Peter Miller Posted November 16, 2018 Author Share Posted November 16, 2018 I have a collection of old aerial tubes and assorted K&S brass tubes up to 1/2". For holes in ply formers I have some hole saws. Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted November 16, 2018 Share Posted November 16, 2018 Hi to all, If somebody is looking for some hole saw bits like Geoff showed, here's a link to AliExpress. At just over €4,- including shipping, I wouldn't use them for marble, tiles or HS steel, but they're great for our balsa or ply jobs. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted November 16, 2018 Share Posted November 16, 2018 After eventually negotiating the US post system of entering an address I got there in the end. Worth a punt at that price. Quote Link to comment Share on other sites More sharing options...
Dean Sarelius Posted November 17, 2018 Share Posted November 17, 2018 Hi Trevor, I purchased the Chinese made K40 Laser cutter for AU$525 and am in the midst of doing all the recommended modifications like replacing the cutting table and adding the air assist to improve the cuts. https://www.ebay.com.au/itm/40W-CO2-USB-Laser-Engraving-Engraver-Cutter-Woodworking-300x200mm-Movable-Wheel/192672721621?hash=item2cdc306ad5:g:vwEAAOSwIDZbOy1F:rk:19f:0 The 40 watt laser is perfect for cutting balsa and ply and the whole unit measures 800x500x300mm however you also need to take into account the added room for the exhaust and water tank for cooling. What I like so much about the K40 is the ability to make improvements as it is well supported by a good maker community with a plethora of Youtube videos. The only drawback is the cutting dimensions are only 200 x 300mm so for some larger parts I need to split them into two or even three sections. Another good reason to have access to the laser cutter is if I smash the plane then it should be much easier to do a rebuild without to much angst. I like the Ohmen as there is no need to produce any canopy or cowl molds for vacuum forming but should the need arise I also have access to a 3D printer. I would look forward to share my DXF files with anyone wishing to use the K40 to do build off the plan. If you think this could be of any benefit let me know and I will be sure to post them when I have finished the build. Cheers, Dean Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted November 17, 2018 Share Posted November 17, 2018 Thanks for all the detail Dean. I haven't really got space for much in the way of bench mounted tools, so I'll probably pass this one by. Looks good for the more prolific builder though. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted November 17, 2018 Share Posted November 17, 2018 Posted by Martin McIntosh on 16/11/2018 21:44:44: After eventually negotiating the US post system of entering an address I got there in the end. Worth a punt at that price. When you get the tools, let us know how they work. Even in tile cutting Geoff Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted November 17, 2018 Share Posted November 17, 2018 For the Ohmen you just need a balsa knife, a David plane, a saw and some sandpaper. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 17, 2018 Author Share Posted November 17, 2018 Posted by Martin McIntosh on 17/11/2018 19:30:26: For the Ohmen you just need a balsa knife, a David plane, a saw and some sandpaper. It does help if you have a power fretsaw. But then I am lazy! Quote Link to comment Share on other sites More sharing options...
Geoff S Posted November 17, 2018 Share Posted November 17, 2018 Posted by Peter Miller on 17/11/2018 21:03:54: Posted by Martin McIntosh on 17/11/2018 19:30:26: For the Ohmen you just need a balsa knife, a David plane, a saw and some sandpaper. It does help if you have a power fretsaw. But then I am lazy! I have that courtesy of Aldi (plus few beer tokens ) but I find I use my small Axminster band saw a lot more. The Aldi disc bench sander helps in correcting slight sawing errors too. It's not laziness, Peter. It's being economical with effort Geoff Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted November 17, 2018 Share Posted November 17, 2018 I also use a scroll saw, not from Aldi but identical. Their sander is a great addition to my power tool kit as well. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 18, 2018 Author Share Posted November 18, 2018 Power tools are essential. I don't have many, the scroll saw, a power drill,a couple of Dremel type drills and an orbital sander which I never use. One of the ones that doesn't get a great deal of use but is a fantasic energy saver is my little Bosch power screwdriver. I even use it for screwing on the wings of my models these days. Edited By Peter Miller on 18/11/2018 08:11:10 Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted December 4, 2018 Share Posted December 4, 2018 Well, my Ohmen is ready to go - needs a spinner to finish it off and good weather when I have free time. Peter's pictures of his model reminded me a bit of a Miles Magister with those tandem cockpits. Hence, as I had plenty of Hobbyking yellow film and some leftover foamy warbird roundels, I've made a cartoon Magister With a cartoon pilot of course! Here's the battery access. I've used a dowel at the front and magnets at the back. Trust me Peter, that hatch is never going to detach in flight, I can pick the model up by the headrest! The 2200 3s LiPo sits in front of the block of balsa on the back of the battery tray, held down by a Velcro strap. Power measurement gives about 400W, the model weighs 3lb (inc. battery) so it should go ok. Peter, the quoted weight in the article is 2lb 10oz. Is that sans battery, or have I just built heavy? I'm not too worried either way, there's plenty of wing. Can't wait to try her, will report back when I have. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 5, 2018 Author Share Posted December 5, 2018 That looks really great!! Averythig is so neat. No. My weight is ready to fly with battery. A 4 ounce variation isn't bad. I will look forward to hearing how you like her. Miond you, looking at the weather for the next week it might be a little while. Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted December 5, 2018 Share Posted December 5, 2018 Thanks, Peter. Yes, the forecast isn't great for the foreseeable future. I've no worries about the maiden, she looks right just like the Ballerina. Quote Link to comment Share on other sites More sharing options...
