Erfolg Posted June 24, 2018 Share Posted June 24, 2018 My charger for my 8fg tx has failed, which is my second. I have looked on the internet, and those that come up are out of stock. Ripmax website is not working. Any ideas as to where I can purchase a charger with a 7.2v output (for the tx) and a very small (compared with my other Futaba) plugs. Diamater approx 5mm. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted June 24, 2018 Share Posted June 24, 2018 I got a replacement for my set from Weston UK after a second Futaba failed.it would seem they are rubbish. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted June 24, 2018 Share Posted June 24, 2018 Is there anything special about the charger? Assuming the batteries are NiMH then any constant current charger will do the job set to (say) 100mA to 500mA (the voltage is irrelevant), ideally one with an automatic cut off when the batteries are charged. You just need a Futaba compatible connector (IIRC they were 3mm concentric on my old Futaba transmitters ie Challenger). The lead cut off your old charger will do, with suitable connectors to plug into the charger (probably 4mm bullets) and you're up and running. I assume the faulty chargers are just so-called wall-warts with a rough DC output? I really don't understand why anyone uses them when there are cheap 'proper' chargers available from places like HK which will do the job more reliably. Geoff Quote Link to comment Share on other sites More sharing options...
Rich too Posted June 25, 2018 Share Posted June 25, 2018 Don’t bother with Futaba, I use an acucel 6 charger and multi plug lead from HK. Had it for years.... Edited By Rich too on 25/06/2018 05:14:27 Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 25, 2018 Share Posted June 25, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted June 25, 2018 Share Posted June 25, 2018 The Futaba chargers supplied with the radio are very poor. I remember mine (supplied with 14FG) soon breaking. I always charge my Batteries from a proper “computer” program charger( modern field type as Percy mentioned) . That way you can properly monitor battery condition ( what you are putting in and what has gone out) each flying session, plus you can cycle the battery occasionally (important on Nimh) . If you “trickle charge “ that way on 200mah your transmitter battery will last much longer. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted June 25, 2018 Share Posted June 25, 2018 While the normal advice seems to be that NiMH packs don't need cycling as they don't suffer memory problems, Timothy may well be correct in that an extended trickle charge is the only practical way to correct imbalance that has built up over a number of charge/discharge cycles. However, they don't tolerate overcharging and the trickle charge should be done at no more than C/20. The typical minimum output from a modern charger of 100mA means it is only suitable for cells from 2000mAh upwards... At this low rate it is quite possible that the charger will not detect a peak and work as a trickle charger but a constant current regulated supply would be better - even an old fashioned "wall wart" charger may suffice if the output is suitable. I would favour peak detect charging with the occasional correct trickle charge after the charge terminates to correct any slight imbalance conditions. There again, I detest NiMH cells and try very hard to avoid their use! Edited By Martin Harris on 25/06/2018 10:43:49 Quote Link to comment Share on other sites More sharing options...
onetenor Posted June 25, 2018 Share Posted June 25, 2018 Many indoor i.e. permanent markets have a shop for hardware/chandlery/D.I.Y. products for plugs light bulbs cup-hooks fuses etc etc etc. They often carry a tranny/charger with variable outputs and a selection of adapter jacks and barrel connectors Quote Link to comment Share on other sites More sharing options...
Erfolg Posted June 25, 2018 Author Share Posted June 25, 2018 Will this charger do the job? I take it the outer is negative on the plug and the centre +ve. That the white stripe on the cable is the positive. Of course i do not know what the cable on the charger indicated looks like. I am pretty much assuming i can cut the Futaba plug and cable of, then connect striped wire to striped wire etc, or is that to simple? Quote Link to comment Share on other sites More sharing options...
Geoff S Posted June 25, 2018 Share Posted June 25, 2018 I think it would do the job but I see it's out of stock Geoff Quote Link to comment Share on other sites More sharing options...
Erfolg Posted June 25, 2018 Author Share Posted June 25, 2018 Geoff You are far more observant than me. All who advertise this charger are out of stock. I have found this, as i only want to charge my Tx, it will probably do? Quote Link to comment Share on other sites More sharing options...
PatMc Posted June 26, 2018 Share Posted June 26, 2018 Erf, you must already have a charger for electric models - yes? Why not also use that for the Tx ? Quote Link to comment Share on other sites More sharing options...
Erfolg Posted June 26, 2018 Author Share Posted June 26, 2018 Hi PatMac Primarily it is about convenance, as my electric charger used for models is a single model type. The second reason is again about convenance, in that i dislike all the button pressing and menu scrolling i already have to do, just using Lipos. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted June 26, 2018 Share Posted June 26, 2018 Weston UK do a range of chargers of the type you want Erflog. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted June 27, 2018 Author Share Posted June 27, 2018 I have now purchased the Airsoft intelligent charger. The principle reason is that their charger has a Delta Peak charging regime. The second is that the Weston UK chargers are twice the price and are it seems a conventional trickle charger. It seems a bit steep when I can get a similar charger at the local market for just about £5, Time will tell if my decision is a good one. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted June 29, 2018 Author Share Posted June 29, 2018 The leads have been cut, the new charger lead soldered to the old charger plug. Here a picture of the new and the old chargers, it seems that everyone use the same enclosure, I guess it is what is inside that changes. Sometimes a lot, other times not much. The good news with the charger is that it works. That soldering white stripe to white stripe was conventional, where no body decided that there own convention would be better. The other good news is that the delta peak worked, in that the diode changed from red to green after probably an hour and the voltage shown on the Tx was 8.4v. I have not bothered with the multimeter. Quote Link to comment Share on other sites More sharing options...
