 29, 2017 Cheers Jon and Thanks again for your advice and encouragement. I think I will upgrade to the 3.5 inch wheels as you say. There are some nice cross treaded fairly narrow ones I have seen and will try adding a small fillet under the retract body as you mentioned 😊 Quote Link to comment Share on other sites More sharing options...
Jon H Posted August 29, 2017 Share Posted August 29, 2017 you might have to remove the plastic wheel wells in the wings and open the bays a touch with the bigger wheels. well worth the effort if it stops it eating dirt on every landing. Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted September 12, 2017 Share Posted September 12, 2017 I managed another two great p47 flights last weekend on Saturday before the rain. We had a decent wind up to 20mph going straight down the runway. I moved the battery back a bit more and tried out a 15x8 prop. The Laser 100 performance was great and it easily made big loops and held good speed up and down the fairly strong wind. I was surprised it runs so well with the 15x8 as I run my OS95v on a 15x6 on my Chipmunk and it certainly seems plenty for that engine. It must be the long stroke of the Laser 100 helping. Anyway landings were far smoother with the re balancing. I did just manage to touch the prop near the end of the landing run on damp grass as the wheels bogged down , but it didn't nose over and re settled easily on the tail wheel. I got applause from club members for the mini display and lots of good comments on the model and engine . One suggested a smoke system! Maybe another day🙂. Regarding the wheel wells they are not lined , but the size of my retracts and wing dimensions prevents me going bigger than 3 inch wheels. I installed the Robart 3 inch scale ones which look good and perform well although slightly heavy. I'm certainly very happy with this combination. Edited By Timothy Harris 1 on 12/09/2017 14:49:16 Edited By Timothy Harris 1 on 12/09/2017 14:53:23 Edited By Timothy Harris 1 on 12/09/2017 14:54:33 Edited By Timothy Harris 1 on 12/09/2017 14:55:14 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 12, 2017 Share Posted September 12, 2017 What a treat this is for the guys down at your patch And for you too, what a beauty? Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted September 22, 2017 Share Posted September 22, 2017 Cheers Denis I just noticed your post as I was out a bit recently. This plane has really given me confidence with Warbirds. No way am I an ace pilot just very average and yet this plane set up as per the advice on this forum was a real revelation to be honest. I do have the WorldModels Spitfire which is just a bit trickier and has poor retracts limiting its "every day" use on our grass strip. I put the heavy duty HK electric retracts on this model as recommended earlier in the thread an this has made it a real pleasure to land. With the extra power this plane can support the decent retracts and proper well covers . I'm definitely a warbird convert now . When I started flying that was always my aim which I never thought achievable given my very average flying ability. I can't wait to be flying it again when the grass dries out🙂 Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted September 22, 2017 Share Posted September 22, 2017 Here is a later picture from two weeks ago Quote Link to comment Share on other sites More sharing options...
Jon H Posted September 22, 2017 Share Posted September 22, 2017 Hi Tim Your legs look very vertical and could do with a rake forward. if you look at the photo below of the full size you will see what I mean an 1/8 ply shim under the rear of the retract mounts should do the job Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted September 22, 2017 Share Posted September 22, 2017 My P47 a couple of years ago. This pic was in the RCM&E mag. Need to fly mine, as not flown it for a while... Edited By Paul Marsh on 22/09/2017 18:14:21 Quote Link to comment Share on other sites More sharing options...
Paul Coxon Posted December 10, 2017 Share Posted December 10, 2017 Hi Timothy, I too am building a Seagull P47 and powering it with a Laser 100. I'm about half way through the build and have come up with a few queries that I thought I'd check with you. a) Having fixed the motor to my nice new mount to allow 145mm as per the instructions between the firewall and the prop spinner I've found the cowl couldn't possibly fit and I've had to now use a dimension of 128mm ! Did you have a similar problem ? b) I've fitted larger wheels (3.5" and raked the oleos slightly forward as was suggested by Jon Harper and had to cut down the oleos and trim the wheel well to achieve this, but the wheel well flaps that fit onto the oleos are well clear of the bottom of the wing which will case considerable turbulence. This problem is not caused by my adaptions. Did you have the same problem ? c) I notice that you haven't fitted the bombs ! I fitted mine but a friend advised against it. Not sure whether I should remove them ? Any advise gratefully received Paul in France Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted March 28, 2018 Share Posted March 28, 2018 Blimey Paul for some reason I missed your reply on this thread From December . You must have finished it by now and I hope it went well! Anyway Regarding cowl dimensions I can’t be sure but I think I used my own measurements after cowl fixing to make sure the prop cleared the cowl. I did use my own large cowl blocks to provide much more secure cowl fitting. I decided not to attach the wing bombs as it would reduce drag a bit plus they are quite vulnerable to Hangar rash and bad landings! I did find I could not go much larger in wheel size due to my large heavy duty oleos on my retract legs as the wheel wells are not very deep. Anyway sorry I missed you and I hope you are enjoying this lovely plane. I can’t wait until it dries out on our runway and I will give mine a flight. Edited By Timothy Harris 1 on 28/03/2018 15:30:22 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted June 5, 2018 Share Posted June 5, 2018 A great flyer, no lead and HK electric retracts fitted. Quote Link to comment Share on other sites More sharing options...
Joakim Karlsson 1 Posted September 23, 2018 Share Posted September 23, 2018 Hi guys! I'm buying this plane as a christmas present for myself And I have a Laser 100 I'm putting in this one, seems a like a great match. A question though, which HK retracts and oleos are you guys using? Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted September 23, 2018 Share Posted September 23, 2018 it a brilliant plane with the lase 100 . Use a 15x8 prop and it’s perfect.for retracts I use these **LINK** Quote Link to comment Share on other sites More sharing options...
Joakim Karlsson 1 Posted September 23, 2018 Share Posted September 23, 2018 Great thanks! Did they fit in the wing without modifications? Did you use the oleos you got with the plane or buy other ones? Edited By Joakim Karlsson 1 on 23/09/2018 19:05:23 Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted September 23, 2018 Share Posted September 23, 2018 For oleos I used these . I cut them to length and drilled out the retract hole to suit then I epoxy them in.https://hobbyking.com/en_us/alloy-straight-oleo-struts-with-trailing-link-205mm-12-7mm-2pcs.html?___store=en_us Edited By Tim Flyer on 23/09/2018 19:06:37 Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted September 23, 2018 Share Posted September 23, 2018 Don’t forget to angle them forwards a bit by adding either washers or thin wood fillet on rear of retract mount ...helps prevent nose overs 😊 Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted September 23, 2018 Share Posted September 23, 2018 Wing needs a bit of dremmeling but not much . I also reinforced the wooden retract boxes a bit. Quote Link to comment Share on other sites More sharing options...