Ken Ball 1 Posted December 5, 2018 Share Posted December 5, 2018 Trevor Crook, where did you get the pilot, really like the look Ken Ball Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted December 5, 2018 Share Posted December 5, 2018 Ken, I knew someone would ask me that, and I can't remember. I think my father-in-law gave it to me ages ago, I'll see if he remembers. It may have come from some ancient Dick Dastardly model. Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted December 6, 2018 Share Posted December 6, 2018 Well, I asked him and he thinks he picked it up in a charity shop - he always scouts the toy collection for potential pilots! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 7, 2018 Author Share Posted December 7, 2018 I must search charity shops more. I do look around them. Once picked up a collectors camera for a tenner. sold it for £60. Usually I pick something up for £60 and only get a tenner!!! Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted December 8, 2018 Share Posted December 8, 2018 Just received the AliExpress hole cutters which I have tried on birch and light ply. Pretty good at a little over £4 for ten assorted. Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted December 10, 2018 Share Posted December 10, 2018 Maidened mine (shown above) this morning. As expected, no issues, she's a great flier. I've propped it for about 320W full throttle (12x7) and performance is good, just short of unlimited verticle. Take-offs can be done on little more than half throttle. Nicely aerobatic and a doddle to land. Well done again Peter! Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted December 10, 2018 Author Share Posted December 10, 2018 Hi Trevor So glad that you are happy with her. Toying with another unusual scale subject.at the moment . just a bit of fun Quote Link to comment Share on other sites More sharing options...
Geoff S Posted December 10, 2018 Share Posted December 10, 2018 Posted by Martin McIntosh on 08/12/2018 14:11:55: Just received the AliExpress hole cutters which I have tried on birch and light ply. Pretty good at a little over £4 for ten assorted. They do look good and , at that price, worth a punt even for a tool used only occasionally. I have a lot of tools I don't use often but, when I do use them, I'm glad they're in the drawer. I think you should try one on a tile and report back Geoff PS I forgot to congratulate Trevor on a successful test flight of his fine looking Ohman. The winds were very light here today but it was cold and damp with it and only something like a quick test flight would have tempted me. I'm afraid if the temperature is in single figures I stay in these days Edited By Geoff Sleath on 10/12/2018 17:16:23 Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted December 10, 2018 Share Posted December 10, 2018 Done all the tiling I intend to in my lifetime and don`t want to risk knackering one just yet. On the ply I just put the tool in a drill but it was difficult to centre so I think it will be the pillar drill when I come to use them in anger. Much better than twisting some sharpened tube by hand. Quote Link to comment Share on other sites More sharing options...
Trevor Crook Posted December 10, 2018 Share Posted December 10, 2018 I wrapped up well Geoff! The sun was peeping through and as the wind was light it didn't feel too cold. As there were more than a dozen of us lucky retirees at the field I did as much chatting as flying! Two enjoyable flights with the Ohmen and another two with the excellent Flightline Bearcat made for an excellent morning. Quote Link to comment Share on other sites More sharing options...
Geoff Parkes Posted January 2, 2019 Share Posted January 2, 2019 Happy new year Peter, following on from my Peggy sue 2 build , which as i have told you before flies so well it has prompted 3 other members of my club to build one, I was tempted into building The Ohmen again very easy to build costs next to nothing in wood and lecy bits. and flyes just as good as P.S.2 I think the only negative is because its smaller than PS2 it can be affected more by wind strength,we fly off a field that is always windy and I have noticed that if I take both planes PS2 battles on regardless but the Ohmen struggles, probably because its not got the power of my PS2, but small price to pay as on good days its a pleasure to fly with many good comments from the crowd, I have just put one cockpit on mine , if I had any idea how to put pictures up I would post planes photos, regards geoff. Quote Link to comment Share on other sites More sharing options...
